Renault Megane Scenic 1999 - Identifying Memory Chips for Immo Key, Receiver, Central Locking
leszekrrr 5727 10
Which memory chips in the Renault Megane Scenic 1999 immobilizer key, reader loop, and UCH need to be transferred or soldered to fix the immobilizer/c central locking issue?
Only the Motorola 3G96A in the UCH needs to be transferred; the loop is just a reader and has no memory to move, and the key contains only a transponder insert, not a programmable chip on the circuit board [#16364329][#16364998] If you replace the UCH, move the Motorola 3G96A from the old unit to the new one and leave the keys and loop as they are [#16364474][#16364998] The later diagnosis in the thread was that the immobilizer was already off and the real fault was an intermittent crankshaft position sensor connection, not the UCH memory [#16385872]
  • Identifying memory chips for immobilizer and central locking modules
    #1 16364280
    leszekrrr
    Rate: 19
    Hello. Request to identify the memory chips on the plates,
    Immo Key and receiver, central locking controller.
    The problem concerns Reno Megan Scenic 1999.
    The code with immo does not enter, it looks like the central locking controller has failed.
    I have the second immo comlet working and I want to solder the memory, if it is not damaged, it should solve the problem, I do not have access to programming, so it is out.
    • Renault Megane Scenic 1999 - Identifying Memory Chips for Immo Key, Receiver, Central Locking DSC_0801.JPG (1.28 MB) You must be logged in to download this attachment.
    • Renault Megane Scenic 1999 - Identifying Memory Chips for Immo Key, Receiver, Central Locking DSC_0799.JPG (503.22 KB) You must be logged in to download this attachment.
    • Renault Megane Scenic 1999 - Identifying Memory Chips for Immo Key, Receiver, Central Locking DSC_0800.JPG (389.74 KB) You must be logged in to download this attachment.
  • #2 16364329
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Motorola 3G96A in the first photo.
    You insert a new UCBIC module with the old memory, the keys and the loop remain old.
  • #3 16364425
    leszekrrr
    Rate: 19
    I only have to solder
    Motorola 3G96A? I understand well?
    And as for the memory in the key and loops which are chips? Because there may also be a problem there.
  • #4 16364474
    grala1
    Help: 1495
    Rate: 5052
    Hold on.
    What code?
    You will not enter any code there.
    Now I noticed that it is UCH and not UCBIC, i.e. the lifted version.
    Here you do not enter the code with the button from the central or it was gasping.
    Since you have the second set, why solder if the whole thing can be moved.
    If you want to change the UCH itself, you only solder the skein and do not replace anything else, the keys with the loop remain.
    The central lock is managed by the UCH.
    If you think it's his fault, put it back and see if the lock works, how it works, you will do the rest, and if not, you will know that the car is at fault.
    What's the problem with the central locking?
  • #5 16364567
    leszekrrr
    Rate: 19
    The central locking is approx.
    The problem is immo, the engine controller does not receive the immo code,
    I changed the key, loop, and UCH, the immo works from another car, but it is not from this car that the engine controller has not unlocked. So I want to try to solder the memory from a damaged set to a good one. Maybe it will work when the memory is ok.
    Added after 28 [minutes]:
    There are bad voltages coming from the UCH to the immo loop, so I believe that the culprit is the UCH, therefore the request for memory identification in the three elements: key, loop and UCH
  • #6 16364998
    grala1
    Help: 1495
    Rate: 5052
    The loop is only a reader so there is nothing to mention.
    In the remote control you have a transponder, a black rectangle that is only inserted into the housing, it is not on the board with elements.
    You just move the Motorola to the new UCH and nothing else.
  • #7 16365159
    leszekrrr
    Rate: 19
    Thanks for your help as I change the chip. He will say if it helped.
  • #8 16373197
    leszekrrr
    Rate: 19
    After soldering the Motorola 3G96A UCH without any response, what's the problem? Anything else you need to solder in the UCH?
  • #9 16373285
    grala1
    Help: 1495
    Rate: 5052
    You solder something wrong, your UCH or Motorola are damaged.
  • #10 16373443
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Do OFF in Sirius. Because otherwise you won't get it.
  • Intermittent shaft position sensor connection caused fault
    #11 16385872
    leszekrrr
    Rate: 19
    Motorola soldered back to the original UCh, it's ok.
    I solved the problem, it was trivial, the shaft position sensor when I measured it with a meter was ok, but sometimes it lost connection, it just did not get permanently damaged, and as for the immo it was off, but the driver shows the error that the immo code did not enter. The car was damaged and I did not know what and who was going through it.
    Thanks to everyone for your help.
    I close the topic
The discussion revolves around identifying memory chips related to the immobilizer (Immo) key, receiver, and central locking controller for a 1999 Renault Megane Scenic. The user is experiencing issues with the Immo code not entering, suspecting a failure in the central locking controller (UCH). Responses suggest that the Motorola 3G96A chip is crucial for the UCH, and it can be transferred to a new UCH module. The user also inquires about the memory chips in the key and loop, with advice indicating that the loop is merely a reader and does not contain significant components. After attempting to solder the chip, the user resolves the issue by identifying a faulty shaft position sensor, which was intermittently losing connection. The discussion concludes with the user expressing gratitude for the assistance received.
