Mileage Correction: VW Golf IV 1999 1.4B Gasoline, Delphi DS100E OBDII, Software & Adapter
eyeshot1905 14988 5
  • #1 16429403
    eyeshot1905
    Rate: 13
    Hello, I would like to make a meter correction in my GOLF IV 1.4 gasoline. I have a diagnostic interface DELPHI DS100E with OBDII plug and the same company program.
    My question is, can I use this device to make a mileage correction when I buy a cable adapter and download some other soft?
    Is it better to buy a cable with a golf and USB output and download some soft for it?
  • #2 16429425
    szymitsu21
    Help: 343
    Rate: 1300
    No DIAGNOSTIC TESTER will do the correction (almost none) and certainly not ADP.
    you need something for correction, vag tacho, commander etc.
    Nevertheless, in such a car it will be cheaper to outsource it to someone than to invest in equipment.
  • #3 16430695
    eyeshot1905
    Rate: 13
    I read somewhere that you can pull out such a cable for about PLN 30 more or less. And download the program to which you can undo the counter what do you think about it? The second thing that such equipment will be useful for sure I can also invest is not important. I just want to do it myself for my satisfaction among others.
  • #4 16430728
    szymitsu21
    Help: 343
    Rate: 1300
    Look at the well-known auction site, read what they have in the list and you'll know what suits you best. There is such a huge amount of equipment that it's hard to say unanimously what to buy.
    Regarding what you write, I hear first.
    coperfild
    Help: 291
    Rate: 1697
    What is your meter, like VDO, maybe you can do other than just a programmer.
  • #6 16450442
    eyeshot1905
    Rate: 13
    I bought one of the cheapest cables and gave advice thanks for the answers
