VW T5 2.5 tdi 2005 - ventilation, blower, fan not working in any gear
twigel 10746 2
  • #1 16436911
    twigel
    Rate: 20
    I searched, I found similar ones, but others do not solve my problem
    particulars:
    Front airflow does not work in any gear (rear airflow is not available)
    Manual air conditioning, with parking heater, roof control
    The indicator lights on the buttons indicating the activation of the air conditioning and the internal circuit (air conditioning not filled) also do not work
    good fan, it flashes for a short time
    all fuses checked: engine compartment, under cup holder and driver's seat
    on the fan power supply the meter shows two masses, it has the same masses to the resistor cube
    I read the post @ziemp and from what can be seen under the seat there is no damage to the installation, insulation, etc., except under the floor, and I haven't looked there yet
    what to check next? What should the air supply switch receive?
  • #2 16436915
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    And under the battery next to the engine control unit?
  • #3 16437290
    twigel
    Rate: 20
    if you talk about this box closed with a flap, screwed on two butterflies, yes, I checked
    only those found in the engine compartment
    today I will unscrew the driver's seat with the frame under it to check these cables better
