Lenovo IdeaPad 100-15IBD Laptop Schematic Needed: CG410/CG510 NM-A681 Rev 1.0 UMA
silny15 18636 11
Where can I find a schematic or service manual for the Lenovo IdeaPad 100-15IBD motherboard CG410/CG510 NM-A681 Rev. 1.0 UMA?
No exact schematic for this board was found in the thread; the closest reference is a blended service manual based on NM-A311, and one reply says the service manual is attached [#16440084][#16440122] The board was identified as using an nVidia N16V-GM-B1 GPU, i3-5020U, IT8586E KBC, OZ8682L charger, SY8286B/SY8286BRAC standby PU200, and a second SY8286? rail for PU201 [#16440084] For a power-supply fault, the charger OZ8682L is the key IC to study, since it is also used in Quanta JW2 UMA Intel Chief River and its working circuit is shown in Quanta JW6/JW7/JW8 service manuals [#16440102][#16440166]
  • #1 16439785
    silny15
    Conditionally unlocked
    hello I need a schematic for such a laptop
    Model Name: Lenovo IdeaPad 100-15IBD
    Platform: CG410 / CG510 NM-A681
    Rev: 1.0
    UMA
    in the attachment a photo of the plate
    I am asking for help in advance thanks to the rafał
    • Lenovo IdeaPad 100-15IBD Laptop Schematic Needed: CG410/CG510 NM-A681 Rev 1.0 UMA f_0030236.jpg (149.79 KB) You must be logged in to download this attachment.
  • #2 16440084
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    There is not, as yet.
    Blended SM from NM-A311
    Read Link_ Elvikom
    CG410 / CG510 NM-A681 Rev: 1.0 based on:
    - GPU: nVidia N16V-GM-B1
    - i3-5020U (SR240)
    - IT8586E kbc
    - charger is OZ8682L
    - stby PU200: SY8286B / SY8286BRAC (3.3V) (* AWV5ka code)
    * and PU201 SY8286? (5V)
    other:
    PU501 NB685GQ / (code: AKUF) VTT
    6 pin (VDDQ) - 1.35v
    5 pin (VTT) - 0.675v
    PU908 NCP811101
    PU701 SY8868QMC (code: KT5WC)
    * photo. both sides of MB (good HD) on Link_ Click on fot_Zoom
    Lenovo IdeaPad 100-15IBD Laptop Schematic Needed: CG410/CG510 NM-A681 Rev 1.0 UMA Lenovo IdeaPad 100-15IBD Laptop Schematic Needed: CG410/CG510 NM-A681 Rev 1.0 UMA
    PL501 - 1.35V
    PL701 - 1.05V
    PL705 - 0.9V
    PL706 - 0.9V
    PL9 - 1.8V
    ps
    What is your "problem" in?
  • #3 16440098
    silny15
    I mean power supply
  • #4 16440102
    lisek
    Help: 6352
    Rate: 6883
    charger is OZ8682L
    Search for info on the forum.
    Used in Quanta_JW2_UMA_Intel_Chief_River, SM available / p.25
  • #5 16440110
    silny15
    I was looking for and I can not find any pattern if no one really has a schema
  • #6 16440122
    lisek
    Help: 6352
    Rate: 6883
    * you have SM in annex
    • Quanta_JW2_UMA_Intel_Chief_River_Rev1A.pdf (1.24 MB) You must be logged in to download this attachment.
  • #7 16440142
    silny15
    is there really a whole scheme for this paw ???
  • #8 16440166
    lisek
    Help: 6352
    Rate: 6883
    This is what I wrote in: # 2 27 Apr 2017 14:16, Yes.
    The rest of the same systems with SM other laptop manufacturers.
    The OZ8682 work system is shown in this SM Quanta_jw6, _jw7 link
    * also JW8
  • #9 16440223
    silny15
    ok, if I do not know something, I will write on pw
  • #10 16598126
    zedix
    Rate: 30
    not deviating too much from the subject, does anyone know where in pl you can get this charger OZ8682L ??
  • #11 16598152
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Only ALI, EBAY.
    If it is not super urgent, I can add to the order.
  • #12 16614256
    silny15
    Topic is closed
The discussion revolves around the need for a schematic for the Lenovo IdeaPad 100-15IBD laptop, specifically the CG410/CG510 NM-A681 Rev 1.0 version. Users share insights about the absence of a dedicated schematic, suggesting that it may be based on similar models like the NM-A311. Key components mentioned include the nVidia N16V-GM-B1 GPU, Intel i3-5020U processor, and various power management ICs such as SY8286B and SY8868QMC. The charger model OZ8682L is also referenced, with suggestions for sourcing it from platforms like AliExpress and eBay. The conversation concludes with a user indicating they will follow up privately for further assistance.
