50m2 Flat: Best Heating Method for Insulated Brick Block Apartment - Gas or Electric?
McFly07 8250 5
  • #1 16417726
    McFly07
    A two-room corner apartment on the second floor in a brick block from the 1960s. Insulated.
    The total area is 52m2. Room height 2.8m. Cubature of 146 m3.
    Heated with a tiled stove (large room) and electric convector heaters (small room / kitchen). G12 tariff.
    The bathroom has a gas flow water heater installed, remembering probably the time of a companion general.
    No chimney liner.
    The apartment belongs to my parents. Due to their age and deteriorating health, including the need to bring fuel through three floors (from the basement to the second floor) I plan to change the heating method combined with bathroom renovation.
    1. What do you think would be the best way to heat such an apartment? Full gas, gas (hot water plus stove) - electricity or electricity?
    2. What would roughly be the investment and operating costs in the above cases?
    Gas - stove, chimney liner, radiators, pipes, project, chimney sweep?
    Electricity - heaters? I don't know what diameter the wires in the walls are.
    3. Am I obliged to install the chimney liner only when replacing the heater? I read conflicting opinions.
    4. Do I need a permit from the gas plant when switching to gas? If so, how much pleasure can it cost?
    I would be grateful for any help.
  • #2 16417770
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Electricity - expensive, although a tiled stove can be used (by installing heating inserts - it is produced by, among others, Kraków's Elektrotermia). There must be a 3-phase power supply (otherwise the input would have to have low power, and then it will not replace coal). How much space does this room have? If it is really big, then the input would have to have 4kW (if not 4.5 kW) - in storage heating, power counts twice. Of course, a two-tariff meter (seek a power distributor), otherwise the bills will be very high. The installation must be adapted to this power consumption! A tiled stove will heat more comfortably than accumulative stoves or - even more so - than other electric heaters (not counting oil ones, which are very good).
    Gas - unfortunately, we do not allow gas burners to be installed on tiled stoves, which is a pity (this applies, for example, in Ukraine). Then it would be cheaper than electricity (but more expensive than coal) and more efficient. The use of CO from a gas boiler requires the construction of the entire gas installation (a lot needs to be invested - boiler, radiators + the entire installation).
  • #3 16417931
    Xantix
    Help: 686
    Rate: 1657
    Was a friend counting or guessing? In a small apartment with good insulation, the costs of heating with electricity will be comparable to gas with a significantly lower investment.
    Just as for warming and other issues - could a friend @ McFly07 complete the form below and provide results?
    http://cieplowlasciwie.pl/
    Thanks to this, it will be possible to estimate heat demand, required heating power, etc.
    Read a colleague's author post? After all, there is a bull standing there:
    So the room has something around 25-30m2 no more.
    I repeat the question - did a colleague read the author's post?
    Again as the bull stands:
    McFly07 wrote:
    G12 tariff
    So the author has a dual-zone tariff so I don't know why he should apply for it a second time?
    If there is a need.
    To the author - more or less describe your electrical installation - how many phases do you have, what power do you have allocated, is the installation properly made (is there no aluminum instead of copper). Basically, going to electric heating costs will depend on whether you do not have to change the connection conditions and improve the installation - this is the main investment in this heating - while the electric furnace itself is already a moderate cost. In the case of gas heating you will basically have to build the entire CO installation from scratch - the cost will be quite high. Therefore, you should calculate the costs in both cases and see how long each investment will pay back - then you can decide what will be the most advantageous option.
  • #4 16418437
    McFly07
    @zbi_gniew Rusek . @Xantix - thanks for comment
    The site Ciepowlasciwie.pl is really cool. I was looking for something like this. I send the results of the heat balance: http://cieplowlasciwie.pl/wynik/2dxg
    As for the electrical installation, it is a copper, single phase installation.
    Regarding the power allocated by ZE, unfortunately I do not know. In any case, pre-tax collateral at 20A.
  • #5 16418486
    Xantix
    Help: 686
    Rate: 1657
    Contracted capacity should be specified in the contract with ZE. But it can be estimated after pre-meter security - since it is 20 A, the contracted power is less than 5 kW.
    In your case, you would need to secure 7-8 kW of power for an accumulation furnace (and this is the absolute minimum). So you will need a three-phase connection. To get them you should go to your Energy District and ask to change the connection conditions for 3-phase power supply. Of course it costs - how much? - it will already calculate for you in the specific case of ZE.
  • #6 16419107
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Poorly. The electrical contribution to the tiled stove for such a room should have (with good insulation) min. 3kW (suppose 3.6kW). And where are other electricity consumers (washing machine, fridge, iron, TV, lighting, etc.)? This means that the electrical installation will not "yield". It would have to be that what goes the tiled stove, no other power receiver will be able to go, except for those with very low power consumption (TV, radio). According to this tariff, most of the furnace heating takes place at night, but it can be "divided", so that some (smaller) part of "cheap" electricity is also during the day and the furnace can be heated during e.g. 7 + 3 hours or 8+ 2 hours (i.e. the main time at night, 2 or 3 hours at noon, to equalize the temperature, as if it cooled slightly). In principle, heaters for tiled stoves should be powered three-phase.
