Samsung a5 2016 does not charge - Does not charge on the original charger
gosiaciszak 4503 3
  • #1 16562422
    gosiaciszak
    Rate: 40
    I have a problem charging my phone since yesterday. When connected to the original charger, the phone cannot see or charge it. The charger is working because I have the same phone and the other one loads without a problem. After connecting to another charger, the phone charges without any problem but that it is slower. It looks like fast charging doesn't work. I searched and there is no option to enable or disable this feature. Does anyone know what this could be? Maybe it will work without a reset? The phone was charged several times with an ordinary charger, could it damage it?
  • #2 16562584
    E8600
    Help: 529
    Rate: 2520
    Unless it was a charger for 5 PLN, it's out of the question that it will get damaged (slow charging works). It looks like a bug in the software, probably others will also advise you to reset. :( You can still try to clean the nest.
  • #3 16580685
    gosiaciszak
    Rate: 40
    Unfortunately, the reset did not help much. The only thing that the phone began to charge with the original charger but very slowly. Even slower than a regular charger. Fast charging is still missing.
  • #4 16580734
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Now it fits a second battery because this model often has problems with the battery. I had cases where the battery was swollen in a few months model.
    The flip does not start to lift you?
    Do you no longer have a guarantee to use it?
