Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information
R@F@L 11661 14
Why does a Lenovo T450 show that it is charging even though the battery does not charge, and is there a motherboard schematic for this board?
The thread says the motherboard schematic was not available, so the fault should be traced in the charging section directly [#16525869] Check whether the battery itself is healthy and whether the system detects its absence correctly [#16525451][#16525806] Measure the charger voltages and inspect the charger path, especially the BQ24760T/BQ24765-related circuit and its SMBus communication [#16539309][#16539333][#16542218] One suggested failure point is the 10-ohm resistor feeding the BQ circuit; if it is damaged or drifting high, the board may show the usual symptoms but not charge correctly [#18268565][#19272575] Also inspect the internal battery, because one report says removing a worn internal battery restored charging on a T450 that would not charge or start from the adapter [#20118476]
  • #1 16525405
    R@F@L
    There is no charging. The system shows that it is charging.
    Does anyone have any schematic for the above CD?
  • #2 16525451
    michalek1988
    Help: 68
    Rate: 181
    Are you sure that the battery is operational?
  • #3 16525464
    R@F@L
    because I have the same disc on which there is no picture and if I insert these two batteries into this disc, the batteries (external and internal) will be charged
  • #4 16525806
    michalek1988
    Help: 68
    Rate: 181
    You will not find the motherboard scheme, you only have to check the integrated circuits one by one. Without a battery, it normally detects the lack of it?
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    The diagram is not available at the moment.
    Upload photos from both sides in HD, provide the cast of key components.
    The results of the measurements made are welcome.
  • #6 16538418
    R@F@L
    Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Give voltage measurements from the charger.
    What is this mysterious cord?
    BQ24760T charger comparison across Lenovo NM-Axxx boards
    #8 16539333
    lisek
    Service technician RTV
    Help: 6354
    Rate: 6885
    T450 NM-A251 rev.1.0 under i5-5300U (SR23X) / i7
    You have the model: EU (Systemboard 00HN525) or ver. from the USA?
    - kbc SMSC MEC1633L-AUE / or MEC1619L-AJZP
    - you have two Flash cards or one
    Read about other platforms in this series NM-Axxx based on the same charger_connector: U7 BQ24760T , housing: QFN40 (4x 10)
    - I wrote about him on the occasion of the Skylake platform
    Page, from cpu / * (SoC, all in one) and charger U7 Link
    ps
    You do not have a warranty?
    This is a new model from the middle of 2016.
    Model
    Lenovo ThinkPad X240
    VIUX1 NM-A091 Rev: 1.0, 2013-04
    was on kbc (MEC1633L-AUE) and the same i5-5300U
    - Lenovo ThinkPad X240. FRU: 04X5162, i7-4600U
    - Lenovo ThinkPad X240. FRU: 04X5168, i5-4300U
    * LA-A901p, same cpu
    See page 40, Wisstron Storm platform, cpu: Ivy Bridge ULV + HM77 chipset
    - charger bq24760 / without the letter T
    - look if there are differences in the pins
    - I will check tomorrow at work
  • #9 16542156
    R@F@L
    KBC-MEC16133L-AUE
    Charger - BQ24760T
    Charger changed into another and the same.
    There is no guarantee.
    Attachments of photos and voltage measurements. The voltages in brackets refer to the board in which there is charging and there is no picture. Voltages without brackets - the image board works and has no charging.
    The BIOS from the disc that has the image has been played to a disc that has no image and is the same.
    Cable - one path was damaged and restored on the wire.
    lisek
    Help: 6354
    Rate: 6885
    And what about the field in cz. responsible for charging Aku?
    Look at the Aku zloty, or the Battery Input chip
    This BQ communicates on the SMBus bus
    Load datasheet on
    - BQ24765
    SMBus-Controlled Multi-Chemistry Battery Charger With Integrated Power MOSFETs
    Link
    * similar BQ24770 Link
    - or BQ24730RG (QFN40)
    On the org BQ24760 / 24760T has no datasheet , enclosure QFN40 / LDQFN-28
    Look p.39-40 SM for the platform Wistron_Storm Link_ Wistron_Storm
    The same charger together with the system. Battery Input
    showing in SM from IBM, the Wistron platform. Dasher-2
    (LDB-2 91.4RA01.001)
    • Battery_Charging_Technology.pdf (2.1 MB) You must be logged in to download this attachment.
    • bq24765.pdf (1.54 MB) You must be logged in to download this attachment.
  • #11 18257588
    okbalord
    hi
    need the bios bin please
  • #12 18268565
    pragmantic
    see if this BQ circuit .... gets VCC power supply through a 10 ohms resistor ... should have 19V on the crash if not replace this resistor they like to burn ... that's exactly what I exchanged for lenovo flex 3 15 days ago; the resistor had 500 ohms!
    Added after 5 [minutes]:
    I found the T460s diagram and it helped me ...
    • Lenovo ThinkPad T460s BT460 LCFC NM-A421 V8.04.pdf (1.09 MB) You must be logged in to download this attachment.
  • Internal battery removal fixed charging issue
    #14 20118476
    n_507
    Excavations - but maybe it will be useful to someone.
    I had a problem, the T450 won't charge and won't get up under the power supply - reason: used internal battery - removing the internal battery did the trick.
    On the occasion of the question about the diagram of the board, I recently came across something like this (unfortunately for 4.5 EURO)
    Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information Lenovo T450 Motherboard NM-A251: Charging Issue & Seeking Schematic CD Information :
    https://realschematic.com/shop/11053/desc/lenovo-thinkpad-t450 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://realschematic.com/shop/11053/desc/lenovo-thinkpad-t450
    The same on Polish - here PLN 12:
    https://www.elvikom.pl/schemat-lenovo-thinkpa...cfc-aivl0-nm-a251-nm-a252-cobain2-t58957.html " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://www.elvikom.pl/schemat-lenovo-thinkpa...cfc-aivl0-nm-a251-nm-a252-cobain2-t58957.html
The discussion revolves around a charging issue with the Lenovo T450 motherboard (NM-A251), where the system indicates charging but does not actually charge the battery. Participants suggest checking the operational status of the battery and the integrated circuits on the motherboard. They note the absence of a schematic for the motherboard and recommend uploading high-definition photos of the board for further analysis. Voltage measurements from the charger are requested, and several users share insights about potential faults, including a burnt resistor in the charging circuit. Some users mention the importance of the BQ24760T charger and provide links to resources for obtaining schematics. The conversation highlights troubleshooting steps and component checks necessary to resolve the charging issue.
