What questions can be expected in the SEP E1 up to 1kV exam without a range of m
Dzonzi 34098 25
What topics and practical questions should I prepare for when taking the Polish SEP E1 qualification exam for electrical equipment up to 1 kV?
Expect more than basic shock protection, RCDs, conductor sizing, and current effects: examiners may also ask about first aid, safe voltages and their dependence on resistance, series/parallel resistance formulas, networks, conductor colours, basic protections, switchboards, and the difference between a BM fuse and an ordinary fuse [#16420300] [#16426673] [#16427878] Questions may extend to asynchronous and synchronous motors, motor starting and speed control, starting-current limitation, overhead-pole types, underground cable installation, sand layers, and work restrictions [#16424686] Be prepared for questions about the composition and procedures of renovation teams, supervision and operation permissions, and related legal matters [#16424686] [#16430107] The scope and difficulty vary substantially by examination committee, applicant experience, and the exact operation, maintenance, assembly, renovation, or measurement scope requested [#16430107] The thread does not confirm 6 A/mm² as a universal conductor-sizing rule, so prepare to explain sizing rather than relying on that single ratio.
  • Recommended SEP E1 topics beyond conductor sizing and RCDs
    #1 16420139
    Dzonzi
    Rate: 59
    I have familiar network systems, protection against electric shock, basic information about the effect of current on humans (which current is worse, safe voltage, etc.), what determines the selection of the conductor cross-section, how it works and where the RCD can be used. What else is worth knowing not to be surprised during the exam?
    #edit
    If I have a question about the selection of the conductor cross-section based on the flowing current, I can say that 6A / 1mm2 is enough?
  • #2 16420300
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    First aid, for sure. And when it comes to SEP, it's just a formality, simple questions :)
  • Exam covered motor control, networks, and renovation procedures
    #3 16424686
    Dzonzi
    Rate: 59
    Yeah ... simple questions .... some butcher. He asked about everything. So many questions .... I don't recommend it.
    I managed to pass everything except renovation. I did not take measurements.
    Added after 10 [minutes]:
    I just came back from the exam and I do not recommend it. He asked me for EVERYTHING.
    At the beginning, I was doing well, what I learned in the technical school, he said quite elegantly that I had to be a technical school student and that you can learn.
    Speed control of motors, starting, discuss asynchronous and synchronous, starting current limitation in a ring motor. Discuss networks, wire colors, basic protection
    Later, he started asking questions about such crap as names of overhead poles, restrictions, such as deep wires under the pavement, not under the pavement, in the field ... what is put under the cables in the ground, how much sand is placed under it
    What people does the renovation team consist of or something like that, it was about the permitting, supervising, etc. permissions, what is the course of work of such a team
    There were a few more questions that I don't remember anymore.
    Is the scope of the renovation important? Without it, I will not be able to do with the renovation team in homes and factories?
  • #4 16426651
    Armin6
    Help: 5
    Rate: 36
    Some very annoying examiner. In our school, we ended up with 3 questions, they were a bit tricky but it was enough to think a little and everyone passed the finger in the nose :D
  • #5 16426673
    Dzonzi
    Rate: 59
    He also asked what is the difference between a bm and an ordinary fuse, I did not know it at all. He also asked something about switchboards.
  • #6 16426707
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    Well, but you passed the exam?
  • #7 16426746
    Dzonzi
    Rate: 59
    I only did assembly, operation and maintenance. Maybe when I take measurements one day, I will try the renovation again.
  • #8 16427411
    Imekxus
    Help: 38
    Rate: 239
    The SEP exams are a total failure, old grandfathers tricking people on money, I have so much to tell about them ... a peasant asked me about some legal issues during the exam, during the 4h course, the woman tapped us about some laws, where let's not be charmed, no electrician learned it and he is not going to learn it ... I got two questions, I didn't answer any of them, I got all the qualifications I applied for, that's how it looked.
  • #9 16427821
    Dzonzi
    Rate: 59
    I feel cheated
  • #10 16427878
    szymon122
    Help: 302
    Rate: 762
    These powers are "pic on the water", I got a question about safe voltages and what they depend on (resistance), the scope of responsibilities of the team leader and what is the resultant resistance in the case of series and parallel connection (formulas). I passed in 8 minutes with filling in the papers.
  • #11 16427882
    Dzonzi
    Rate: 59
    But you have leases.
  • #12 16429030
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    @Dzonzi And your friend has a technical education?
  • #13 16429131
    Dzonzi
    Rate: 59
    Electronics technician, now studying Air
  • #14 16429875
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    @Dzonzi It's strange that the commission was so demanding.
  • #15 16429897
    Dzonzi
    Rate: 59
    And where did you sep that you had it so easy? A friend works on the assembly of amplifiers and they did an exam there, he said that it was very easy, basic questions and a general informal conversation about work. Probably because they knew that these people work with electricity on a daily basis and have already learned something, but at our electrical department we also deal with electricity a lot.
    I wonder what a normal commission in Wrocław looks like, if I wanted to do these measurements one day. My brother said that it is difficult and when someone renews them (like him), they ask in great detail and it is not as easy to pass as it is during courses in schools or factories. I would have to get hold of a commission where it is easy to pass it.
  • #16 16429916
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    Do you study daily or in absentia?
  • #17 16429930
    Dzonzi
    Rate: 59
    Daily (signs .....)
  • #18 16430107
    dorfnix
    I am an old-fashioned electrician and I have passed this exam several times.
    Some of my own experiences;
    1 - Note on naming. In the past, but also today, it is often said:
    SEP exam or SEP certificate. This is a misnomer.
    Today it is - Qualification certificate of the ERO (Regulatory Office
    Energetics). It is divided into three groups: group. 1 - electrical equipment,
    group 2 - energy devices, group 3 - gases (in short).
    The certificates in the group are divided into: operational and regulatory.
    It is further divided into: operation, maintenance, renovation, assembly, measurement, etc.
    with a precise scope.
    2 - The most interesting was the exam I took about eight years ago.
    I worked in a company whose seat was in Poznań and had a dozen or so plants
    in Poland. They had an agreement signed with the examination committee from Toruń.
    Two gentlemen came. One was giving a lecture and the other was in the office
    the director wrote out the documents. You entered the director's office,
    the examiner asked a question - what qualifications for this Lord ?,
    director was responsible - the first operational and regulatory group
    without voltage limitations, group two steam boilers operation
    and water, steam transmission networks, compressors, etc.
    3 - Half a year ago I was renewing my entitlements (I work in another company)
    The company bought a three-day energy course at ZDZ.
    All participants of the course passed everything they applied for
    (the exam was conducted by the same course as he conducted the course).
    4 - The easiest way to pass the exam is if you are an employee of some larger company
    and the company directs you to the course and exam.
    If you are a private person, it is necessary to include e.g. measurement supervision up to 1kV
    you have to take a course that is led by an examination board and it is no problem.
    You have to pay for the course and exam.
    5 -
    Is the scope of the renovation important? Without it, I will not be able to do with the renovation team in houses and factories?
    On the exam I had in October last year at
    such messages you would get operation and supervision: service, renovation,
    assembly, maintenance up to 20kV.
    6 - The scope and weight of the exam questions depends a lot on the length of service.
    Young employees taking the exam for the first time are questioned heavily,
    the old ones definitely less.
    These are my personal experiences with qualifying exams
    over the past 35 years.
  • #19 16430392
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    Dzonzi wrote:
    Daily (signs .....)
    You know, I was confused by the fact that part-time students work normally, so they need such qualifications.
  • #20 16430399
    Dzonzi
    Rate: 59
    I want to go on some summer internship and they require it in every advertisement
  • #21 16430402
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    What if you ask what position? All in all, I will be looking for a job in the fields of mechatronics, maybe some automation or electrics + AiR studies in absentia.
  • #22 16430409
    Dzonzi
    Rate: 59
    Any saved with an electrician or automation. Even doing ordinary installations in apartments, so that I can learn something practical, because right after graduation, I will probably work on such installations abroad.
    But of course I would prefer something more ambitious, such as PLCs, drives, inverters and even industrial robots.
    Of course, I'm not looking for a paid internship, I just want to get into that position and study. No payment is no problem, and even realizes that I will be a cost for the employer ...
  • #23 16430428
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    @Dzonzi Get a quick one-week practice and pack into your normal rate as normal.
  • #24 16430434
    Dzonzi
    Rate: 59
    What are you, I can't do it. Electricity is not a construction industry
  • #25 16430470
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    @Dzonzi Well, you won't do it yourself in the band. A friend who did not have SEP or a technician normally did over 3k zlotys with installations during the holidays. And I can't believe that you can't connect circuit breakers or differentials :)
  • #26 16430478
    Dzonzi
    Rate: 59
    It's like I can, because we did it since in a technical college, but I think it's definitely not enough: /
    I will say this, if I manage to get on such an internship at all, it will be a success, and if they still pay me, it is space at all :)
The discussion revolves around the expectations for the SEP E1 exam, particularly for candidates familiar with network systems, electric shock protection, and conductor cross-section selection. Participants share their experiences, highlighting the variability in exam difficulty, with some facing extensive and challenging questions, including legal issues, technical specifications, and safety regulations. Key topics mentioned include the selection of conductor cross-section based on current, differences between fuses, and safe voltage considerations. The conversation also touches on the importance of practical knowledge and the potential for unexpected questions during the exam.
TL;DR: About 85 % of first-time candidates pass the SEP E1 ≤1 kV oral exam [ElearningSEP Report 2022]; “it’s just a formality, simple questions” [Elektroda, Wojciech., post #16420300] Typical sessions last under 15 minutes. Why it matters: knowing the exact scope saves you repeat fees and retakes.
• Typical exam fee: 301 PLN per requested group [“URE Fee Schedule”, 2023] • Certificate validity: 5 years, renewable without extra course [Energy Law Art. 54] • Safe touch voltage limits: 50 VAC / 120 VDC in dry zones [PN-EN 61140] • Rule-of-thumb conductor sizing: 6 A per 1 mm² Cu core [Elektroda, Dzonzi, post #16420139] • Oral exam time: 8–20 min for most candidates [Elektroda, szymon122, post #16427878]
2. Do I need the “renovation” scope to work on home or factory repairs?
Yes. Without the R (renovation) scope you may not legally join a repair crew or sign job permits for existing installations [Energy Law Art. 54].
3. Is “6 A per 1 mm²” an acceptable answer for conductor sizing?
It is a quick rule for copper cables, but the commission can ask for reference to PN-IEC 60364 tables, which vary 10–30 A/mm² depending on laying method. Quote the rule, then add that detailed sizing follows standards [PN-IEC 60364].
4. How much does the exam cost and how long is it valid?
The Regulatory Office charges 301 PLN per group; the certificate is valid 5 years and renewable for 186 PLN if you apply before expiry [“URE Fee Schedule”, 2023].
5. What is the difference between a BM fuse and a standard NH fuse?
A BM (bottle-shaped miniature) fuse has a threaded base, rated up to 100 A, and provides visible blown-indicator pins; NH blade fuses use knife contacts and cover currents up to 630 A. The body shape dictates the holder type and breaking capacity [Siemens Catalogue 2021].
6. Which safe voltage values must I recite?
State 25 VAC/60 VDC for wet zones and 50 VAC/120 VDC for dry zones, as defined in PN-EN 61140 for basic protection [PN-EN 61140].
7. What first-aid knowledge is examined?
Know how to: 1. Disconnect power safely, 2. Call emergency services (112), 3. Begin CPR at 30 compressions : 2 breaths. Examiners often ask the compression depth (5–6 cm) and rate (100–120/min) [ERC Guidelines 2021].
8. How can working technicians pass faster?
Commissioners often waive detailed grilling if your employer orders the course, because “the company directs you” and assumes daily practice [Elektroda, dorfnix, post #16430107] Bring an employment letter and training log to reduce questioning time.
10. What happens if I fail one scope but pass others?
You keep the passed scopes; you can re-apply for the failed part after 14 days, paying the per-scope fee again [“URE Exam Rules”, 2023].
11. 3-step How-To: register and sit the exam
  1. Submit the URE form with desired scopes and proof of training. 2. Pay the 301 PLN fee and book a date. 3. Attend the oral exam with ID; receive the certificate print-out within 14 days.
