Renault Laguna 2 Air Conditioning Compressor Not Turning On: 1.8 16v - Gas Issue or Bent Cable?
Jasiek2000 13497 9
Why does the air conditioning compressor on a Renault Laguna 2 1.8 16v not switch on after a gas refill and valve replacement?
The compressor not switching on is more likely an electrical or component fault than a gas issue: check the wiring for breaks or bends, then verify the pressure sensor, and if power reaches the compressor test the compressor clutch/solenoid/valve and measure resistance [#16576078] [#16576234] If current is reaching the compressor, something in the compressor assembly itself is likely damaged rather than the refrigerant charge being the only problem [#16576234] The thread also notes that AC pipes cannot be “frozen” or bent as the cause of this symptom, so the piping should not be the first suspect [#16575990]
  • #1 16575986
    Jasiek2000
    Hello, I have a problem with the air conditioning compressor, it does not turn on. Klima filled, tight, replaced valve with a new one, the current in both cubes is and still does not turn on. Strange, because when filling the air, apparently, little gas has entered, it may be that the gas does not reach the compressor because there is a bent cable and therefore does not turn on? Please help. Renault laguna 2 1.8 16v
  • #2 16575990
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Jasiek2000 wrote:
    because when filling the air, apparently little gas has entered, it may be that the gas does not reach the compressor because there is a bent pipe
    Then replace it, the air conditioning pipes cannot be frozen.
    And don't go to mates what they know ...
  • #3 16576078
    kalumet
    Before you go to the mechanic, see for yourself these wires or nowhere are they bent
    if the wires are ok check pressure sensor
  • #4 16576105
    Jasiek2000
    I will say this: the mechanic looked at it twice and today gave up and does not know what it could be, the sensor was also replaced but the old one was good, as the mechanic checked, there is no gas in the radiator, and should it be? And if the hours for the wires, if they were broken, would it be gas?
  • #5 16576211
    Help: 1405
    Rate: 6430
    Jasiek, write clearly with whom you were.
  • #6 16576213
    Jasiek2000
    I will only add that it was connected to the computer and error DF090 what is this error?
    • Renault Laguna 2 Air Conditioning Compressor Not Turning On: 1.8 16v - Gas Issue or Bent Cable? Screenshot_2017-07-08-22-47-46.png (871.75 KB) You must be logged in to download this attachment.
  • #7 16576223
    Help: 1405
    Rate: 6430
    BOY, who have you been to since you haven't even seen the compressor?
  • #8 16576232
    Jasiek2000
    I am writing to the mechanic
  • #9 16576234
    ladamaniac
    Help: 724
    Rate: 2078
    There is a break in the circuit, since the current reaches the compressor, something is damaged in the compressor, clutch solenoid or valve. Measure the resistance or test the actuators.
  • #10 16576243
    Jasiek2000
    Thanks I'll check back tomorrow.
The discussion revolves around a malfunctioning air conditioning compressor in a Renault Laguna 2 1.8 16v, which fails to turn on despite having the system filled with refrigerant and a new valve installed. Users suggest checking for bent wires and the pressure sensor, as well as confirming the presence of gas in the radiator. The author mentions an error code DF090 after connecting to a diagnostic computer, indicating potential issues with the compressor's circuit, clutch solenoid, or valve. Further testing of the circuit and components is recommended to identify the fault.
