Module (BMS PCM PCB) for charging and protecting Li-ion cells 3S 12V 6A - 18650
płetwa 11019 14
Can I charge a 3S Li-ion pack through this BMS module with a normal power supply, or is it only a protection board that still needs a dedicated charger?
This board is only secondary protection for overcharge, overdischarge and overcurrent; it is not a charger and it does not provide balancing [#17004923][#17005018] A protection IC such as the S-8254A is just a protection chip, so the seller’s description is misleading if it suggests a full charger [#17005018] You can theoretically feed a discharged 3S pack from a supply with proper current limiting and a voltage high enough for the pack, but the board will only cut off when a cell reaches the overcharge threshold, which is not proper charging and can shorten cell life [#17004153] For normal use, a dedicated 3S Li-ion charger/power supply with 12.6 V final voltage, current limit, and charge-end signaling is the right solution [#18891646]
  • #1 17003218
    płetwa
    Help: 165
    Rate: 551
    I bought this one system and I have some doubts about its operation.
    According to the description (page quote, link above): "Electronic system protecting batteries against discharge a charger at the same time for these batteries.
    It allows you to build a secure battery pack that does not need to be charged with special chargers for li-ion batteries ".
    The 2 in 1 module will keep the cells in the best conditions, preventing overcharging and excessive discharging. One module replaces the charger and security module here (I have bolded what is important to me).
    I can connect a package armed with this system to a power supply with a voltage above 12V and any current capacity. If so, what about charging signaling?
    Is it just a safety system and does it require a specialized charger?
  • #2 17003325
    aaanteka
    Help: 729
    Rate: 1194
    After all, our clearly described in the title:
    "BMS PCM PCB module for charging and protecting Li-ion cells 3S 12V 6A - 18650 ".
    And in the description of the tile:
    " Technical data
    Security before overcharging: 4.25-4.35v ? 0.05v (per cell)
    Protection against over discharge: 2.3-3.0v ? 0.05v (per cell)
    Maximum working current: 4-5A
    Maximum peak current: 6-7A
    Working temperature: -40 + 50 C
    Storage temperature: -40- +80
    Low current: 6uA
    Life cycle: over 50,000 hours
    Resistance: Less than 45m?
    Dimensions: 50 * 16 * 1.0mm
    It looks like what is in the description - a complete 3 cell package charger. Of course, the power supply must be from a power supply with adequate capacity and output voltage respectively larger than the contractual 12V (package after charging to 12.75V-13.05V and there are transistors on the way). It's best to ask the supplier about the parameters of a dedicated power supply.
  • #4 17003508
    aaanteka
    Help: 729
    Rate: 1194
    But this module already has a balancer. :D
  • #6 17003631
    aaanteka
    Help: 729
    Rate: 1194
    But according to the manufacturer and the elements contained on the disc, the system has a balancer. This is even indicated by the very description of voltage control on a particular cell, how the cells are connected.
    • datasheet.pdf (359.24 KB) You must be logged in to download this attachment.
  • #7 17003704
    płetwa
    Help: 165
    Rate: 551
    wojtek 9007 wrote:
    Hello - in my opinion there is none - please review it again;
    https://abc-rc.pl/modul-balansera-li-ion-li-po-3s-
    Well ... very nice balancer, only how it relates to the subject. My circuit has it built in, I know for sure.
    The basic question is whether how to connect the 18V 1100mA power supply (I have it on hand) - will I charge or spool?
    And when I charge it, how will I know that it is already.
    Here they spelled nice, but my English is a bit short.
  • #9 17004153
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    which exactly is the layout, there is a whole pack of photos in the link.
    If the first from the shore then it is secondary protection only , there is no charger, no balancing and other such.
    The producer (seller) misleads buyers.
    Theoretically, you can charge such a package directly from the power supply, if the power supply has an appropriate current limit working in a convention of a power source, it will work fairly well in the CC charging phase. After crossing the "overcharge" limit by any link, the protection system will simply cut off the power circuit. It will work, but you shouldn't charge the cells, the "secondary protection" is the last line of defense for the cell when all else fails. In addition, "commuting" with charging voltage to the cut-off cutoff voltage causes cell degradation and a significant reduction in lifetime.
    best regards
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    płetwa wrote:
    My post has changed, but it is the one from the first photo:
    https://abc-rc.pl/modul-ladowania-ochrony-ogniw-li-ion
    This arrangement is only collateral : overcharge, overdischarge, overcurrent protection, does not contain any charger and even more balancing.
    I suggest you check one more thing. The seller gives anything enigmatically quite large threshold voltage ranges. Download the layout documentation from post # 6, or if you do not want to spend points, look for the layout documentation on the network (Seiko and various clones). Then read the layout marking on your board and check the table in the documentation for what exactly the parameter values have a layout from your board, you may find that they just don't match your links.
    Freddy
    Help: 1394
    Rate: 2821
    S-8254A Series is a protection IC
    This is only a security module, not a charger.
    In addition, you request 4 points for DS.
  • #13 17010121
    płetwa
    Help: 165
    Rate: 551
    As you can see, the topic has been exhausted. I have some working links from the METABO screwdriver, the system was not expensive, so I can afford destructive testing.
    I close the topic for now, but if something interesting arises, please unlock it and write a few words.
  • #14 17186996
    hashwrc
    Rate: 19
    Can you give a link to this first plate and connection diagram?
    Added after 4 [minutes]:
    So what layout should you add so that you can charge and balance? You can write what systems and how to connect to be able to safely load the package with a regular charger?
    I understand I need two layouts. Balancer + charging module + security module also ?? anyone give links to such modules and connection diagram?
    Can anyone explain to me what is BMS, PCM, Balancer? so blatantly
  • #15 18891646
    budro2
    Rate: 52
    Read here about BMS
    https://abc-rc.pl/BMS-Li-ion-Co-To-Jest-i-co-...-i-ogniwach-litowych-blog-pol-1540976010.html
    PCB - it's just a printed circuit board with electronic components
    Balancer is a system that charges the cells individually because the consumption of cells can be different. Not every module has a balancer.
    The BMS protection module is not really a charger because it must be properly powered with a limited current and voltage following the package. It cannot be a stabilized power supply with a voltage of 4.2Vx3S = ~ 13V DC because with a heavily discharged 3Vx3S = 9V package it will tend to 13V and it will turn off and if it has current protection with undercutting, it will turn off. A certain solution is an unregulated transformer power supply, e.g. 9V DC, which idle has over 13V DC but will be without charging end signaling.
    A better solution is to buy a dedicated 3S power supply / charger:
    Which should have an end voltage of 12.6V, current limit and a Leda signaling power loss / end of charge.
    You can also make a nice charger using a 14-15V DC, 1-3A inventor power supply, for example:
    and a led driver, for example:
    It has current limit and end voltage adjustable with blue potentiometers, and the LEDs on the board show the charging status. It is good to give us. and you. 470 micro electrolytes and a Schottky diode at the input to protect against reverse polarity.
    (suitable for 1S-7S packages and the power supply should have a voltage of ~ 2V higher than the final voltage)
    Moderated By radsat:
    https://www.elektroda.pl/rtvforum/faq.php point: 3.1.18 I have removed the links.
The discussion revolves around a BMS PCM PCB module designed for charging and protecting 3S 12V 6A Li-ion cells (18650). The user expresses confusion regarding the module's operation, particularly its ability to charge and signal charging status without requiring a specialized charger. Responses clarify that the module provides overcharge, over-discharge, and overcurrent protection but does not function as a charger. It is suggested that while the module can be connected to a power supply exceeding 12V, it lacks built-in charging capabilities and balancing features. Users recommend using a dedicated charger for safe operation and to avoid cell degradation. Additional inquiries about the connection of balancer and charging modules are made, emphasizing the need for proper configurations to ensure safe charging.
TL;DR: For a 3S Li‑ion pack, full charge is 12.6 V, and “BMS … is not really a charger.” Use a CC/CV 3S charger, not a raw PSU. [Elektroda, budro2, post #18891646]
Why it matters: This FAQ helps makers choose the right BMS/charger, wire safely, and avoid cell damage when building 3S 18650 battery packs.
Does this 3S BMS board charge and balance my 18650 pack?
No. The specific “first photo” board discussed provides overcharge/overdischarge/overcurrent protection only. It has neither a charger nor cell balancing. Use a dedicated 3S CC/CV charger, or replace with a BMS that includes balancing. [Elektroda, krzysiek_krm, post #17004923]
Can I plug any power supply above 12 V to charge a 3S pack?
Avoid a raw fixed-voltage PSU. Proper charging needs a current-limited, constant-current/constant-voltage profile that tracks the pack. Protection ICs will only cut off at the limit; floating near cutoff accelerates degradation. Use a 3S CC/CV charger instead. [Elektroda, krzysiek_krm, post #17004153]
How do I know when charging is finished?
Use a 3S charger with status LEDs and CC/CV control. Full charge is 12.6 V. A plain PSU offers no end-of-charge signaling and may shut off unpredictably with protection trips. “The BMS protection module is not really a charger.” [Elektroda, budro2, post #18891646]
What do BMS, PCM, Balancer, and PCB actually mean?
BMS/PCM: protection module that manages cutoff for overcharge, overdischarge, and overcurrent. Balancer: equalizes cell voltages in series during charge. PCB: the printed circuit board hosting these parts. A BMS alone does not replace a charger. [Elektroda, budro2, post #18891646]
Does this board include a balancer?
No. Despite some listings, the referenced protection board lacks a balancing function. If you need balancing, add a separate 3S balancer module or choose a BMS with integrated balance. [Elektroda, krzysiek_krm, post #17004923]
Is 12.6 V the correct end voltage for 3S Li‑ion?
Yes. Set the charger’s constant-voltage phase to 12.6 V for a 3S pack. Pair it with an appropriate current limit and status indication to avoid overcharge trips and to confirm completion. [Elektroda, budro2, post #18891646]
What charging current should I use?
Match charge current to your cell datasheets. The board itself is rated around 4–5 A working and 6–7 A peak; do not exceed the lower of cell-spec or board limits. For longevity, many 18650 cells charge well at 0.5–1 C. [Elektroda, aaanteka, post #17003325]
What happens if I keep the charger at the cutoff voltage?
Hovering at the cutoff threshold makes the protection IC repeatedly disconnect and reconnect. This “commuting” degrades cells and shortens life. Use a proper CC/CV charger that terminates cleanly to avoid this failure mode. [Elektroda, krzysiek_krm, post #17004153]
How should I wire a 3S pack to a protection board?
Typical wiring: connect pack negatives/positives to B‑, B1, B2, B+ pads, then route load/charger through P+ and P‑. Verify polarity, set charger to 12.6 V with current limit, and confirm status LEDs function. [Elektroda, budro2, post #18891646]
Can I charge with an 18 V, 1.1 A adapter I already have?
Do not feed it directly. Use a DC‑DC CC/CV module to step down and regulate to 12.6 V with the desired current limit, or buy a dedicated 3S charger with indicators. [Elektroda, budro2, post #18891646]
Is using an unregulated transformer supply acceptable?
It can work if its idle voltage exceeds 12.6 V and drops under load, but it lacks end‑of‑charge signaling and protections. A proper 3S charger with CC/CV and LEDs is safer and repeatable. [Elektroda, budro2, post #18891646]
What protection thresholds should I expect from this board?
Typical per‑cell thresholds are overcharge at about 4.25–4.35 V and overdischarge at about 2.3–3.0 V. Exact values depend on the specific IC variant the seller populated. [Elektroda, aaanteka, post #17003325]
How do I add balancing to this setup?
Add a standalone 3S balancer module between the cells’ taps or replace the board with a BMS that integrates balancing. Balance during charging to keep cell voltages equal. [Elektroda, wojtek 9007, post #17003490]
Quick 3-step: set up a CC/CV charger for 3S
  1. Adjust CV to 12.6 V and set CC to your target charge current.
  2. Connect charger output to P+ and P‑ on the protection board.
  3. Verify LEDs: red (charging) to green (full), then disconnect or let it float at termination. [Elektroda, budro2, post #18891646]
Why do some listings claim “charger + protection” for this board?
Marketing often conflates protection with charging. Documentation and user tests show the linked board only cuts off for faults; it does not perform CC/CV charging or balancing. Trust specs over titles. [Elektroda, krzysiek_krm, post #17004923]
