The display does not turn on after updating xiaomi redmi 3 s pro
jurasldz 4230 2
  • #1 16418395
    jurasldz
    Well, at night checking the time, it was about 1:30 everything was ok. In the morning the alarm clock rang on the phone, but the screen was off. The touch along with the sound and LEDs also work the buttons work. I turned on and off the phone but still the same. The phone also charges, but the charging battery does not show (when the phone is switched off). The phone computer detected (but as a portable device because I do not know how to enable usb debugging mode when the screen is off), I even answered the call, but the display still has no life. The phone is in perfect condition, without scratches and abrasions. Yesterday I downloaded the phone updates and I did not restart it (most likely it was set to restart the phone at 2 am but I won't cut my hand because I didn't change anything in the update settings). This is my problem
    I can't check my software number or other parameters because the screen does not turn on. Connecting the phone to the computer pops up as a Redims 3 portable device. (starting vol + power is also impossible because the screen does not turn on)
  • #2 16418518
    nutergsm
    Help: 1034
    Rate: 1665
    Probably the screen to be replaced.
  • #3 16442705
    jurasldz
    It turned out that some malicious software was installed that damaged the system ... That's what the guy from the site said, reinstalled the system, and the phone got up. Problem solved
