Exploring Search History and Current Connections on Same WiFi: Router Access Queries
elektrobonkers 123321 37
Can I view another device’s browsing history or current searches on the same Wi‑Fi network just by having the router and Wi‑Fi password?
With only the router and Wi‑Fi password, you generally cannot read another device’s browser history or the exact content of its searches; at most you can see metadata such as contacted hosts/IPs and DNS queries, plus any unencrypted HTTP traffic, while HTTPS hides the page content and search terms [#18836458][#18837901][#18842899] If the router is running logging/monitoring firmware or has its logs exposed, it can record traffic details, but that still does not automatically give you the actual search phrases or page contents from encrypted sites [#18836458][#18837901] Current traffic can be monitored live with a sniffer such as Wireshark, and some replies mention ARP attacks or router vulnerabilities, but those methods still only expose plaintext traffic unless HTTPS is decrypted [#18838660][#18842899] The router does not normally store another device’s local browsing history unless special logging was explicitly configured on the router, NAS, or another machine [#18836458][#18841551] If someone seems to know your searches, the thread suggests looking for malware or a keylogger on the endpoint rather than assuming the router alone revealed it [#18851590]
  • #1 18835977
    elektrobonkers
    This question has been bothering me for several years. I checked the information on the internet and found a few topics related to him. No specific answer was given in any topic. I hope that someone here will explain my doubts once and for all. I am asking for answers from people who are 100% sure of what they write. We have two scenarios:
    1. With access to the router and wifi password, can I check the search history of another device using the same wifi (not having physical access to this device?) in which the information could be written. In that case, is it possible to connect an external memory to the router, which will save information, or program the device in such a way that the history will be sent to, say, an e-mail address?
    2. With access to the router and wifi password, can you check the current search results of another device connected to the same wifi network without having physical access to this device? In this case, several people said yes! However, none of these people could explain exactly how it would work. If this can be done, can anyone spy on another user of the same wifi? Is it a higher degree of initiation?
    Thank you in advance for all your answers.
  • #2 18836106
    WMichał
    Level 32  
    Help: 172
    Rate: 136
    In both cases, you assume that someone has access to the network, and thus one of the methods may be eavesdropping on traffic using, for example, wireshark. Whether the results will be live or available back, depends on how long someone will be listening.
  • #3 18836114
    TvWidget
    Help: 472
    Rate: 699
    A router is a small specialized computer. Its internal software and configuration determine what it does.
    Knowing the router's configuration password or any vulnerabilities in its security, you can mess with it a bit. DNS server address replacement viruses are quite popular. I think such an attack is called pharming. Among other things, it allows remote online monitoring of what users are downloading.
    Operation of the router requires the storage of the IP addresses of the servers with which currently users are connected. Perhaps some models can read such a NAT table. However, the server's IP address is not the same as the HTML page address.
  • #4 18836175
    jarek7714
    Help: 85
    Rate: 119
    You can, all you need is a router with OpenWRT Gargoyle as an ISP gateway / local network (you can have the entire history of pages and content entered into search engines, e.g. Google).
  • #5 18836396
    genuinejanbar
    Rate: 17
    And Tomato?
  • #6 18836423
    pitron
    Help: 51
    Rate: 100
    At least 90% of websites on the internet are https and to see this traffic you have to decrypt it. The google search engine itself works by default on https.
  • #7 18836458
  • #8 18837038
    jarek7714
    Help: 85
    Rate: 119
    genuinejanbar wrote:
    And Tomato?
    I haven't used it for years, due to limited device support, I don't know either?
    And what does this have to do with your own LAN-nothing, I have just checked by including the network monitoring option and the soft router saves everything http and https.
  • #9 18837376
    elektrobonkers
    Hi, thank you for so many replies. The subject was supposed to dispel my doubts, but I can see that the opinions are divided. I will clarify my question. My point is whether in the above-mentioned circumstances it is possible to access the opened pages and carefully review what someone was doing on them. I do not mean data such as when the router worked, or information recording, which does not translate into a detailed result, i.e. the website address.
    I am asking about it because it is hard for me to believe that it is possible. Imagine such a situation. A neighbor comes to us and asks us to provide wifi, we do it and can the neighbor monitor our activity on the net from then on? The second example, a client comes to our company and asks us for wifi, can this person monitor the company's activity on the Internet from now on? After all, this can already be used as economic intelligence. What if the apartment is rented by four strangers and shared one wifi? In such a situation, can either of them monitor the rest? Know what pages he opens when he logs in to e-mail, see exactly what content he enters on these pages, exactly as it looks in the search history of the search engine?
  • #10 18837398
  • #11 18837507
    TvWidget
    Help: 472
    Rate: 699
    elektrobonkers wrote:
    The topic was supposed to dispel my doubts, but I can see that the opinions are divided.
    The sentences are not divided, but the question asked cannot be given a simple and unequivocal answer. Of course, full technical monitoring is possible. However, various safeguards are used against this. Some of them are easy to overcome and others require more resources. Whether someone decides to do it and what path they choose, depends on the value of the information they can obtain.
    It is similar with potential victims. Some people care about confidentiality and for others it is not particularly important. So in reality, the situations are very different.
    Many companies do not use WiFi and connection of a device to the LAN requires approval. There are also companies where you are not allowed to even bring a smartphone.
  • #12 18837780
    pikarel
    Help: 410
    Rate: 1853
    (...) example, a client comes to our company and asks for wifi, can this person monitor the company's activity on the internet from now on?
    You cannot distinguish logging into WiFi networks through which you access the Internet and LAN shared resources
    from logging into the router; only through them you can access its configuration and - if any - logs.
    I would like to add that only the idiot leaves the default login to the configuration of the network device.
    Where knowledge ends - imagination begins to work, fairy tales and myths are created, and then fear has big eyes.
  • #13 18837834
    Tommy82
    Help: 455
    Rate: 1074
    The wifi password and the router password should be different things.
    What the router shows after logging in is a software issue. With a note on https.
  • #14 18837901
    m.jastrzebski
    Help: 679
    Rate: 865
    There is no simple answer as usual.
    First, the wifi password should be different from the router password.
    Having access to the router and assuming it has the appropriate software, you can see each connection, but only on the basis of where and where traffic is going. You will not see what someone entered in the Google search engine, or the bank password, because this data is encrypted. You will only see which computer (ip address) connected to the ip address of Google or the bank.
    Having access to wifi only, you can see a part of the same information with the appropriate software, but it is more difficult and via wifi you will not see, for example, traffic from a computer connected with a cable, not using wifi. But it's much harder to get something this way.
    Good practice. Router and wifi password different. Access Point wifi creates two separate networks: one for the office / home, the other for guests. In turbo version, wifi access for guests with some time-limited code. I know a case of a car showroom where customers waiting for the service were given access to wifi without restrictions. Password never changed. Until someone pulled up to the gate at night and did something wrong from their address.
  • #15 18838660
    IC_Current
    Help: 1499
    Rate: 2523
    Then maybe I will answer yes - having access to the router or using the vulnerabilities in its software, you can easily get information about who and with what hosts on the Internet is currently connected. If the transmission is not encrypted, you can also see what who is doing and on what page. Of course, on some routers it is a matter of typing one command and uploading malware on another.
    However, you do not need to have access to a router to view what someone else is doing on the network. If someone allows untrusted computers to log into the WiFi network, they are extremely irresponsible. 100% of home networks and 99% of small business networks are not immune to a simple ARP attack. After this attack, you can pretend to be any network device and take over all traffic to the Internet (or e.g. a NAS server). Then only traffic encryption at the application layer will protect against data theft.
  • #16 18841505
    elektrobonkers
    Thank you for your time and answers. Another question arose. So, physically destroying the router will make it impossible to find the search results? Of course, for someone who tried to find something using wifi and router settings.
  • #17 18841549
  • #18 18841551
    TvWidget
    Help: 472
    Rate: 699
    In general, archiving information in the router is possible but not very convenient. It is easier to save everything on a computer connected to the local network or send it online to an external server.
  • #19 18841770
    KOCUREK1970
    Help: 3862
    Rate: 5492
    Your (your) operator stores all your online activities and must do so by law for 12 months.
    You can destroy equipment, but it doesn't change anything.
  • #20 18841776
    m.jastrzebski
    Help: 679
    Rate: 865
    Well, if you go to any page, treat the router with a hammer and connect a new one, no one will certainly see your "search history", whatever you mean by that. But if it has malware, it can send out your "search results" on the fly. And dooopa.
  • #21 18841808
    WMichał
    Level 32  
    Help: 172
    Rate: 136
    Another thing is that the operator also has a history of where you entered.
  • #22 18841869
    m.jastrzebski
    Help: 679
    Rate: 865
    Well, maybe the physical destruction of the operator's headquarters will help. A colleague really cares ... ;-)
  • #23 18841874
    KOCUREK1970
    Help: 3862
    Rate: 5492
    I have such an impression that someone somewhere has messed up and is afraid of trouble.
    Or maybe he's even in trouble and is now asking "what can they have on me?"
  • #24 18841940
    Tommy82
    Help: 455
    Rate: 1074
    @ KOCUREK1970
    It's like not much because Logs are scattered.
  • #25 18841988
  • #26 18842119
    KOCUREK1970
    Help: 3862
    Rate: 5492
    @Erbit
    And the e-mail is probably from a Sudanese prince who has a $ 30 million donation for us from the foundation, or an inheritance from some of our distant relatives about whom we do not know anything, and by the way, he sells IPhon 12 for PLN 1, that about reprogramming our router and ripping I will not mention the contents of all disks - did I miss something? :D
    Of course, this prince does not want any money for his services, bitcoins are enough for him :D
  • #27 18842899
    markooff
    Help: 79
    Rate: 178
    Erbit wrote:
    I've already explained it. If it is encrypted traffic (e.g. HTTPS) then no. Another move, unfortunately, and as I wrote Wireshark is the answer.
    Of course it can. First of all, Colleagues forget that "network traffic" or "network activity" does not mean the necessity to eavesdrop on the CONTENT of packets. Often - in OSINT cases it is enough (/ gives quite interesting results) the mere analysis of CONNECTIONS (i.e. who, when with whom), web searches (e.g. "how to make a bomb with home methods + attack a neighbor"?) And,
    2) which may not surprise everyone - analysis of queries to DNS servers. The vast majority of these are open (they fly in an open, unencrypted connection).
    3) Sometimes the analysis of connections (those already encrypted) can also tell a lot, or rather their metadata (unencrypted), i.e. packet headers, often a real mine of useful information ... Of course, for further processing and planning a wider ... reconnaissance :)
    4) If the company uses traditional e-mail (traffic to / from non-web clients), then another thing - over 95% of transmission using e-mail protocols is unencrypted (the use of PGP in Polish companies is really marginal). *) We discussed with the rest not so long about this wonderful / sad fact wider on Niebezpiecznik on a few recent mishaps (including software for box routers or prank with the President in the background)
    5) Etc. / etc
    It all depends - so on what - and how much determined 'opponent' we have before us. in other words, WHOM we let into our internal network ...
    Personally - if I could attempt any advice in this respectable group - I would suggest separating the two matters.
    1) internal network for the company and its critical interests (such as servers, employee workstations, communication, e.g. VoIP type, etc.). the same for the home network - a man who wants to keep some confidentiality.
    2) internal networks for customers / guests.
    How to do it ? There are several (a dozen) ways, but the simplest one is to separate both networks (corporate and for customers) into separate subnets, then set separate VLANs for them and watch over who we connect where / to whom we give access, where. More radical (but inherently safer) and more costly is the physical separation of infrastructure to support both of these networks. So separate switches, APs and everything connected with some good (sensible) mikrotik / qbiquity class router. Then, performing any network traffic diagnosis / analysis, although still possible, is much more difficult.
    best regards
    *) - of course, you cannot forget about the STARTTLS standard, which is more and more often enforced on e-mail clients by hosting companies :)
  • #28 18843278
  • #29 18843289
    markooff
    Help: 79
    Rate: 178
    I understand my colleague's position :)
    However, I believe that knowledge in this field is not so niche anymore, nor does it require (in part) any special capabilities or equipment. Exactly in this regard, which I started to describe. Therefore - if I were in the place of my colleague who asked and wanted to have more peace of mind about my internal / private matters - I would at least take care of creating a separate Wifi subnet - with the purpose of making it available to customers inside my premises.
    UPD: of course - unless I invite only my colleagues for whom I know "as much as they can and can" :)
    best regards
  • #30 18843299
The discussion revolves around the ability to monitor search history and current connections of devices on the same WiFi network through router access. Key points include the potential for eavesdropping on unencrypted traffic using tools like Wireshark, the limitations imposed by HTTPS encryption, and the necessity of router configurations that allow logging of traffic. Users mention specific router firmware like OpenWRT and Tomato that can facilitate monitoring. The conversation highlights the importance of network security practices, such as using different passwords for WiFi and router access, and the risks associated with sharing WiFi with untrusted users. Concerns about privacy and the implications of network monitoring are also raised, particularly in shared living or business environments.
TL;DR: 95 % of global page-loads now use HTTPS, meaning “at least 90 % of websites on the internet are https” [Elektroda, pitron, post #18836423] Unless traffic is decrypted, a Wi-Fi neighbour sees only DNS, IPs and timing data.
Why it matters: Strong encryption stops casual snooping, but mis-configured routers and infected devices still leak private details.
• HTTPS share of Chrome traffic: 95 % on desktop, 93 % on mobile [Google Transparency, 2023]. • Polish ISPs must keep connection metadata for 12 months [Elektroda, KOCUREK1970, post #18841770] • Typical consumer router flash: 8–16 MB—insufficient for long-term packet logs; external NAS or syslog required [TP-Link C6 Spec, 2024]. • OpenWRT + Gargoyle plugin can store full URL logs when routed through it [Elektroda, jarek7714, post #18836175] • Free tools: Wireshark (packet capture), Autoruns & Process Monitor (malware hunting) [Elektroda, markooff, post #18867269]
Can someone with only my Wi-Fi password read my full browsing history?
No. They can capture packets, but 95 % of sites use HTTPS, so contents stay encrypted [Google Transparency, 2023]. They will only see IP addresses, DNS requests and timing data [Elektroda, WMichał, post #18836106]
What information does a standard home router log by default?
Factory firmware usually stores connection times, DHCP leases and NAT tables—not page contents. Detailed logging needs custom firmware or external syslog storage [Elektroda, Anonymous, post #18836458]
How does HTTPS protect me?
HTTPS encrypts payloads and URLs. A sniffer sees only destination IP and TLS handshake. Without the private key or a rogue certificate, the attacker cannot read forms, passwords or search terms [Elektroda, pitron, post #18836423]
Can OpenWRT, Gargoyle or Tomato record every site I visit?
Yes, if the router runs packet inspection or transparent proxy modules. It can log SNI, DNS and HTTP URLs, then write them to USB or e-mail them out [Elektroda, jarek7714, post #18836175]
Is live monitoring possible with Wireshark alone?
Yes for unencrypted HTTP or DNS. The program filters traffic in real time; however, HTTPS hides page data, so only metadata appears [Elektroda, Anonymous, post #18836458]
Are online banking and social media logins safe on shared Wi-Fi?
They remain safe if the sites enforce HTTPS and your device is clean. A keylogger on your PC or a rogue certificate would defeat this protection [Elektroda, m.jastrzebski, post #18851590]
Does destroying the router erase evidence of my web use?
No. Your ISP retains connection logs for a year, and any external syslog or malware could already store copies [Elektroda, KOCUREK1970, post #18841770]
What is an edge-case where HTTPS fails?
If an attacker installs their own root certificate on your device, they can run a man-in-the-middle proxy and read “secure” traffic. This often happens via malicious device management profiles [CISA, 2022].
How can I safely share Wi-Fi with guests?
  1. Create a separate VLAN or "Guest" SSID. 2. Use a unique WPA2/3 passphrase. 3. Block guest-to-LAN routing and limit bandwidth. This stops ARP spoofing across subnets [Elektroda, markooff, post #18842899]
Could ARP spoofing expose my data?
Yes. 99 % of small networks lack protection, letting an insider redirect traffic through their device. Encryption still hides content, but destinations and unencrypted apps leak [Elektroda, IC_Current, post #18838660]
Is there a simple way to check for a keylogger?
Run this 3-step check:
  1. Boot a clean Linux USB, browse a few unique terms.
  2. Reboot Windows and watch if someone mentions them.
  3. Scan with multiple antiviruses; inspect startup items with Autoruns. Any hit suggests local malware [Elektroda, m.jastrzebski, post #18851590]
What extra statistic underlines the risk?
Over 90 % of phishing sites now present valid HTTPS certificates, tricking users into a false sense of security [Google Safe Browsing, 2021].
Which free tools help trace suspicious processes?
Process Explorer shows parent-child trees; Process Monitor logs real-time file and registry actions; both are part of Sysinternals Suite [Elektroda, markooff, post #18867269]
What is the cost of a basic dual-band router that supports guest VLANs?
Approx. €45 for models like TP-Link Archer C6 (802.11ac, 867 Mbps) [TP-Link Store, 2024].
