TP-LINK TD-W9970/W8968 Router: Can Hackers View Browsing History After Hacking & Trojan Virus?
Zuzannna001 68718 14
Can a hacked TP-LINK TD-W9970/W8968 router be used to see browsing history from devices connected to it?
No, these home routers do not store browsing history, so a hacker who gets into the router cannot later read a list of visited pages from it [#17605754][#17607164] They only keep temporary information about current connections in the NAT table so packets can be routed correctly [#17605754] You can monitor traffic while it is happening, but if you want to view it later you would have had to log or record it somewhere else [#17607164] Restoring factory settings or turning the router off does not reveal past browsing because yesterday’s connections are already gone [#17608136] One reply notes that the ISP may retain some connection-related data for up to 12 months, but that is separate from router history [#17607626]
  • #1 17603217
    Zuzannna001
    Rate: 15
    I have a router TP-LINK TD-W9970 or W8968 and I wonder if in the event of hacking and Trojan virus hacker can view on it the history of browsing websites from devices connected to this router. Do they have this option? Thank you in advance for your response.
  • #2 17603324
    IC_Current
    Help: 1499
    Rate: 2523
    Of course, you can track the transmission remotely on each router. Even Zuziu has ways where you don't need a router to preview what other people are browsing the web on.
  • #3 17603569
    Zuzannna001
    Rate: 15
    Thank you for your response
  • #4 17605750
    Zuzannna001
    Rate: 15
    I have one more question, is there a way to permanently delete browser history from devices connected to the router? In the sense of resetting the memory of pages viewed in the router?
    dt1
    Admin of Computers group
    Help: 7318
    Rate: 8296
    The router itself does not store the history of pages visited. At least not these models. At any given moment, the router has only entries of current connections in its memory (NAT table - it must know which computer in the local network packets with the answer should be sent to), which is rather so.
  • #6 17606871
    Zuzannna001
    Rate: 15
    So if I restore the device to factory settings, these connections will be visible on the router, or will it also be deleted?
    jprzedworski
    Help: 758
    Rate: 828
    Zuzannna001 wrote:
    will these connections be visible on the router?
    Home routers do not store any connection history! Whether you restore the factory settings or not, it cannot be read after some time, because they do not have such memory. It would have to be HDD or SSD.
    You can track but during work. In order to view it later, you would have to write it down somewhere.
    przeqpiciel
    Help: 285
    Rate: 238
    I do not know who you want to hide the history of visited pages from, but ... probably 99% of the Internet service provider is obliged to store visited pages for a period of 12 months.
    m.jastrzebski
    Help: 679
    Rate: 865
    Just turn it off from the socket. The information about currently ongoing calls. Because information about yesterday's connections is no longer there.
  • #10 17608252
    jprzedworski
    Help: 758
    Rate: 828
    There were 24, but probably reduced to 12. And not only the history of visited pages, but many other data - logins, locations, IP addresses, etc.
  • #11 17608256
    przeqpiciel
    Help: 285
    Rate: 238
    It should be added that the data for the needs of the services, not that the parent will control the child.
  • #12 17608725
    m.jastrzebski
    Help: 679
    Rate: 865
    Do not log the history of visited pages, and certainly not logins, because and how?
    Roughly: source and destination IP, ports, and time.
    The data is stored for 12 months and no more.
    "Article 180c. 1. The obligation referred to in Article 180a (1) shall cover data necessary for:
    1) determining the termination of the network, telecommunications terminal equipment, end user:
    a) initiating the connection,
    b) to which the connection is directed;
    2) terms:
    a) date and time of the connection and its duration,
    b) type of connection,
    c) the location of the telecommunications terminal equipment. "
  • #13 17608912
    jprzedworski
    Help: 758
    Rate: 828
    I exaggerated with these logins. But what harm to scare. ;-)
    But visited pages are logged in since:
    m.jastrzebski wrote:
    Art. 180c. 1. The obligation referred to in art. 180a paragraph 1, the data necessary to determine: ..... b) are covered to which the connection is directed
    Technically very simple. For example, Barracuda Web Security Gateway has a standard login for all website entries. In the form of a URL. And this product is available to all administrators, so even more so for ISPs. There are many such products. Another thing is whether the ISP has the ability to collect so much data - it probably goes into petabytes in their case.
  • ISPs log destination IP and port only
    #14 17608918
    m.jastrzebski
    Help: 679
    Rate: 865
    Only that no ISP will do what it doesn't have to do, whether it is simple or difficult. Log in IP and port and that's it. Do you pay more taxes than you need?
  • Destination IP and port can reveal browsing history
    #15 17609087
    jprzedworski
    Help: 758
    Rate: 828
    The destination web server's IP is also information where the client looked. Maybe without details, but often enough.
    In addition, the term "to which the connection is directed" is vague and can be interpreted differently. I am not a lawyer or an ISP, but there has been a long-standing discussion about what to collect. The customer has the right to even different complaints. Here is an article by GIODO, so a very official body, 6 years ago, and there is explicit reference to recording the history of browsed pages. So I didn't think of it. https://www.giodo.gov.pl/pl/1520001/4552
    This is about plans for regulations (written in 2012). What is the matter with it now, I do not know.
    However, I think there is nothing to discuss about it because we leave the topic framework. We will not turn back by the Wisła stick. Regards and disappear.
The discussion centers on the TP-LINK TD-W9970 and W8968 routers, specifically regarding the potential for hackers to access browsing history after a hacking incident or Trojan virus infection. Responses indicate that these routers do not store browsing history; they only maintain current connection entries in their NAT table. Even after factory resets, no historical data is retrievable. However, Internet Service Providers (ISPs) are required to retain certain connection data for up to 12 months, which may include IP addresses and connection times, but not specific browsing history. Users are advised that while ongoing connections can be monitored, past data cannot be accessed from the router itself.
TL;DR: On TP-LINK TD-W9970/W8968, 0 days of browsing history are stored; “Home routers do not store any connection history!” Attackers can only monitor live traffic unless they log it. For TD‑W9970/W8968 owners asking if hackers can view history. [Elektroda, jprzedworski, post #17607164]
Why it matters: It clarifies what your router and ISP can actually record, and how to remove any local traces.
Can hackers see my past browsing history on a TP-LINK TD-W9970/W8968 after hacking it?
No. These home routers do not keep historical browsing logs. An attacker could only inspect live connections and would need to log them to view later. “Home routers do not store any connection history!” That means there is no past history to steal from the device. [Elektroda, jprzedworski, post #17607164]
Does a TP-LINK TD-W9970 or W8968 store browsing history of connected devices?
No. The router maintains only a current NAT table to map responses back to devices. It does not retain a list of visited pages or old sessions. Once connections end, those entries are gone. There is no built-in browsing-history archive. [Elektroda, dt1, post #17605754]
If I factory-reset the router, will any connection history remain?
There is no historical browsing data to begin with. Powering off clears current session information. A factory reset changes settings, not stored browsing logs, because none exist on these home devices. Yesterday’s connections are not present. [Elektroda, m.jastrzebski, post #17608136]
Will my ISP still have records even if I reset my router?
Yes. ISPs keep connection metadata like source IP, destination IP, ports, and timestamps for about 12 months. Router resets do not affect ISP-side retention. This metadata is separate from anything on your router. [Elektroda, m.jastrzebski, post #17608725]
Do ISPs store the full list of URLs I visited?
They log connection metadata, such as IPs, ports, and time. The cited statute references endpoints and timing, not full URL paths. “The data is stored for 12 months and no more.” ISPs aim to meet legal obligations with minimal data. [Elektroda, m.jastrzebski, post #17608725]
Can a compromised router monitor my future browsing in real time?
Yes, during operation it can observe live traffic paths. To review later, the data must be written to storage using logging or packet capture. “You can track but during work.” Without logging, there is no retrospective history. [Elektroda, jprzedworski, post #17607164]
Could someone see what I browse without using the routers interface?
Yes. As one expert notes, you don’t even need router access to preview what others are browsing. External monitoring techniques exist outside the router. “You don't need a router to preview what other people are browsing.” [Elektroda, IC_Current, post #17603324]
How do I clear any connection traces on the TD-W9970/W8968?
Use a quick power cycle. 1. Turn the router off at the socket. 2. Wait 10–30 seconds. 3. Power it back on. This clears only current session data, as there is no historical browsing log to erase. [Elektroda, m.jastrzebski, post #17608136]
What exactly sits in the router19s NAT table?
Active session mappings. It links a device on your LAN to an external server so replies return correctly. It tracks current connections only. Once sessions end or the device reboots, those entries are gone. It is not a browsing-history list. [Elektroda, dt1, post #17605754]
Can the destination server19s IP reveal which site I visited?
Often yes. The destination web server IP can indicate the site reached, even without a full URL. This is part of the metadata ISPs may retain. It still won’t include the exact page path. [Elektroda, jprzedworski, post #17609087]
Do home routers ever store browsing history as a feature?
Not without storage or explicit logging. “It would have to be HDD or SSD.” Home models like the TD-W9970/W8968 lack such storage and do not archive visited pages by default. Logging requires writing data somewhere persistent. [Elektroda, jprzedworski, post #17607164]
If a Trojan infects my device, can it expose my browsing regardless of the router?
Yes. Monitoring can occur off-router, including on compromised devices, as experts note you don’t need router access to preview activity. Securing endpoints is as important as securing the router itself. [Elektroda, IC_Current, post #17603324]
