WV Golf V: Clearing Airbag Error - Tester Recommendations, Affordable Options & Alternatives
dareczek3000 36462 9
How can I clear an airbag fault in a Golf V, and is a cheap VAG tester enough?
You need a CAN-capable diagnostic interface, because cheap VAG cables from Allegro often connect only to the engine, while airbag diagnostics in Golf V go through the CAN gateway [#16318463][#16320142] But the fault should be diagnosed and repaired first, and only then erased [#16318640] If the problem appeared after messing with the fuses or ignition, buying a cable may be a waste of money and it may be easier to have the fault cleared in a workshop or friendly service [#16319606][#16320193][#16318235]
  • #1 16318080
    dareczek3000
    Rate: 28
    I want to clear the error of the airbag cushion. I wonder if I should buy a tester to erase errors, if so what? I know that there is a lot on the net from 80 zlotys, you can only buy something if they can deal with it. Or maybe there is another way?
  • #2 16318235
    andrzej20001
    Help: 1578
    Rate: 6669
    Delete in the workshop
  • #3 16318463
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Only something after CAN.
    Such VAG with allegro will connect only with the engine.
    Here communication is after CAN.
  • #4 16318640
  • #5 16319606
    dareczek3000
    Rate: 28
    The diagnosis is the fuse removed when the ignition is on
  • #6 16320100
    r_Lunar
    Rate: 32
    and are you sure that any airbag driver inserted into the golf V was after CAN in terms of diagnostics?
    remove the wheel cover from the side of the gearbox gearbox on the left, and somehow try to read the beginning of the driver number which is hidden there
  • #7 16320112
    andrzej20001
    Help: 1578
    Rate: 6669
    How to buy a cable can and ik jump.
  • #8 16320127
    r_Lunar
    Rate: 32
    do not say this because they will eat you. :) he should go to the workshop for serious diagnostics even if the error gets erased
  • #9 16320142
    grala1
    Help: 1495
    Rate: 5052
    Diagnosis with pillows is via the CAN gate via CAN and the CAN gateway has communication with OBD via CAN.
    r-Lunar, if you have other information, then show them off.
    Already Golf IV had from the year 2000 communication with pillows via CAN. Line K was also there but it was not attached anywhere.
    It is obvious that interfaces and CAN-diagnoshes that work with CAN also work on the K line and should also work on the L line
  • #10 16320193
    andrzej20001
    Help: 1578
    Rate: 6669
    As soon as he fumbled in the fuses, it is a waste of money for the purchase and then for the bank to cry as if something of boredom will change in coding and this tempts the cable operators. It is better to delete the fehler in a friendly establishment.
The discussion revolves around clearing an airbag error in a VW Golf V. Users suggest that while affordable diagnostic testers are available, they may not effectively communicate with the airbag system, which operates via the CAN protocol. Recommendations include seeking professional diagnostics to ensure proper error resolution, as simply erasing the error without addressing the underlying issue may lead to further complications. Some users mention the importance of checking the airbag driver and fuses, while others emphasize the need for a CAN-compatible interface for accurate diagnostics.
