[Solved] UPS Ever CDS 700 emergency power supply - short circuit during battery replaceme
Paszczak22 8979 14
Can I turn a damaged Ever CDS 700 UPS into a standalone full-sine inverter by removing the unnecessary charging/control parts and connecting only the battery and inverter stage?
No simple bypass or strip-down is suggested; the thread points instead to a fault that should be repaired in the UPS’s power stage. First check the two green 30A board fuses between the red and black battery leads, and inspect the PCB for a burnt trace or ground path, because that current path should not normally burn out [#16432978][#16450807][#16433477][#16435514] One user who had the same kind of short found damaged IRF1404 MOSFETs, replaced the fuses and transistors, but the UPS still blew the same path, which suggests the real problem may be in the control/drive circuit for those transistors [#16539488][#16541107] The thread does not provide a schematic or a method to convert the board into a simpler battery-only full-sine inverter. In practice, the only definite “solution” mentioned was to buy a separate full-sine converter instead [#17996479]
  • #1 16432933
    Paszczak22
    Rate: 114
    Yesterday I replaced the battery in my old UPS. I wanted to remove the protection of the "+" connector on the battery with a screwdriver and unfortunately I came into contact with the device housing. A short cycle of a little balloon and the device didn't get up. I don't know what exactly burned out because you can't see the soot exactly. But this UPS could be used as an emergency power supply for the pump and gas furnace in the event of a power failure because it was equipped with a full sine wave. But before I get fixed, I don't need real-time power. Can I remove the necessary elements from this power supply, such as a transformer, inverter, etc., to get the full sine output after connecting the battery? Anyone have a schematic? Certainly in this electronics there are modules needed to detect the power state or the battery charge level, and for me it is unnecessary because such a system is an additional load for the battery. Can you do something like this "analog" or does it have to be a digital module? Or maybe it can be done with an arduino? I am completely green. I know how to convert AC to DC but I haven't done it the other way yet. Please help.
  • #2 16432978
    huluk
    Level 32  
    Help: 221
    Rate: 206
    Check the fuses first. It's a bit strange, because by shorting the + battery to ground, you only short-circuit the battery, if the UPS was turned off at that time and the charging system was not working, then nothing should happen to it.
  • #3 16433023
    jmnlabs
    Level 19  
    Help: 40
    Rate: 50
    See also if the plate has not burned the mass path.
  • #4 16433025
    mariann
    Help: 550
    Rate: 647
    Also check the plate from the print side. Perhaps there was some path burnt out.
    best regards
  • #5 16433181
    Paszczak22
    Rate: 114
    I was looking, but I really can't see anything. In total, this power supply was bought on the Allegro for PLN 60, so I do not have a 100% guarantee that the error is operational before changing the battery. I am attaching photos of the board on both sides.
  • #6 16433194
    huluk
    Level 32  
    Help: 221
    Rate: 206
    And the fuses are measured? Something reminds me that this UPS will not start without a functioning battery connected, if the fuses "popped", there is a break in the battery circuit and the UPS may not want to "start".
  • #7 16433477
    Paszczak22
    Rate: 114
    The tubular fuses are intact. I started looking for a broken circuit - did not find it. I plugged it in again and turned it on. It started to shoot and smoke in the marked place until the path came out of the tile. Does this mean that I have to make an additional bypass circuit with another wire?
  • #8 16435514
    huluk
    Level 32  
    Help: 221
    Rate: 206
    Probably not. This path should not be followed by so large currents that it would burn out. Was it working properly for that moment after turning on the UPS? If so, you can measure the current flowing through it. A functional, charged battery was connected? There is probably a short circuit somewhere. You have to traverse the elements following its footsteps.
  • #9 16450500
    Paszczak22
    Rate: 114
    And here the problem becomes more complicated. The path branches out - one of them leads to some kind of chip. I suspect that it will be difficult to locate the fault. Coming back to my question, if the current can be rectified with a few diodes, maybe it can be easy to change direct current to alternating current using parts from this UPS. PS. I want a full sine wave.
  • #10 16450807
    MACIEK_M
    Help: 111
    Rate: 462
    The battery fuses are the two fuses on the board, green with the number 30, between the red and black battery cables.
  • #11 16450837
    Ture11
    Help: 573
    Rate: 1130
    My friend probably connected the UPS front panel to the board incorrectly, these UPSs do not like it. I've already done one Ever (a microcontroller shot). I don't know how - but it happened.
  • #12 16517915
    LukaszBfy
    I made the same mistake - short circuit + to ground on the off upsie when replacing the battery. Teb ups probably does not have a protection system against such a case. Managed to fix the board (path connection and replacement of 30A fuses)? Are these regular 30A 32V automotive fuses?
  • Repeated fuse failure after IRF1404 replacement
    #13 16539488
    mlak
    Hello, I will connect to the topic, because maybe someone has managed to fix such a defect.
    I broke my UPS similarly, but I'll add some data.
    My UPS had cables with + and - crocodile clips led outside. It was connected to an external battery (under the photo / solar battery). Recently the crocodile clip fell off my clamp and touched the housing. The spark was heard. (the current flowed from the capacitor at the UPS input). Before reconnecting, I looked inside to be sure. I did not notice anything suspicious, so I connected the battery (so far nothing happened. After pressing the switch, the fuse burned out and exactly the same path as in the description above. I do not have a diagram, but I measured as much as I could and found two IRF1404 transistors damaged. So the path, I replaced the fuses, I replaced the transistors. After connecting, unfortunately, the effect is the same, i.e. after pressing the switch, the transistors fuses and this path. These transistors make me wonder because they are final and there is only a transformer behind them. it is 17v, it works quietly and does not heat up, so the secondary winding does not have short-circuits between the coils. Maybe someone has already managed to fix it, or maybe someone has a diagram, it would be a chance to go deeper.
  • #14 16541107
    mariann
    Help: 550
    Rate: 647
    Rather, see what drives them. Because it is the wrong control of these transistors that is probably the reason for their damage. They're probably open all the time, which is why the fireworks.
    best regards
  • #15 17996479
    Paszczak22
    Rate: 114
    I fell ... I bought a full sine converter. best regards
The discussion revolves around a user who short-circuited their UPS Ever CDS 700 while replacing the battery, leading to potential damage. Participants suggest checking fuses and circuit paths for burns or breaks, as well as the possibility of a short circuit. The user reports smoke and damage to the circuit board, complicating the repair process. There are inquiries about the feasibility of modifying the UPS to output a full sine wave without unnecessary components. Some users share similar experiences and suggest replacing damaged components, such as transistors, while others recommend ensuring proper control of these components to prevent further damage. Ultimately, the user decided to purchase a full sine converter instead of repairing the UPS.
