Renault Laguna III 3 diagram - I need an air conditioning wiring diagram
Pabcd 8892 3
  • #1 16421980
    Pabcd
    I need an air conditioning wiring diagram for Renault Laguna III 2.0dci. Because there is no electricity to the air conditioning compressor.
    All fuse checked and no current.
  • #2 16423467
    robi1214
    Help: 151
    Rate: 869
    Errors in the engine controller regarding air conditioning are not available. Without deletion, it will not start.
  • #3 16423490
    szymitsu21
    Help: 343
    Rate: 1300
    And without pressure in the system and we do not know if it is and what if.
  • #4 17876195
    konai
    Help: 10
    Rate: 33
    I will connect and ask where the compressor fuse is and where to look for it, thank you
