Hitachi UC18YG Charger Issues: Replaced Burned Resistors and 2SK3567 Transistor, Still Not Charging
mekoy 11655 3
  • #1 16436897
    mekoy
    Rate: 18
    Burned resistors R5-4.7?; R6-470?; R7-1k? and R8-0.68?. Of course, I replaced them and additionally I replaced the 2SK3567 transistor. The charger is still not charging.
  • #2 16448119
    mekoy
    Rate: 18
    There is no voltage to the UC3842BN. Capacitors and diodes are functional.
  • #3 16459167
    TONI_2003
    Moderator
    Help: 2192
    Rate: 3812
    Sure, I'm curious what a miracle you haven't checked, for example R7, R8 is just for the look :cry:
  • #4 17338012
    worys
    Rate: 19
    Because the topic is not closed, let me add that in addition to the above. components must be replaced with UC3842. I had the same case.
    And the reason was the dried 82uF / 400V capacitor.
    The topic can be closed.
