Bosch VeroAroma 500 TES60523RW Coffee Machine - 'Device Needs to Cool Down' Message Issue
Geronimo10 9234 3
  • #1 18549569
    Geronimo10
    Rate: 8
    Hello, I have a problem with the Bosch VeroAroma 500 coffee machine. Imported from Germany, it worked several times and now a message is displayed saying that the device needs to cool down. Anyone know anything about?
  • #2 18552574
    robsons10
    Help: 73
    Rate: 401
    I suggest checking the block drive. If the brewing unit is not audible after starting, but after a while the message appears, it is something with the drive or its power supply.
  • #3 18555992
    MAN_IN_BLACK
    Help: 9
    Rate: 72
    A standard fault in Bosch / Siemens espresso machines is the brewing unit drive and the ceramic valve. I would check the brewing unit drive because it likes to lock, especially when the espresso machine has its time and stands a little unused.
  • #4 18568259
    Geronimo10
    Rate: 8
    Thank you very much for the advice, when I get home I will take this machine.
    Do you have to spin it up and how to go about it?
