H1Z1 Game Shuts Down Automatically on GTX 1060 after Radeon 270 Gaming Swap
DiiXoX 3522 6
  • #1 16437668
    DiiXoX
    Rate: 18
    Hello. I have a problem with h1z1. Each time after a few minutes, the game turns off automatically without any error. I reinstalled the game, checked the consistency of files via steam, reinstalled the net framework, miscrosoft visual C ++, but to no avail. The problem appeared in my opinion after changing the graphics card from radeon 270 gaming to gtx 1060, because before everything was ok. The card does not overheat, temperature within 55 degrees.
    Please help.
    Computer Specifications:
    1. Intel CORE i5-4460 processor, 3.2GHz, 6MB, BOX (BX80646I54460)
    2. Thermaltake Smart SE Modular 530W power supply (SPS-530MPCBEU)
    3. Western Digital Caviar Blue drive, 3.5``, 1TB, SATA / 600, 7200RPM, 64MB cache (WD10EZEX)
    4. MSI B85-G43 Sc motherboard LGA1150 Intel B85, 4xDDR3, VGA, GbLAN, ATX HASWELL
    5. MSI GeForce GTX 1060 GAMING X 6G 6GB GDDR5 (192 Bit) 3xDP, HDMI, DVI-D, BOX (GTX 1060 GAMING X 6G) graphics card
    6. HyperX Memory 2x4GB 1600MHz DDR3 CL9 DIMM black Series (KHX16C9B1B / 4)
  • #2 16437769
    atomic99
    Help: 171
    Rate: 338
    What temperatures on the processor?
    Did you reinstall the system after changing from [radeon 270] to [GTX1060]?
  • #3 16437826
    DiiXoX
    Rate: 18
    On the processor, wheel 60-63. I did not reinstall the system.
  • #4 16441860
    DiiXoX
    Rate: 18
    I have reinstalled the whole game and the problem persists. Is anyone able to help me?
    Added after 2 [hours] 23 [minutes]:
    After checking the consistency of the files, information appears that two files are missing, but unfortunately the name is not given and they do not want to download again and probably because of this the game turns off. Reinstalling doesn't help
  • #5 16442862
    enhanced
    Help: 963
    Rate: 883
    Run hwinfo64 sensors only, play to disable and insert a screen with all sensors.
  • OCCT failed after 11 minutes, H1Z1 ran 1.5 hours
    #6 16444072
    DiiXoX
    Rate: 18
    I started OCCT to make sure that nothing overheats, but after 11 minutes the error detected error pops out and the program has shut down.
    Temperature after an 11-minute OCCT test
    Then I started h1z1 and, surprisingly, after almost 1.5 hours of playing the game did not turn off. Below I also attach a screen with temperatures after turning off the game
  • #7 16444119
    enhanced
    Help: 963
    Rate: 883
    And why error detected in occt?
The user experiences automatic shutdowns of the game H1Z1 after switching from a Radeon 270 Gaming graphics card to an MSI GeForce GTX 1060 Gaming X 6G. Despite reinstalling the game and various software components, the issue persists. The user reports that the processor temperature is between 60-63 degrees Celsius and that they did not reinstall the operating system after the graphics card change. After running OCCT for stress testing, an error was detected, but subsequent gameplay lasted 1.5 hours without shutdown. The user suspects missing game files may be contributing to the problem.
