Win 10: How to Locate & Recover Files from Desktop, Downloads, & Documents on Non-Booting Drive
cyborg39 27333 10
  • #1 17943001
    cyborg39
    Help: 105
    Rate: 541
    I installed Windows 10 for the first time, after some time it stopped starting. None of the repair options work. I had Windows 7 working on another disk, I connected both of them because I would like to recover files from the Windows 10 desktop. The problem is that I cannot find the "Desktop", "Downloads", Documents ", etc. folder on my Win 10 disk. How do I recover these files? They must be written somewhere
  • #3 17943016
    Heinzek
    Help: 554
    Rate: 494
    By default it is in C: \ users \% username% \
    And then the folders:
    Desktop
    Documents
    Download
  • #4 17943088
    cyborg39
    Help: 105
    Rate: 541
    I know Windows 7 quite well, the problem is on the disk with Win 10 not working and there is no Users directory there.
  • #5 17943108
    sosarek
    Help: 9318
    Rate: 15496
    Are you sure you are looking at the partition where the system was installed?
    Z
    Pka, Poznań, 60-850
  • #6 17947749
    cyborg39
    Help: 105
    Rate: 541
    Yes, it must be the partition .. I have no idea what's going on, as if the folders are gone? First, Windows stopped starting, no repair or recovery options worked
  • #8 17950067
    cyborg39
    Help: 105
    Rate: 541
    Hmm .. Then I will add an earlier history, it may have an impact on this disappearance .. Well, when Windows was still running, the computer would hang from time to time, slow down, and after some time it worked properly again. I noticed that at these moments you can hear characteristic, repeating sounds from the hard drive. For this reason, I installed the HDD Regenerator program and ran it with the scan and repair option. The program scanned the entire disk (under Windows), found no bad sectors. After all, I shut down my computer normally. On the second day, it did not start anymore, further story in the first post ..
  • #9 17950075
    icosie
    Help: 298
    Rate: 239
    cyborg39 wrote:
    I installed HDD Regenerator and launched it
    Error, could have finished the data on disk already.
    sosarek wrote:
    Disk visible on druvim computer properly?
    Post his SMART.
    Follow it.
  • #10 17953031
    cyborg39
    Help: 105
    Rate: 541
    The disk is visible correctly, all data from the D partition is available, from the C partition those that are visible are also available, no "Users" folder or "Users" folder there. I already suspected in the company laptop that this folder should normally be there.
    Now it's harder .. What's the easiest way to preview a SMART disk?
  • #11 17953311
    icosie
    Help: 298
    Rate: 239
    You can preview SMART with the following programs:
    - Hard Disk Sentinel
    - CrystalDiskInfo
    Upload screenshots from programs, full windows, because sometimes it crops the bottom attributes, and you need all of them for the analysis.
    It seems to me that HDD Regenerator or Windows CHKDSK has done its job.
    After the SMART analysis, if the disk is in good condition, DMDE will probably be useful, as it should be able to recover data. But this is only after you read SMART correctly.
✨ The discussion revolves around recovering files from a non-booting Windows 10 drive. The user initially seeks to locate the "Desktop," "Downloads," and "Documents" folders but cannot find the "Users" directory on the Windows 10 disk. Responses suggest that these folders are typically located in C:Users%username%. The user confirms that the disk is visible and that data from other partitions is accessible, but the "Users" folder is missing. Further context reveals that the computer had been experiencing performance issues prior to the failure, leading to the installation of HDD Regenerator, which did not identify bad sectors. Recommendations include checking the SMART status of the disk using tools like Hard Disk Sentinel and CrystalDiskInfo, and if the disk is healthy, using DMDE for data recovery.
