Discovering Wi-Fi User Activity: Can You Access Someone's History?
Sajani 45149 18
Can I view the websites visited by someone using my Wi‑Fi connection?
Not with the stock D-Link firmware: the router’s normal log usually won’t show a user’s browsing history or the exact pages visited [#10579901][#10583465] If your router is a supported version (A1 or B1), you can try DD-WRT, which can provide outgoing/incoming logs and, in some setups, URL-level logging [#10583465][#10583942] DD-WRT can also be configured to send logs by email at intervals so they are saved before being overwritten [#10583942] On the original software, there is no such functionality, so the log will not tell you what websites someone opened from their phone [#10583465][#10579901] If your goal is simply to stop unwanted use of the connection, change the Wi‑Fi password [#10583680]
  • #1 10579199
    Sajani
    Rate: 18
    I have a problem, is it possible to access the history of someone who uses my internet via wifi? I would like to see what exactly the user was doing.
  • #2 10579336
    VooVoo
    Help: 215
    Rate: 266
    If you have login on your router enabled, you can check it. You will know what IP ports he was running from, so you will find out what he was using.
  • #3 10579546
    Sajani
    Rate: 18
    How to turn it on? I'm green please help!
  • #4 10579591
    VooVoo
    Help: 215
    Rate: 266
    It may be different for each router. In my: Administration-> Reporting-> Log -> check Enable ;)
  • #5 10579662
    Sajani
    Rate: 18
    I have d-link 300 and I really can't find this option and I don't know how it should work ....
    does this also apply to the person connecting through my router from their phone?
  • Home router logs rarely reveal complete connection details
    #6 10579735
    salmon
    Help: 435
    Rate: 262
    And you turned it on and watched what is contained in such a log? Because something seems to me that you went a bit into fairy-tale writing ;) Yes, it usually contains a record of operations performed at router startup, received / allocated dhcp leases, firewall alerts, but rather there is no record of exactly every connection as for IP, port, etc. simple, home device ... Besides, what would your friend get from the log of ip's and ports? This does not clearly define the content of the package - you can only guess ...
  • #7 10579761
    Sajani
    Rate: 18
    Well, if your patience does not run out, I would be very grateful for some tips for blondes. I have a d-link 300 router. I would like to know, if possible, which websites someone has accessed from their phone. Is there any program or settings on my administration panel? Thanks a lot in advance :)
  • Router logs usually lack browsing history
    #8 10579901
    salmon
    Help: 435
    Rate: 262
    At 99.9%, there will be no such information in the router's log. You can try - in the top menu "Maintenance", on the left "log settings", in "log type" enable all possible options, save, accept changes, generate some traffic (e.g. go to different sides) and then use the "Save log" button file to local hard drive "save the log to your computer's disk and view it. After the experiment, set the "log type" to the same configuration as before, let the router not get unnecessarily tired :) .
  • #9 10579915
    Sajani
    Rate: 18
    Earlier, I accidentally found here a topic that there are programs that allow you to save the history of users, but I missed it somewhere. The log saved by the admin panel does not tell me much ... :( No useful information.
  • Router logs expose UPnP port mappings, not packet contents
    #10 10579967
    VooVoo
    Help: 215
    Rate: 266
    Not really - in the belkin router the log contained a local IP and the port number it was on, now I turned on logging on my router, and I will boast of the logs tomorrow :)
    EDIT: A few lines from the linksys router logs:
    Wed, 2012-02-22 06:58:52 - Upnp Log: UPNP ACTION: adding port mapping IntIP 192.168.1.13 IntPort 42930 ExtIP xxx.xxx.xxx.108 ExtPort 42930 Proto TCP
    Wed, 2012-02-22 07:22:46 - Upnp Log: UPNP ACTION: deleting port mapping IntIP 192.168.1.12 IntPort 49090 ExtIP xxx.xxx.xxx.108 ExtPort 49090 Proto UDP
    Wed, 2012-02-22 07:22:46 - Upnp Log: UPNP ACTION: deleting port mapping IntIP 192.168.1.12 IntPort 49090 ExtIP xxx.xxx.xxx.108 ExtPort 49090 Proto TCP
    Wed, 2012-02-22 07:22:47 - Upnp Log: UPNP ACTION: adding port mapping IntIP 192.168.1.12 IntPort 49090 ExtIP xxx.xxx.xxx.108 ExtPort 49090 Proto UDP
  • #11 10580868
    salmon
    Help: 435
    Rate: 262
    How would I tell you this - this is not traffic logging, but the operation of the UPnP module - automatically adding / removing port forwarding to a specific host in the local network. The client of this service is "sewn" in, for example, in Skype, uTorrent, etc.
  • Clarifying browsing activity versus torrent traffic
    #12 10582726
    VooVoo
    Help: 215
    Rate: 266
    I guess that's what the author of the topic meant - I got the impression that someone was browsing a lot on the web and the question was whether he was browsing the pages or cluttering the link, e.g. with torrents :)
    Edit: I rather meant this entry:
  • Port configuration and UPnP cannot reveal exact browsing activity
    #13 10582775
    salmon
    Help: 435
    Rate: 262
    Sajani wrote:
    if possible, know which websites someone has accessed from their phone.
    I guess it wasn't really that :) and taking into account the fact that the configuration of the port itself does not say much and that only a small percentage of applications have the need and possibility of using UPnP, it misses the concept stated in the first post "see what exactly it did" ...
  • #14 10583280
    Sajani
    Rate: 18
    So what, there is no such possibility? I tried to install tomato but I don't know why I can't do it ....
  • #16 10583680
    piterus99
    Help: 1084
    Rate: 328
    I do not recommend using any non-original software - loss of warranty, possible problems that you cannot deal with - why do you add problems? And anyway, you can't save logs in the router - there is simply no place for it.
    If you have the impression that someone is using your connection, change the network access password (not to the router) and that's it.
  • DD-WRT support and warranty exchange experience
    #17 10583721
  • #18 10583860
    salmon
    Help: 435
    Rate: 262
    jurek.adam wrote:
    Without exaggeration, DD-WRT can be uploaded to this router.
    You can, but what for? What will it bring to the topic discussed in this thread? Few. The log will cover a small - current - scope, and certainly not the historical one, as I understand it by the author ...
  • DD-WRT can email logs with URLs before overwrite
    #19 10583942
Accessing the browsing history of users connected to your Wi-Fi network is generally not straightforward. While some routers allow logging of IP addresses and ports, this information does not provide detailed browsing history. Users are advised to enable logging through their router's administration panel, but the specifics vary by router model. For example, D-Link routers may not have comprehensive logging capabilities. Some participants suggested using third-party firmware like DD-WRT for enhanced logging features, although this may void warranties and is not compatible with all hardware. Ultimately, the consensus is that detailed user activity tracking is limited, and changing the Wi-Fi password is a recommended security measure if unauthorized access is suspected.
