Clio 2 '99 Ignition Replacement: Immo Concerns & Key Coding Process
marcinclio2 9327 5
  • #1 16438269
    marcinclio2
    Hi, I will replace the ignition in clio 2 99 r and I have a question if I will not have problems with immo afterwards. Because I heard that I will have to code a new key. Help
  • #2 16438285
    GBW
    Help: 123
    Rate: 293
    If you only replace the metal key bayonet and leave all the electronics, you don't need to code anything.
  • #3 16438286
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6411
    Replace the key plate only.
  • #4 16438297
    marcinclio2
    So it is important that the electrical system with the key was the same anyway? And immo should not be decoded?
  • #5 16438300
    Help: 1404
    Rate: 6411
    It is important that the key you buy has a place for the plate from your current key.
  • #6 16438430
    GBW
    Help: 123
    Rate: 293
    The cars had replaceable metal parts of the key.
