2005 VW GOLF V 1.6 102HP - Air Conditioning Not Cooling, Small Fan Issues and Solutions
pawel9502 11772 4
  • #1 16524321
    pawel9502
    I am the owner of Golf V, year 2005, petrol 1.6, 102HP. My air conditioning doesn't cool. It was studded, it is tight. Searching the internet for a solution to my problem, I read many times that a small fan must rotate for the climate to cool. I do not spin, but when I warm up the engine at a standstill, the small one turns on with a large windmill. Has anyone had similar or know how to solve the problem? Thank you in advance for your help.
  • #2 16524365
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Both fans should run at the same time as when the car is hot.
    Connect to a computer, see what the errors are, as can be seen in the measuring blocks - e.g. system pressure.
    For example, if the sensor does not see the correct pressure, it will not allow the air conditioning to work.
  • #3 16597939
    pawel9502
    Can the sensor be replaced without losing gas? The system has a valve or just the removal of the sensor all the gas will escape?
  • #4 16597952
    MobilTruck
    Help: 139
    Rate: 965
    You can only do what for. It is cheaper to do diagnostics and check in the parameters whether there is permission to turn on the air conditioning. Write whether it is climatic or climatronic.
  • #5 16603093
    pawel9502
    It's climatic.
