  • #1 16418464
    Ture11
    Help: 573
    Rate: 1130
    Hyde park is probably the most suitable for this topic.
    I have such an observation - Allegro has for a long time the "recently viewed" bar, which shows auctions that have been recently viewed by the user (also not logged in). The history of these views could never be deleted by deleting the history, cookies, etc. from the browser level. This, however, is not the topic of the post.
    Recently, I have noticed that in "recently viewed" there are items of household members (no one is logged in to Allegro on any computer), who do not have access to my computer, but use Allegro on their PC. The computers are on the same network and, after all, they run on a shared Internet IP. Of course, other household members can also see other people's browsing on their computers. There are no secrets here, but disgust from the user's point of view - there is.
    Do you have similar observations - that Allegro assigns browsing to a specific IP address and not to a computer? If that's true, then it's a serious setback on their part - but it wasn't like that before.
    Ps
    This happens regardless of the browser used.
  • #2 16419056
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, this situation has been going on for quite a long time.
    Is it legal?
    Difficult question.
  • #3 16420212
    Ture11
    Help: 573
    Rate: 1130
    It worries me very much. There is no problem if you are logged in all the time on Allegro - but this is not a solution.
  • #4 16420801
    ociz
    Help: 1379
    Rate: 3486
    You are probably wondering who of the household members was browsing the erotic section. ;)
  • #5 16422282
    Ture11
    Help: 573
    Rate: 1130
    Hah, no, probably users wouldn't do it, not all sections are visible :D
    Gentlemen, I have another shocking observation. At work, I have a computer with Internet access and I logged in on Allegro only once in my life (without remembering passwords, etc.) - somewhere around 2015. After dealing with the required matters, I logged out of the account and never logged in again (I am still logged out).
    Today, out of curiosity, I checked - and what? - I found on my PC at work (in "recently viewed") products that I was browsing the day before yesterday at home, being logged in to my Allegro account. This is apparently not even about IP ...
  • #6 16422555
    Grzegorz S.
    Help: 27
    Rate: 24
    I was interested in the topic, so I figured it out.
    This is in the cookies, but removing them from the browser (firefox for me) has no effect. I deleted the Allegro CCleanerem cookies and voila, there is no browsing history on the Allegro.
    But after logging in and logging out of Allegro, it is back.
  • #7 16422968
    Ture11
    Help: 573
    Rate: 1130
    For me, cleaning up from Firefox is effective, but that's not the point. After clearing cookies, you have to reconfigure Google's privacy policy, and this is already time-consuming.
    I found the AlleBlock add-on for Adblock - it works, completely removes all ads from Allegro, so there are no graphics on the home page :D I like it - but it's still not a solution. In fact, the only solution would be for Allegro to stop such practices - but they probably have some $$$ ...
  • #8 16423214
    rb401
    Help: 750
    Rate: 984
    Generally, the case is that a person wastes a lot of life confirming naive messages of cookie acceptance, and this is just a part of places where it is possible to throw up potentially spy throws.
    Allegro, apart from cookies, places at least cards (that's what I can see at the moment) in two other, less well-known places. It is true that I did not specifically track the one responsible for "recently viewed", but maybe someone else will. My situation is a bit complicated with anti-advertising additions, so that in my case, those recently viewed behave strangely.
    From "bare" Firefox it is possible to get to two such potential places and selectively delete these various foundlings. It is enough to press F12 while on the Allegro website and select Storage on the panel that appears. By clicking on the left side, we have an entry to Allegro cookies, which we can selectively delete, but also access to the normally invisible "Local Storage" in which, for example, Allegro stores, among others shopping cart data.
    If after F12 on the panel beam there is no "Storage" option (or a similar one, because I am using English FF), then running this option is the gear to the right of the beam and tagging this tool in the first column.
    The second place where Allegro obviously stores some of its data is Flash Player, or more precisely, its settings.
    To crash it, you just need to go to Documents and Settings in your profile, and from Application Data \ Macromedia \ Flash Player to delete folders. All or more selectively.
    Ooooh ..
    And don't you have a service enabled on these computers, e.g. synchronization of loads, etc., settings? Some Sync or something.
    Then the matter would be more rational.
  • #9 16423249
    Ture11
    Help: 573
    Rate: 1130
    rb401 wrote:
    Ooooh ..
    None of this, I avoid any integration with the browser, especially at work.
  • #10 16423327
    rb401
    Help: 750
    Rate: 984
    If we reject the spell as an explanation, it is evident here that the fact of logging in in 2015. left a permanent mark on this computer that Allegro was now able to read and find out that it was you.
    Looking at Allegro cookies, you can see that some of them have a life span of up to 100 years. And if not cookies, then Local Storage, which is probably indefinite. So here is a rational explanation.
    Now I have another question for you. Have you ever logged into Allegro on those computers where you have recently viewed leaks?
    In general, it is the policy of this fierce remembrance about Allegro users that certainly makes a lot of practical sense for Allegro (e.g. targeting fraudsters). And maybe the problem you are talking about is just a side effect of this policy.
  • #11 16424996
    Ture11
    Help: 573
    Rate: 1130
    Yes, the problem is that not only me - e.g. my father logged into his computer, mother's computer and my computer - and as a result I can see the history from my mother's + father's computers.
  • Allegro device tracking links shared viewing histories
    #12 16425181
    rb401
    Help: 750
    Rate: 984
    So you can see here that Allegro "marks" each computer so that their system knows everyone logged in to it. Although it is rational, revealing it by connecting it to the story is, in my opinion, an obvious blunder of programmers.
    So I think the best thing in this situation is to report it to Allegro as soon as possible using the form on the website.
    They even read it and reply pretty quickly. The more so as it actually concerns their security mechanisms. And here they inadvertently reveal themselves and give the fraudsters a test platform for free.
    From my experience, I will add a hint that it is better to avoid digressions in the Allegro application and to report the problem strictly.
    Some time ago I reported when the option that was important to me disappeared and I wanted to be courteous and wrote in the form "everything is ok just ...".
    I got a response dripping with narcissism about how happy they are that I am happy with them etc. And at the end, it was only incidentally added that there is no option and there will be no option, because few people used it :-o .
    And by the way, you can try to selectively remove these allegral foundlings from your computers, e.g. using the F12 method, as I wrote above.
The discussion revolves around Allegro's "recently viewed" feature, which retains browsing history linked to a user's IP address rather than individual computers. Users express concern over privacy, noting that even when logged out, browsing history from other household members appears. Some participants suggest that this issue may stem from cookies or local storage, which can retain data even after clearing browser history. A user recounts finding their browsing history on a work computer despite never logging in again since 2015. The conversation highlights the need for Allegro to address these privacy concerns, with suggestions to report the issue directly to the platform for resolution.
