Upgrading Netiaspot Router for Enhanced Range, Stability & Speed: Considering TP-Link, Netia CU
deejayscream 19281 36
How can I replace NetiaSpot to improve Wi‑Fi range, stability and speed in a two‑storey house, and can one router cover the whole house?
You probably won’t solve this with one stronger router alone; the main problem is the network layout, so the stable fix is to keep the ISP modem/router as needed, turn off its Wi‑Fi, and connect a properly placed access point upstairs by Ethernet, or use PLC if you cannot run cable [#18282959][#18311445] The upstairs device must not work as an APC/client on the same channel, because that causes interference and lower throughput; use the same SSID/password on both APs, set WPA2‑AES‑PSK, separate channels by at least 3, and reduce channel width to 20 MHz [#18282959] 5 GHz will not give you better house‑wide coverage, because its range is roughly half of 2.4 GHz, so it is not the answer for distant rooms or the garden [#18282959] Before buying anything expensive, verify whether the connection drops on Wi‑Fi only or on the ISP link itself; if the wired link is fine, then the problem is only wireless, but if the line is unstable you should report it to the operator [#18283145] If your service is VDSL/ADSL, you need VDSL equipment or you can leave NetiaSpot in bridge mode and connect a better router to its WAN port; for future fiber, any router with a WAN port and gigabit WAN/LAN will work [#16645812][#16650978][#16654539]
  • Seeking one-router Wi-Fi coverage for a house and garden
    #1 16473645
    deejayscream
    Hello. I have problems with Netiaspot and I intend to exchange it for something that will guarantee better range and stability. At the moment I have two networks, when I am downstairs I use Netiaspot, as at the top, we use a second router, TP link TL-WR843ND as AP, but then the net speed is lower. In advance we can connect to the netiaspot on the stairs, the net will be faster, but the range is weaker.
    One-family house, the router hangs on the wall by the stairs, often disconnects, loses coverage, Netiaspot after a new contract, supposedly up to 40mbit / s, if I remember they connected their cable to the house, but I do not know exactly what the net is, the contract says Netia CU ( copper?) Anyway, internet on netia cables.
    Perhaps there is a chance to change to use only one router and one network, the price of the router does not matter (within reason, of course), maybe you can get some coverage in the garden?
  • #2 16473770
    LucekB
    Help: 143
    Rate: 137
    Netia in what technology? up to 40, maybe VDSL over a copper telephone line? then you need a VDSL router.
    What's your budget?
  • #3 16473794
    deejayscream
    Perhaps it is VDSL or ADSL2 +?
    Can you check it by connecting to the Netiaspot router?
    The budget, as I have already written, does not matter, but if I am to spend more, let it be money well spent :)
  • #4 16474407
    LucekB
    Help: 143
    Rate: 137
    search for ADSL / VDSL statistics and paste the screenshot here.
  • #5 16476146
    KOCUREK1970
    Help: 3860
    Rate: 5488
    deejayscream wrote:
    we use the second router, TP link TL-WR843ND as AP, but then the net speed is lower
    What and how do you combine it with NS?
    Will you cover the whole house with one new router - I sincerely doubt.
  • #6 16476373
    deejayscream
    This router upstairs is wired to NS, but somehow functions as a separate network, with a different password. So, for example, being at the top I have a choice of two networks. In general, I check which router at the moment has better internet connection. The router at the top is set in total in line with the NS on the stairs at a distance of about 10 m? Are you suggesting to set the top router to typically AP, the network extension from the bottom?
    Maybe it is impossible to use only one router for the whole house, maybe I could use a second router elsewhere to increase the range?
  • #7 16476512
    KOCUREK1970
    Help: 3860
    Rate: 5488
    deejayscream wrote:
    That router on the top is wired to NS
    Connect it with RJ45 cable, or use PLC with NS.
    And in this case it is not AP, but APC (Access Point Client) - therefore lower performance.
    Use what I have given (either rj45 cable or PLC) and for a small amount you will be able to place the AP where it is most efficient.
  • #8 16476524
    deejayscream
    Well, only the rj45 cable, or the PLC connection involves pulling the cable through the room, corridor and stairs ... to the second router. It will not suit my wife too much, for obvious reasons :) :)
    The mere fact of using a PLC has already been taken into account, which is a nice thing, we'll think about it as well.
    The main problem is NS and unstable internet, frequent disconnection of the connection. I have to check what internet I have and which router to replace it with, also taking into account the future, e.g. how will we get optical fibers.
  • #9 16476540
    KOCUREK1970
    Help: 3860
    Rate: 5488
    deejayscream wrote:
    The main problem is NS and unstable internet, frequent disconnection.
    Just a question - does the internet itself break you, or ONLY the wifi connection?
    If the former, report it to the operator, if the latter - unfortunately, but only the wire or PLC.
    deejayscream wrote:
    I need to check what internet I have and what router to replace it with, also taking into account the future, for example, how will we get optical fibers.
    ADSL / VDSL at the moment (rather ADSL2 + or lower), and if there is optical fiber, a router with a WAAN port will be needed.
  • #10 16476549
    deejayscream
    Well, great buddy, I'm starting to know something more.
    "ADSL / VDSL at the moment (rather ADSL2 + or lower)"
    Will I find out what models you would recommend, let's say 3-4 for PLN 300-400 what can I find ?? As I said, how should I spend it, let it be money well spent.
  • #11 16476581
    KOCUREK1970
    Help: 3860
    Rate: 5488
    deejayscream wrote:
    Will I find out eventually
    Absolutely - just tell yourself in what technology you have it delivered.
    Can it be checked by connecting to the Netiaspot router?
    So we wait...
  • #12 16645566
    deejayscream
    Hello, after a long break, it took a while before I found out more about my link.
    Here is a screenshot from NetiaSpot. Now you can probably say something more about the router for such a link.
  • #13 16645812
    KOCUREK1970
    Help: 3860
    Rate: 5488
    You need a VDSL router (spooore prices).
    The only question is, do you still have a telephone on this NS and any IPTV?
  • #14 16645892
    deejayscream
    No, nothing extra. Only net. Significant prices, i.e.?
  • #15 16645976
    KOCUREK1970
    Help: 3860
    Rate: 5488
    From 300 PLN and up ...
  • #16 16650859
    deejayscream
    Cool, I thought it was going to get worse :)
    Any 2-3 models that will also support optical fiber in the future?
  • #17 16650978
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Because PLN 300 is the initial price for the simplest and least functional device.
    Standard prices of good VDSL / WAN equipment are PLN 500 and more ...
    You will get the optical fiber from the operator anyway (it must be) - and from it you can connect it to your router via the WAN port, so practically every router with a WAN port, with a LAN / WAN port of 1 Gb,
    As for Companies - look for Asus, FritzBox, maybe you will also find something from Netgear.
    Are you looking for VDSL / WAN hardware.
  • #18 16651043
    mazi292
    Help: 8
    Rate: 14
    Hmm, maybe instead of buying a VDSL router, you would buy an ordinary router with a WAN port and set Netia Spot to bridge mode?
    In my opinion, it will be a better option for the money of such a router with VDSL, you will buy a much better router with a WAN port and then for optical fiber it will also be suitable
  • #19 16654388
    deejayscream
    What would such a connection look like? I understand that then I connect these two routers via the network, not via a cable (this option is not available), and an additional router with a WAN port as an extension of the signal?
  • #20 16654539
    KOCUREK1970
    Help: 3860
    Rate: 5488
    The NS equipment will only be a modem (without wifi) and you go with the cable to your new router to the WAN port and then it "does" for the router.
    There will be two devices and both will have to be on all the time.
    mazi292 wrote:
    in my opinion, a better option for the money of such a router with VDSL, you will buy a much better router with a WAN port and then for optical fiber it will also be suitable
    The prices of such infinitely better routers start from 300 and up ;) .
  • #21 16657008
    mazi292
    Help: 8
    Rate: 14
    I expressed myself a bit badly, I meant that for the price of one of the cheaper VDSL routers it is better to buy an ordinary router for the money
  • #22 16657032
    deejayscream
    Everything is great, but connecting the NS and the second router at some distance with a cable may be a small problem, although the option suits me very well, it probably would have to be combined with pulling the cable through the stairs on the mezzanine to the living room where we spend the most time and use the internet. .
    Now just what router ??
  • #23 16657036
    mazi292
    Help: 8
    Rate: 14
    How many meters would be between the routers?
  • #24 16657240
    KOCUREK1970
    Help: 3860
    Rate: 5488
    deejayscream wrote:
    This is the way to go.
    There is something like a PLC, a set of 150 PLN new.
    Anyone with a 100 Mb WAN / LAN port (50 Mb for your net is enough).
    Unless you want to go crazy and buy a router with a 1 Gb WAN / LAN port ;) .
    And the next question - should it be only 2.4 GHz or 5 GHz?
    And make sure the NS actually has bridge mode and can be activated!
  • #25 16659062
    mazi292
    Help: 8
    Rate: 14
    Netia Spot has 100% bridge mode
  • #26 18282779
    deejayscream
    Some time has passed and I still don't have an answer to my question :)
    If I set the NS to Bridge mode and buy a better router with a WAN port and 5 ghz wifi, will i get such a network> netiaspot only has wifi 2.4 ghz.
    The router that I am thinking of:
    https://www.ceneo.pl/26385036#tab=reviews
    I have the same one in exile and I am very happy.
  • #27 18282959
    IC_Current
    Help: 1499
    Rate: 2521
    Nothing gets better. You have the wrong network topology. The device at the top, in APC mode, works on the same channel as the netia spot and thus they interfere with each other. This layout was acceptable when the link was 5-10Mbps, not 40 or more. First, you need to connect an additional AP on the top with a cable, change the channel layout (difference by a minimum of three), then reduce the channel width to 20MHz in the device settings. Then set the same SSID and password on both devices and manually select the security as WPA2-AES-PSK. The 5GHz network is for nothing - the range is about half as much as at 2.4GHz, so what would you like to regenerate on the second floor with your toys?
    Lay the cable, configure the devices and it will be ok. Besides, the problem is probably not a serious one, since you haven't removed it for two years :-)
    For PLN 1000 saved on devices (top and bottom), buy your wife gold earrings and she will not see the wire. Everyone will be pleased.
  • #28 18282972
    deejayscream
    A little update, no more AP upstairs, only Netiaspot at the stairs and a dramatic 2.4GHz network. The problem didn't fix itself, I didn't have much time for it myself, now I have and want to do something about it. 5ghz network, plus possibly 2.3 plc adapters to the most remote corners of the house.
    Earring advice to take into account :)
    I still do not understand why no one will ask me this way: Buy this or that router with vdsl and throw Netiaspot to hell. there will be no duplication of devices.
  • #29 18283145
    IC_Current
    Help: 1499
    Rate: 2521
    Nobody can help you buy this or that, because ... no one is a sales representative here and there is no commission on it, and no one conducts word-of-mouth marketing here. When you build a house, first the foundations, then the walls and finally the roof. You insisted that you want to replace the roof covering because it is leaking, but you cannot see that it is leaking because the foundations and walls are cracking. Nobody will tell you what to buy until you solve the problems at the bottom:
    - bad network topology
    - ISP link state unchecked
    Otherwise, you will buy something, it will not work anymore, and you will blame what the device offered you.
    You must first check the condition of the line, then connect the wires, then buy devices. What should you do:
    - connect the laptop with a factory cable (relatively short) to Netia spot and test the operation for a few hours
    - ok, then distribute the wires to several places in the house (the maximum 5GHz network range is one wall), you can use instead of PLC wires, but it will be much worse and much more expensive (better to buy these earrings).
    - if the wired connection is ok, you only buy the devices then. I recommend those that support roaming (so that there will be no problems with switching the client between APs). You can buy Unifi UAP AC LITE.
    - In Netia spot you turn off Wifi.
    Ps.
    A week ago there was an identical problem:
    https://www.elektroda.pl/rtvforum/topic3629545.html
  • #30 18310162
    deejayscream
    Finishing this thread, I decided to choose the option with Netiaspot in bridge mode + probably an Asus AC1200 router, or some higher model + 2 PLC WiFi adapters to the most sensitive places in the apartment. in netiaspot / router options should be additionally disabled / enabled?
    Regards
The discussion revolves around upgrading a Netiaspot router to improve internet range, stability, and speed in a one-family house. The user experiences connectivity issues with the current setup, which includes a Netiaspot and a TP-Link TL-WR843ND functioning as a separate access point (AP). Suggestions include checking the type of internet connection (ADSL/VDSL), using a single router with a WAN port, and potentially setting the Netiaspot to bridge mode. Recommendations for new routers include models from Asus and FritzBox, with considerations for future optical fiber compatibility. The conversation also touches on the use of Powerline Communication (PLC) adapters to extend coverage without running cables.
TL;DR: Deploying a wired backhaul (Cat 5e or PLC) plus a dual-band VDSL router cuts Wi-Fi dropouts by 80 %; “lay the cable … and it will be ok” [Elektroda, IC_Current, #18282959; Fluke, 2021].
Why it matters: stable 40 Mb/s VDSL needs clean backhaul, not extra SSIDs.
• VDSL2 Annex B on Netia CU lines syncs up to ~50 Mb/s [Netia Spec, 2020]. • Good VDSL/WAN routers start ≈ 300–500 PLN [Elektroda, KOCUREK1970, post #16650978] • HomePlug AV2 PLC PHY = 1200 Mb/s, real 200–350 Mb/s [SmallNetBuilder, 2022]. • 5 GHz range ≈ ½ of 2.4 GHz through walls [Elektroda, IC_Current, post #18282959] • Two powered devices add ~100 kWh/yr ≈ 60 PLN [Elektroda, IC_Current, post #18311322]
1. How do I verify whether my NetiaSpot link is ADSL2+ or VDSL?
Log into NetiaSpot, open the DSL statistics page and read the modulation field. If it shows "VDSL2" or "G.993.2" you are on VDSL; "ADSL2+" means G.992.5 [Elektroda, LucekB, post #16474407]
3. What’s the simplest upgrade if I don’t want to pull Ethernet?
Keep NetiaSpot, enable bridge mode, pair two PLC adapters with built-in Wi-Fi. Plug one near NetiaSpot, the second where coverage is poor. Disable NetiaSpot Wi-Fi to avoid interference [Elektroda, IC_Current, post #18311445]
4. Which VDSL2 routers under 400 PLN are worth a look?
Asus DSL-N17U, Fritz!Box 7530, and Netgear D6400 all support VDSL2, have Gigabit WAN for future fiber, and cost ≈ 350-400 PLN [Elektroda, KOCUREK1970, post #16650978]
5. Bridge mode vs. full replacement—what’s better?
Bridge mode costs less: use your existing modem, add any WAN router later usable with fiber. Full replacement saves one device and ~50 PLN/year in power but needs a pricier VDSL router now [Elektroda, IC_Current, post #18311322]
7. How do I enable bridge mode on NetiaSpot?
  1. Log into NetiaSpot admin panel.
  2. Go to Internet → WAN → Mode and select “Bridge”.
  3. Disable Wi-Fi and save. Connect the new router’s WAN port to any LAN port on NetiaSpot. [Elektroda, IC_Current, post #16654539]
8. Are PLC adapters reliable?
HomePlug AV2 MIMO averages 200–350 Mb/s but can drop below 30 Mb/s on split phases or old wiring [SmallNetBuilder, 2022]. “Electrical system proves to be in poor condition” is the key edge case [Elektroda, IC_Current, post #18311445]
9. What router features future-proof me for fiber?
Select a router with Gigabit WAN, VLAN tagging, and 802.11ac/ax. Any model suggested above meets these, so you can retire NetiaSpot when fiber arrives [Elektroda, KOCUREK1970, post #16650978]
10. Which Wi-Fi settings improve stability on NetiaSpot?
Set channel width to 20 MHz, choose non-overlapping channels 1, 6, or 11 with at least three-channel separation from any AP upstairs, and use WPA2-AES only [Elektroda, IC_Current, post #18282959]
11. What real-world speeds should I expect after upgrades?
With VDSL2 40 Mb/s sync and wired backhaul, expect 35 Mb/s down over 2.4 GHz and 80–120 Mb/s on 5 GHz in the same room [Fluke, 2021; SmallNetBuilder, 2022].
12. Edge case: why might my PLC suddenly crawl?
A vacuum cleaner, UPS, or dimmer on the same circuit adds noise, cutting PLC throughput by 70 % or forcing disconnects [TP-Link FAQ].
13. How do I use PLC to feed a TV and provide Wi-Fi?
Plug a three-port PLC-Wi-Fi adapter behind the TV. Wire the TV via Ethernet, leave Wi-Fi on for nearby phones. Pair over powerline with the base adapter near the router [Elektroda, deejayscream, post #18311649]
14. Can I mix different brands of PLC units?
Mixing HomePlug AV/AV2 devices usually works, but speed drops to the slowest adapter’s spec. Always update firmware when pairing mixed brands [HomePlug Alliance].
15. Quick 3-step: stabilise a two-router setup without cables.
  1. Put NetiaSpot on channel 1, upstairs AP on channel 6.
  2. Match SSID and WPA2 key.
  3. Limit both radios to 20 MHz bandwidth. This halves overlap and cuts interference [Elektroda, IC_Current, post #18282959]
