Skoda Fabia 1.2: Identifying Cylinder Numbering and Ignition Coil Issues
tomek2875 21270 6
  • #1 16417379
    tomek2875
    Rate: 38
    Hello, I am posting because I can't find information on cylinder numbering, but I can start from the beginning. Yesterday coming back from
    work, the car fired normally but only for 2 cylinders, the car jerks terribly and the speed jumps max. Strangely, by the time this fault was all ok. I would bet on an ignition coil or candles but I need information more experienced than me what to do in this topic, including which is the 3rd cylinder from the front of the car? Regards
    Aleksander_01
    Help: 1167
    Rate: 3435
    You count from the timing, i.e. standing in front of the car from the left side first. It's 99% coil (that's my bet).
  • #3 16417406
    tomek2875
    Rate: 38
    great thank you for the answer, so I would bet on the coil, of course, I can not exclude other failures such as candle or valve burn out but so far there was no problem.
  • #4 16417504
    andrzej20001
    Help: 1578
    Rate: 6669
    Swap coils and check
  • #5 16417546
    waski821
    Help: 18
    Rate: 61
    By the way, check or replace the candles, because a used candle shortens the life of the coil.
  • #6 16417595
    tomek2875
    Rate: 38
    Thank you for helpful references to the topic. Tomorrow I will start taking the car after work because it won't work out because of the 2nd day of Christmas. Regards
  • #7 16421129
    tomek2875
    Rate: 38
    Welcome back. Yesterday I purchased a new coil and it turned out that she was the problem. Replacement is very simple, you just have to get tired of unzipping the cube and everything quickly flies. Error cleared by elm 37 and piston application for android. I consider the topic closed. Regards
The discussion revolves around issues with a Skoda Fabia 1.2, specifically related to cylinder numbering and potential ignition coil problems. The user experienced a malfunction where the car only fired on two cylinders, causing severe jerking and speed fluctuations. Responses indicated that cylinder numbering is counted from the left side when facing the engine, and the ignition coil was suspected as the primary issue. Suggestions included swapping coils for diagnosis and checking/replacing spark plugs, as worn plugs can affect coil longevity. Ultimately, the user confirmed that replacing the ignition coil resolved the issue, and the repair process was straightforward.
