Relocating Users and Program Files on Windows 10: Is It Possible?
Sannjas 11220 6
  • #1 16429278
    Sannjas
    Rate: 17
    Hello!
    Has anyone practiced such a solution?
    I was looking for instructions but unfortunately they are only for earlier versions.
    Please help.
  • #2 16429307
    sylweksylwina
    Help: 1882
    Rate: 2355
    What do you want to do this? Just install programs and keep files on another partition / disk.
  • #3 16429316
    Sannjas
    Rate: 17
    I have a small SSD disk and I work mainly on files kept on the desktop. I know it is a matter of habit but I check if it can be done.
  • #4 16429343
    rafal131313
    Help: 27
    Rate: 181
    The easiest way would be to back up the whole disk, especially as it is small :)
    e.g. Acronis True Image
    You can make a copy of files and store on the net, etc ...
  • #5 16429348
    Sannjas
    Rate: 17
    Ok, but I wanted to move to another magnetic disk what I use and that the desktop was taken from there. Can you do something like that?
    sylweksylwina
    Help: 1882
    Rate: 2355
    It changes things. Enter in C: \ users \ username click right on the "desktop" directory -> properties -> location tab
    And there you will have options that interest you :)
  • #7 17202130
    Gio4u
    do you have to discuss topics you have no idea about? focus on the construction of a hammer and pliers
    Moderated By DriverMSG:
    3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, they are dangerous or they do not solve the user's problem.
    3.1.19. Do not send messages on archive topics if it is another question, in particular other than the questioner. Because of the respect to the questioner, create your own topic. You can only add a way to solve the problem.
    3.1.9. Do not be ironic and do not be mean to the other side of the discussion. Respect different opinions and other opinions on the forum.
The discussion revolves around the possibility of relocating user files and program installations on Windows 10, particularly for users with limited SSD space. The original poster seeks guidance on moving files from a small SSD to a larger magnetic disk, specifically wanting to change the location of the desktop folder. Responses suggest backing up data using software like Acronis True Image and provide a method to change the desktop directory location through the properties settings in the user folder. The conversation highlights the need for practical solutions for managing storage on Windows 10.
