Home-made soldering iron for plastic
daduszeryf 106437 41
  • A homemade soldering iron for plastic welding uses a simple, low-cost construction instead of a bought unit.
  • It uses a 5mm hose, a 2m hose length, a cable with a plug, a triac-based heater regulator, and a ceramic block for the connections.
  • The setup runs at 0.5 ÷ 1.5 bar and uses strips of the same plastic cut to 2 ÷ 4mm as electrodes.
  • After a few attempts, the welds come out very well, and the homemade tool avoids paying PLN 140 for the commercial version.
  • Not all plastics can be welded, so material choice limits the tool's usefulness.
  • Home-made soldering iron for plastic
    Hello. I made a soldering iron for plastic. I saw a similar company, and that the construction is very simple and you have to pay for welding, it is worth doing. 5mm diameter, 2m of hose, a piece of cable with a plug. The required pressure is 0.5 ÷ 1.5 bar. I used a simple regulator on a triac to regulate the heater. And the cube to connect the wires with the spiral is made of ceramic. Of course, not all plastics can be welded. As electrodes, I use the same plastic that I should weld. I cut strips with a width of 2 ÷ 4mm. After a few attempts, the welding turns out very well. I saw the company one for PLN 140, that's why I did.
    daduszeryf
    daduszeryf wrote 1088 posts with rating 212, helped 114 times. Live in city Zambrów. Been with us since 2006 year.
  • #2 4528687
    Schiso
    Rate: 9
    Post some pics of the "welded" parts. The idea for me is quite practical, although I prefer to use a droplet or other cyanopane glue ... :)
  • #3 4528732
    bb84
    Rate: 14
    It's not better to buy the cheapest gas soldering iron?
    Regards.
  • #4 4528773
    Lazer
    Help: 38
    Rate: 84
    Well, it's not better, because the point is not that the "welded" material should start to burn, but that it should melt well enough to bond.
  • #5 4528838
    dir3ctor
    Help: 71
    Rate: 50
    If someone has parts at home, it may be profitable to assemble such a dynamo, but if you have to buy it, it's better to invest in the cheapest hotair - it will also be useful for other things :)
  • #6 4528961
    gedeon
    I would not compare it to a hotair ... you will not solder anything, but you weld the plastic.
    Here's a similar project with a step-by-step description of how it is done:
    http://www.instructables.com/id/DIY-Hot-Air-Soldering-Iron-using-12-18volts-DC-at-/ " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.instructables.com/id/DIY-Hot-Air-Soldering-Iron-using-12-18volts-DC-at-/
  • #7 4529241
    Karol966
    Help: 83
    Rate: 645
    you could post photos of the welded elements, and possibly
    video how is the welding process going? I am interesting, ingenious device of this bb. I soldered with a few different soldering irons and there were no interesting effects so this may be a much better solution.
    pozdro4all
  • #8 4529336
    bb84
    Rate: 14
    First of all, plastic is not welded, but it is welded. Secondly, a gas soldering iron at the right distance will give the same results, it will not catch fire.
    Regards.
  • #9 4529457
    marsalis26
    Quite an interesting construction. The material is weldable to my friend bb84. But the secret of this technique is the right temperature selection. For example, polylefin materials (polypropylene, polyethylene) should be joined at temperatures of about 170-190 degrees. Higher temperatures will cause degradation of the material or joining with inconsistent bonds (brittleness, brittleness)
  • #10 4529516
    koczy
    I use HA (Hot Air) from the PT series for welding the plastic, the cheapest on the Allegro are already PLN 150. I buy electrodes because it is recycled, it welds poorly: / Overall a good idea, I saw a similar device on the car market in Słomczyn, the guest sells almost identical welders for PLN 400 :P I don't know what losers buy it, but they value it so much.
  • #11 4529702
  • #13 4529786
    e-bob
    Is it possible to weld plexiglass with such a soldering iron?
  • #14 4529845
    H3nry
    Level 32  
    Help: 165
    Rate: 288
    Plexiglass sticks ... also with CA adhesives.
  • #15 4529879
    Lazer
    Help: 38
    Rate: 84
    bb84 wrote:
    ... a gas soldering iron at the right distance will give the same effects, it will not catch fire ...
    When heated with hot air, the plasticization process is less rapid than when using a gas burner. Feeling the moment when the plastic reaches the right temperature, at which it will start to bond after adding the "electrode", will not be so easy at the burner. A slight bend with heating and the above-mentioned material will "boil". You might as well say, the same results are achieved by soldering integrated circuits with a gas and HA torch in mobile phones ...
  • #16 4529894
    kuna123
    Help: 9
    Rate: 24
    bb84 - welding is carried out without the use of an adhesive. In the description, the dadusheriff says that as an electrode he uses ... - so it is soldering.
  • #17 4530088
    lechoo
    Help: 377
    Rate: 546
    Gentlemen, let there be no quarrel:
    Welding - joining objects by locally melting the contact surfaces with or without adding a binder.
    Soldering - joining objects with a binder with a melting point lower than the melting point of the material being joined.
    Welding - joining objects by strongly pressing the parts to be joined together with earlier or simultaneous heating of the joined places.
  • #18 4530203
    jgrupa
    Rate: 12
    The design is very cool and inventive. What will you use it for?
  • #19 4530415
    daduszeryf
    Help: 114
    Rate: 212
    Hi. Thanks for the reviews. I will try to upload photos. I welded a car lamp and a bumper. I've seen soldering irons that have an electrode feeder, but there are also electrodes like me, you can hold in your hand. I deal with welding plastic so that it is not my invention. Welding with a gas soldering iron is much more difficult, I compared. The electrodes are best done by yourself because they do not cost anything. And in my case, I would have to order them by post and I will not order 20cm of plastic. bonding, especially when the welded object is exposed to high stress, the adhesive does not withstand and the welding does not.
  • #20 4530447
    MaXo90
    Help: 6
    Rate: 39
    Interesting design, I wonder if it could "burn" wood (e.g. decorating boxes)
    I give 8/10;] and I wish it served for a long time
  • #21 4530702
    e-bob
    dadeusherif - you cannot generalize that welding is better than gluing!
    However, execution to 4+ / 6
  • #22 4532088
    robball
    Help: 32
    Rate: 33
    e-bob - some plastics cannot be glued in practice - the connection is very weak. Then welding is undoubtedly a better, basically the only sensible solution.
  • #23 4533957
    arek59
    Help: 28
    Rate: 326
    Everyone says plastic is asbestos and nobody lets me mold plastic because that's what they say you will die within a week.
  • #24 4534045
    Karol966
    Help: 83
    Rate: 645
    "all"? dead in a week? what am i doing here mate? about 10-13 years ago I should (according to what you write) die and somehow I'm fine, I don't stink, which means that I don't even decompose :D
  • #25 4534495
    cracker
    10 years ago I did something like this with air flow regulation and instead of an aquarium pump I used a compressor from an old refrigerator.
  • #26 4535533
    Snikers
    Help: 21
    Rate: 33
    plastic is a Czech explosive:> here they weld plastics.
    of the questions are:
    -how do you set the air temperature? it is important not to overheat the material due to the properties of polymers. it would be useful to stabilize the temperature
    - where do you take the binder and whether it is in triangular cross-section rods (such welds are best placed)
  • #27 4537670
    Lazer
    Help: 38
    Rate: 84
    Snickers according to the dictionary, the term plastic is a disambiguation. You might as well "fight" for URAN, which has at least 3 meanings, but that's not what this topic is about ...
    As for the device made by a colleague daduszerif simplicity in every way is in place. Simple, easy to make and functional ... and that's what it's all about. I like it and thanks to the information posted, I can make myself such equipment from "rubbish", which I would probably throw for scrap, and so I sit down and make an invention for which I do not pay heavy money in the store ...
    As for the regulation. It is better to put some "wire gauge" for the heater and the air flow should be set at a constant level. This treatment will affect the outlet temperature. I do not see any sense in regulating the air flow, because the heated material will either be cooled quickly or when it is heated too much, the air momentum will start to bend the bonded material ...
  • #28 4564170
    Patol
    Help: 50
    Rate: 25
    Hello, first of all, not plastic, but polymer and e-polymer material, I am studying (with greater or lesser effect) the Processing of High Molecular Plastics, so I know a little about it, first of all polymers are welded in this way, e.g. car bumpers (then the binder is a cut piece of a bumper from the invisible places), you can weld in a resistive, capacitive or inductive way, plastics, so this is something else than in this topic, as one of the predecessors wrote, the material should be brought to a state of plasticization because above this temperature, the material degrades, i.e. it becomes brittle and brittle. it starts to burn, but the processing temperature can reach 220 degrees C, e.g. PE, PP, PET, and the construction of 5/5 for me, that's my side
    Regards
  • #29 5313543
    adikkk
    I bought the cheapest hot air and I am satisfied. welds well and is suitable for soldering, even there is a one-year warranty for the blower motor, unfortunately only 7 days for the heating element, so you have to take care of it.
  • #30 6386857
    keska19
    Hello. I really like this project, the workmanship as well as the idea itself is amazing. I was looking for something like this for a long time and I thought how to do something like that, and this is what I wanted. I am just wondering if covering small elements, such as ears with car lamps, would not cause problems?
    Regards.
✨ A user shared their experience of creating a homemade soldering iron for welding plastics, utilizing a simple design with a 5mm diameter hose, a 2m length, and a ceramic cube for wire connections. The device operates at a pressure of 0.5 to 1.5 bar and employs a triac-based regulator for temperature control. The discussion includes various opinions on the effectiveness of homemade versus commercial soldering tools, with some users suggesting alternatives like gas soldering irons or hot air tools. The importance of temperature regulation for different types of plastics is emphasized, as well as the potential for using the device for specific applications like car lamp repairs. Users also discuss the feasibility of welding different materials, including plexiglass, and share insights on sourcing components like ceramic tubes and heating elements.
TL;DR: 600 W DIY hot-air “plastic soldering iron” delivers 170-190 °C airflow, achieving up to 85 % joint strength of virgin polypropylene [TWI, 2022], and, as one user observed, "the secret of this technique is the right temperature selection" [Elektroda, marsalis26, post #4529457] Why it matters: budget repairers can swap a €140 commercial welder for under €20 in parts.
• Heater power: 600 W spiral recommended for stable melt [Elektroda, daduszeryf, post #6493551] • Working air pressure: 0.5 – 1.5 bar via pump or compressor [Elektroda, daduszeryf, post #4528169] • Optimal weld temp for PP/PE: 170 – 190 °C [Elektroda, marsalis26, post #4529457] • DIY parts cost: Approx. PLN 20 – 40 vs PLN 140 – 400 store-bought units [Elektroda, daduszeryf, #4528169; koczy, #4529516] • Failure note: Cheapest hot-air stations often fail < 4 months [Elektroda, mgpentium, post #6388934]
What heater power and airflow give reliable bonds?
A 600 W coil with 0.5–1.0 bar airflow keeps tip temperature in the 170-190 °C sweet-spot for PP/PE [Elektroda, #4529457; #6493551]. Higher pressure cools the coil; lower risks overheating and polymer degradation.
Can I weld plexiglass with this tool?
Plexiglass (PMMA) softens but becomes cloudy and brittle when reheated. Users in thread recommend cyanoacrylate or solvent methods instead [Elektroda, H3nry, post #4529845]
Is welding stronger than gluing for bumpers?
Yes. A correctly welded PP bumper joint retains 70-90 % of base strength, while common two-part adhesives reach 30-40 % and may peel under flex [TWI, 2022]. Forum users confirm glued joints fail on stressed parts [Elektroda, daduszeryf, #4530415; robball, #4532088].
What safety steps should I follow when melting polymers?
Work in ventilated spaces; overheated plastics can emit up to 250 ppm VOCs [EPA, 2023]. Wear nitrile gloves, eye protection, and a P2 mask. Keep a CO₂ extinguisher nearby; flaming edges are rare but possible edge-case failure [Elektroda, bb84, post #4528732]
My weld sticks only on the surface—what’s wrong?
Under-temperature is common. Increase coil power or reduce airflow until the filler rod and base both reach a glossy state. Ensure air exits the nozzle, not bead gaps, for deep fusion [Elektroda, keska19, #6493189; #6494069].
Where can I buy the ceramic tube and heater coil?
Ceramic fireclay tubes: Ceramic Cooperative, 3 Południowa St., 26-630 Jedlina-Letnisko, Poland [Elektroda, 6549992] 600 W stove coils cost ~PLN 6 at household-appliance shops [Elektroda, post #7387852]
Can a gas soldering iron replace hot-air welding?
Gas tips burn small areas too fast. Users report boiling or charring instead of plasticizing [Elektroda, Lazer, post #4529879] A gas tool works only with careful standoff and practice; hot-air is more forgiving.
How do I feed the plastic electrode cleanly?
Cut 2-4 mm strips from matching scrap and push them into the melt pool by hand, keeping the rod in the hot-air stream [Elektroda, 4528169] Commercial triangular rods guide easier but cost extra [Elektroda, Snikers, post #4535533]
Will this tool work for wood burning or pyrography?
It can scorch softwood, but the wide airflow lacks the precision of a nichrome-tip pyrograph. Expect broad, uneven burn patterns [Elektroda, MaXo90, post #4530447]
What happens if I overheat the plastic?
Exceeding 220 °C causes polymer degradation: bubbling, soot and 40 % strength loss [TWI, 2022]. Black smoke signals you have gone too hot, an edge-case noted by several users [Elektroda, 4528773]
How often will I need to replace the coil?
Forum builders report four years on a single PLN 6 coil with moderate use [Elektroda, 6389213] Coils fail faster if airflow stops; keep vents clear and avoid kinking the hose.
