Bosch TCA 6001 benvenuto B20 - Does not make coffee, water flows into the tray
8208 4
  • #1 16421339
  • #2 16737698
    nowicki1990
    Rate: 8
    Hello, do you have any way to set this clutch? After folding, I have the same and I want to start undressing again, but I don't want to guess then and not do it yet :)
  • #3 16737709
  • #4 16737724
    nowicki1990
    Rate: 8
    To correct it, it is about what is in this can, right?
    Thanks very much, and if you associate the photo from which you looked, give me a link.
  • Infuser likely causing water to drain to tray
    #5 16738415
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    These are two different machines that operate on completely different principles.
    By mixing threads of two different models with a completely different design, you can get lost.
    The author has already solved the problem?
    The last post suggests a problem with the infuser, since all the water goes to the tray.
    Kawa i Naprawa - Serwis AGD
