YATO YT-36704 Gas Soldering Iron - Unexpected Flame Change After Initial Use
nici 5451 2
  • #1 16437529
    nici
    Help: 266
    Rate: 979
    Hello. I have just received a package with this soldering iron and started to try it out.
    First attempt - ok, it blows nicely, etc. After a minute the flame changed and I extinguished. Another attempt to fire results in the same flame as in the picture.
    What could have happened? I undressed as much as I could but nothing disturbing is visible
    clean everything because new.
    . YATO YT-36704 Gas Soldering Iron - Unexpected Flame Change After Initial Use
    Rysio4001
    Heating systems specialist
    Help: 609
    Rate: 1063
    The flame looks as if the burner is not receiving air, and only gas exits the barrel of the burner instead of a mixture with air.
    Check the burner air inlets are not obstructed and there is no obstruction on the burner air inlet.
    Or maybe something has overheated and melted (e.g. the plastic parts around the nozzle) blocking the air inlets.
    Greetings.
  • #3 16438509
    nici
    Help: 266
    Rate: 979
    I checked everything, buddy, and everything indicates that you are 100% right.
    Rysio4001 wrote:
    Check burner air inlets for obstruction
    checked - OK
    No, it worked about 2-3 minutes after unpacking.
    After contacting the seller, I submitted a complaint. As it is a gas device, I did not want to risk a major accident or explosion.
    Thanks Rysio !!
