Heating in the apartment: Gas or city? Comparison of costs and advantages for 50m2
Desperadosx 18057 16
For a 50 m2 apartment, is gas heating or district heating cheaper and more advantageous, and what should I check before buying?
District heating is usually the more convenient choice and has been slightly cheaper than gas in the past, but prices are changing so fast that nobody can reliably predict which will be cheaper now or later [#20338991][#20339021] The main downside of district heating is that you do not fully control when the heating season starts and ends, and you may still pay a share even if you close your radiators, depending on the building’s settlement method [#20338991][#20339134] If you choose district heating, it is best to have an individual apartment heat meter; avoid systems based on heat dividers or flat-rate area-based billing [#20349365][#20339134] For gas heating, the big advantage is that you can heat whenever and however much you want, but that applies only if the apartment has its own boiler [#20339389] If the building has a shared gas boiler room, it works much like other central heating systems, so check whether the boiler is individual or shared before buying [#20339389]
  • Clarifying gas versus district heating costs for 50 m2
    #1 20336952
    Desperadosx
    Hi!
    I know this may not be the forum for this because I couldn`t find a topic like this, but since I`m here, I`ll ask :D I`m thinking about buying an apartment and maybe someone can advise whether it`s worth buying a flat with gas heating or, if possible, with district heating? or what else to think? I don`t know what the price differences are, does anyone know? and could tell me what the differences are in relation to the month/year, apartment 50 m2 +/- if you need more information, feel free to write, thanks in advance for your help!
    ay56
    Help: 192
    Rate: 487
    Hello, city heating.
  • #3 20338830
    Desperadosx
    So when buying an apartment you shouldn’t even consider whether it’s city or gas?
  • #4 20338913
    ay56
    Help: 192
    Rate: 487
    I wrote that it was urban.
  • City heating is cheaper but less controllable
    #5 20338991
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    Both have their advantages and disadvantages. Currently, it is difficult to say what is and will be cheaper and what is more expensive, because even Maciej, a fortune teller, does not know these prices and their constant changes. So far, municipal heating has been more convenient and slightly cheaper than gas heating. There is one but, namely the city heating only when the manager says we are heating from today, and it stops when the manager says we are not heating and you have no influence on it because even if you turn off all the radiators, you still pay a share for using the central one. Theoretically, gas ones are a bit more expensive, but you can heat them whenever you want and even if there is a failure of e.g. city pipes or a pump in the station, you are not interested in it, you just heat it yourself.
  • #6 20339014
    78db78
    Help: 1816
    Rate: 3285
    zdzichra wrote:
    Gas ones are theoretically a bit more expensive
    It`s also more expensive if the stove breaks down and needs to be replaced if it can`t be repaired, or if it`s old and costs several thousand dollars.
  • #7 20339021
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    Of course, you are right that the boiler is also your expense. Let me be clear, until recently, when it comes to costs, city buses were cheaper. Nobody knows what it will be like tomorrow. Most heating plants are fired with coal, the price of the raw material has now increased 3-4 times, so the price of this heat will also increase.
  • #8 20339116
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Municipal heating (especially when the heat source is a coal-fired power plant) should be significantly cheaper. The disadvantage is that they impose heating even when the weather requires cooling air conditioning (typical heating is in May, which is more and more often not a spring month, but a SUMMER month).
  • Heating season rules and radiator shutoff limits
    #9 20339134
    stachu_l
    Help: 480
    Rate: 1129
    But who imposes? Heat supplier or cooperative?
    The heating network usually operates all year round and only heats hot water in the warm months. If you have a house or a terraced house with your own heating system, you decide whether central heating and domestic hot water works or only domestic hot water. In a block or tenement house there is a certain date for turning the central heating system on and off - something like 3 days with the temperature below 10 degrees, and necessarily from October 1. Perhaps we should consider changing the spring shutdown date and giving a longer conditional period. This is probably some kind of nationwide recipe, but I`ve never needed to read it.
    If there is an individual heat meter, all you need to do is turn off the radiators, but in fact there is a problem with older buildings that have heating risers and dividers on the radiators, or even worse, a flat-rate settlement based on the area of the apartment.
  • #10 20339279
    pipałosia
    Help: 74
    Rate: 179
    I would aim for urban ones. I have one and it`s cheaper than my friend`s with gas, but it`s not a good comparison because I have 50 meters and he has a lot more meters to heat.
  • #11 20339375
    Desperadosx
    thanks everyone for your help! Maybe I'll go for the gas ones, but you can heat them whenever you want and as much as you want :)
  • Check whether the gas boiler is individual or shared
    #12 20339389
    stachu_l
    Help: 480
    Rate: 1129
    Desperadosx wrote:
    thanks everyone for your help! Maybe I`ll go for the gas ones, but you can heat them whenever you want and as much as you want
    But only if you have an individual boiler in your apartment. If you have a gas boiler room common to the entire building, it is similar to any other central heating system, so if you find a gas boiler in the advertisement, check whether it is your own boiler or a shared one.
  • #13 20339390
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    And you pay for what you use, not, for example, leaking hot water in the node 😁
  • #14 20339407
    78db78
    Help: 1816
    Rate: 3285
    You have an old furnace, you buy a new one, but the size is small, and the boiler is too powerful, because there is no choice - an apartment with an area of 45 m2 and it is constantly on.
  • #15 20342041
    Desperadosx
    I see :) I know I probably won’t go to the city ones, but what about gas, is it not worth taking a shared boiler? ^^ and if it is shared, they also heat as they want, e.g. in the city, can I heat it whenever I want? only there is a price difference? and if it is common, can I then arrange an individual one? Is it not worth thinking about it at all because it is too expensive?
  • #16 20342067
    zdzichra
    Level 32  
    Help: 167
    Rate: 306
    It`s difficult to answer such questions. It all depends on the number of rooms that are heated by the shared heating system and on the layout. You need to "interview your potential neighbors by asking them these questions😁"
  • #17 20349365
    slider2002
    Help: 10
    Rate: 43
    If it`s municipal, don`t go for heat dividers. If there is a heat meter for the apartment, it`s ok. The same applies to every boiler room.
The discussion revolves around the choice between gas heating and district heating for a 50m2 apartment. Participants highlight that municipal heating is generally more convenient and slightly cheaper, but it is subject to the heating schedule set by the management, which can lead to costs even when not in use. Gas heating offers more control over usage and can be more cost-effective in the long run, especially if an individual boiler is installed. However, shared gas systems may impose similar limitations as district heating. The rising costs of coal and other heating sources are also noted as a factor influencing future pricing. Participants recommend considering individual heating meters and the potential for shared versus individual systems when making a decision.
TL;DR: For ~50 m² flats, coal feeding many district systems rose 3–4×; "Nobody knows what it will be like tomorrow." Choose district heat for convenience or an individual gas boiler for control and pay‑per‑use. [Elektroda, zdzichra, post #20339021]
Why it matters: If you’re buying a ~50 m² flat, this FAQ answers “gas or city heat?” with clear guidance on costs, control, and pitfalls.
Which is cheaper for a 50 m² flat: district heating or gas?
There’s no fixed winner because tariffs change. “So far, municipal heating has been more convenient and slightly cheaper than gas heating.” Gas gives independence and flexible timing, but you own maintenance risk. Compare current heat tariffs, gas prices, metering, and building rules before deciding. Align choice with your control needs and risk tolerance. [Elektroda, zdzichra, post #20338991]
Can I heat whenever I want with district heating?
Usually not. In blocks or tenements, the manager sets start and stop dates. A typical criterion is roughly three days below 10°C before switching on. If your flat has an individual heat meter, you can close radiators, but building rules still apply. Expect domestic hot water to run year‑round via the network. Ask the manager about exact policies and metering. [Elektroda, stachu_l, post #20339134]
Do shared gas boiler rooms give me the same control as an individual gas boiler?
No. A shared gas boiler room behaves like any central system, with building‑level scheduling. An individual apartment boiler lets you heat anytime and tailor indoor temperatures. When reading listings, verify whether “gas heating” means your own boiler or a shared one. Ask for system type and metering details up front to avoid surprises. [Elektroda, stachu_l, post #20339389]
What hidden costs should I expect with a gas boiler?
Plan for replacement if it fails. A broken or unrepairable unit can cost several thousand to replace. Budget for inspections and maintenance, too. Consider total cost of ownership over 10–15 years, not just monthly fuel. Ask the seller for service records and boiler age before committing. [Elektroda, 78db78, post #20339014]
Is boiler oversizing a problem in 45–50 m² flats?
Yes. Small flats often face limited boiler size options, which can mean an overpowered unit. Oversizing can force the boiler to run almost constantly and cycle inefficiently. Check the model’s minimum modulation and suitability for small loads. Ask for documentation and observe cycling behavior during a viewing. [Elektroda, 78db78, post #20339407]
Is district heating actually cheaper than gas today?
It can be, especially when supplied from coal‑fired CHP. “Municipal heating… should be significantly cheaper.” The trade‑off is control: you may get heating even on warm days. Verify current tariff tables and your building’s billing method. Prices can shift quickly with fuel markets and seasonality. [Elektroda, Zbigniew Rusek, post #20339116]
Will I pay for heating if I turn my radiators off?
It depends on metering and settlement. With an individual heat meter, you can close radiators and pay for what you use. Older riser systems may use radiator dividers or even area‑based settlement, which charge shared costs. Ask how your building bills heat and whether meters are installed. [Elektroda, stachu_l, post #20339134]
Should I avoid radiator heat dividers?
Yes. Prefer flats with apartment‑level heat meters. Heat meters settle actual consumption more fairly than radiator dividers. Dividers can misrepresent heat use in riser‑based systems. Confirm the metering method with the seller or manager before purchase. [Elektroda, slider2002, post #20349365]
Can I switch from a shared system to an individual gas boiler later?
It depends on the building’s layout and how many rooms the shared system feeds. Speak with neighbors and the manager about feasibility and rules. Conversions may be complex, so get clear answers on technical and administrative constraints first. [Elektroda, zdzichra, post #20342067]
How do I check if an advertised “gas heating” flat has an individual boiler?
  1. Ask the agent whether the gas boiler is exclusive to the apartment or shared.
  2. Request photos of the boiler and its location inside the flat.
  3. Confirm metering: individual gas meter and DHW heating vs building‑level plant. [Elektroda, stachu_l, post #20339389]
Do district‑heated buildings supply hot water year‑round?
Typically yes. Heating networks usually run all year, delivering domestic hot water during warm months. Central heating then activates based on building policy or temperature criteria. Ask which services your substation provides and how DHW is billed. [Elektroda, stachu_l, post #20339134]
What happens if the district network fails or the station pump stops?
With an individual gas boiler, you keep heating regardless of district outages. Network failures or substation pump issues affect central supply, not your in‑flat boiler. If uptime matters, individual gas offers resilience at the cost of ownership. Keep boiler maintenance current to preserve that resilience. [Elektroda, zdzichra, post #20338991]
Could substation leaks inflate my bill?
Yes, leaks on the central side can increase shared consumption. With your own gas boiler, you pay for what you use in the flat. Ask the manager about leak monitoring and recent repairs in district‑heated buildings. Review settlement rules to understand exposure to shared losses. [Elektroda, zdzichra, post #20339390]
