Samsung A5 (2016) - The phone does not want to charge via USB or connect to the
sosna94 3180 4
  • #1 16718003
    sosna94
    Hello, I had a bad situation yesterday, my phone was discharged, so I connected it to charging, and then the trouble started, the phone did not want to charge, the battery badge was showing on the screen and it disappeared all the time, so I tried to start the phone one time I succeeded and the android logo popped up and some boot error, so I reset the phone and one time it disappeared and the phone then turned on normally, but I have such a problem because now I can not charge the phone normally because when I connect the charging cable, nothing happens as if it would not I saw I tried to connect the phone to the computer is also dead and it is strange that if I turn off the phone and connect to the mains charger it is not shown that it is charging but after an hour it will charge 15% I wanted to re-upload the system but without a connection to the computer I would not do anything; / please help !
  • #2 16718017
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. The socket in the phone is not touched. The lack of contact on the socket may be the reason for this, or maybe February on the disc.
  • #3 16718019
    sosna94
    The socket is not broken, the phone is only 2 months old, it is very possible that they let go, but after such a time when it never fell to me; /
    Pedros050
    Help: 2471
    Rate: 3926
    And it was necessary right away that it is under warranty. Reclaim the phone.
  • #5 16719159
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    The battery has died. Theoretically, you can drink it and charge it on the charger to wake it up. The phone is practically under warranty, so give it back.
