VW Golf 4 1.9TDI AXR 2001 - Air conditioning does not work
Klimanek 4380 3
  • #1 18844766
    Klimanek
    Hello, I have a problem with the air conditioning in the Golf 4 - the manual air conditioning lights up after pressing ac, but the air conditioning and fans do not work. The air conditioning works for a short time, I bridged the pressure sensor, changed the fan module and then nothing, the temperature is good. Someone will help, I do not know where to look for the problem or I have to check the installation piece by piece ...
  • #2 18845084
    sigwa18
    Help: 1194
    Rate: 3354
    Readings from the outdoor temperature sensor what value does it have?
  • #3 18849467
    Klimanek
    The positive temperature is shown as it is in the yard
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4180
    Got a VCDS?
    As in the engine measuring blocks, you can check the air conditioning status.
