Tchibo Cafissimo Duo: Water Dripping Issue and Knob Position Malfunction
prochu1972 7905 2
  • #1 16945571
    prochu1972
    Help: 6
    Rate: 65
    Hello all
    I have such a problem with my express:
    water into the capsule barely drips and the knob that should return to the "0" position after brewing coffee remains in the "cup" position and the backlight blinks just like before brewing. Is it serious damage or can you fix it yourself. I will add that water does not flow into the drainer.
    Help Regards Piotrek
  • #2 16945645
    barton21
    Help: 79
    Rate: 192
    Check the pump
  • #3 16985880
    prochu1972
    Help: 6
    Rate: 65
    3x a glass of water with 100ml vinegar cleaned up. I consider the topic closed
