Siemens SN66T050EU Dishwasher: Error e:09, Heating Circuit Issue, Heater Testing & Schematics
kemotz 6690 2
  • #1 16440504
    kemotz
    Rate: 11
    The Siemens dishwasher refused to obey. Looks like a problem with the heating circuit. I dismantled the dishwasher, located the electronics and the pump heater.
    Unfortunately, I do not have a connection diagram and do not know how to measure the heater to eliminate the problem with the control electronics.
    I would add that the dishwasher behaves unchanged when I disconnect the Red and PE cables going to the heater.
    A request for a schema and advice on what to do about it.
    How to measure the output from the control system? Should he give 230 to the heater? Which contacts?
    Thanks in advance!
    Greetings,
    Tom.
    • Siemens SN66T050EU Dishwasher: Error e:09, Heating Circuit Issue, Heater Testing & Schematics IMG_1379.JPG (518.03 KB) You must be logged in to download this attachment.
    • Siemens SN66T050EU Dishwasher: Error e:09, Heating Circuit Issue, Heater Testing & Schematics IMG_1381.JPG (680.6 KB) You must be logged in to download this attachment.
  • #2 16440534
    kemotz
    Rate: 11
    I searched and found https://www.elektroda.pl/rtvforum/topic2377022.html
    I'll be measuring soon ...
    Added after 8 [minutes]:
    Heater contact nearest NTC has a break :-(
    Do you have any tips on dismantling?
    Greetings!
    Added after 5 [minutes]:
    I will try according to the instructions:
    https://www.youtube.com/watch?v=Fy-STgHpHJk&t=1s
    Added after 3 [hours] 24 [minutes]:
    I already know that I will never buy anything from the Siemens / Bosch logo. The heater has burned ... Siemens SN66T050EU Dishwasher: Error e:09, Heating Circuit Issue, Heater Testing & Schematics
  • #3 16474014
    kemotz
    Rate: 11
    After replacing the heat exchanger with Siemens 654575 and reworking the wiring, the dishwasher works correctly.
