Audi A3 8P coding the key - immobilizer id48 tp25 coding the key
jackq 33894 11
Why won’t a second TP25/ID48 transponder code to my 2007 Audi A3 8P with the PIN and VCDS, even though the original key works?
A PIN plus VCDS is enough only if the transponder is already correctly pre-coded from the car’s immobilizer data; otherwise the key will not add and you need the right pre-coding/CS data first [#16487901] [#16473678] One reply suggests trying a clean ID48 crypto transponder without Audi pre-coding, because the pre-coded ones may need a 7-bit CS upload before the car will accept them [#16451546] In practice, this means the problem is likely not VCDS alone but the way the new transponder was prepared, so you need either a properly prepared blank transponder or a specialist with equipment that can read the immobilizer data and pre-code the key correctly [#16473678] [#16451546]
  • #1 16451501
    jackq
    Rate: 26
    Hello colleagues.
    I have a problem with encoding the key in the audi a3 8p 2007.
    I bought a stimulant with the same number as the old one and a new clean pre-coded TP25 transponder with alle.
    I drove to the doriaczer to encode the key (I did not know the PIN code).
    He failed to get his fancy, Super VAG, remove the PIN code from the meter (after a while there was an error), but it went from the engine driver - the 5-digit pin code I know.
    During the procedure of adding the key, the latter (added) does not want to encode.
    It looks like the meter's display (ori key inserted in the ignition switch) shows 1/2 (key number 1 coded) and after inserting the new one, SAFE jumps in after a few seconds.
    I tried to do the same with my vcds 12.12 rice cable. With the same effect, I am doing according to the procedure ross tech wiki (immo iv key matching), the pin code is correctly adopted in immo, I go to adaptation, channel 01, change the number of keys to 2, the first has already coded, I put the second and again SAFE. Only the 1 old works.
    I checked the key in vcds, according to wiki-ross tech tips, it looks like ok. Dorabiacz also checked this key (transponder), his razor showed that it is ok. He also tried on another his pre-coded immo tablet - the same effect.
    Screen from vcds:
    operating key
    new key
    The only option for SAFE to disappear is to select the number of keys 1 and encode only the 1 old one.
    The pilot coded without a problem, super vag.
    I am asking for advice on what to do next.
    Do you want to look for another magician for the keys, or can I make it through myself, are these transponders bad or the equipment too weak?
    What else could I check. I care about adding a second key, if you can do it yourself.
    Thanks in advance for your help ;)
  • #2 16451540
    spinacz
    Help: 1204
    Rate: 2654
    And you tried the new transponder without adding the old one first?
    If it is not possible, something with the transponder is wrong.
  • #3 16451546
    jackq
    Rate: 26
    I tried this new one, it is not the first mode at all. I'm wondering that we tried two beans from different sources and it does not work on both, maybe these beans have to be prepared in some other way.
    edit:
    I have read even more and write yes, or try a clean 48 crypto without pre-coding for an audi or you need a 7-bit CS to "upload" to the tablet.
    With this second option I do not even know if I will find someone in Bielsko: /
  • #4 16473678
    Queens
    Help: 5
    Rate: 17
    In this car, you can put in a PIN ...
    You will not add a key or VCDS or know what.
    IMMO block read devices.
    Equipment for transponder pre-coding based on IMMO.
    Downloading to the car.
    So much philosophy. You need the right equipment and knowledge, but if anyone has it and knows how to use it. :D
  • #5 16487901
    szogun0
    VAG group specialist
    Help: 135
    Rate: 547
    If the transponder will be pre-coded on the basis of Immo data, it is enough to use the PIN and VCDS to add the key.
  • 7-bit CS coding quoted at 200 PLN
    #6 16503550
    jackq
    Rate: 26
    I found a guest in Bielsko what is overwhelmed by such themes but for coding the 7-bit CS tablet with immo cries 200pln, and that's a gentle slight inflection.
    I understand that equipment costs a little, but let's not go crazy for 5 minutes.
    For now, I do not smoke, more important expenses. Thanks for all the answers. Greetings.
    Moderated By CameR:
    Reg. 3.1.17. Do not present the attitude that I am due. Take care of the level of questions and discussions. Thank you.
  • #7 16503648
    spinacz
    Help: 1204
    Rate: 2654
    Is 5 minutes or 5 hours knowledge and equipment also counts so I do not think that this assessment of the person is right, it is the protection of the car and not the replacement of the bulb.
    Everyone would want everything for free, and that someone has spent a lot of money on equipment and for example to train a person, everyone has somewhere, and the time of doing so does not matter.
  • Disagreement over pricing for key coding
    #8 16504047
    jackq
    Rate: 26
    And here, in my opinion, you are mistaken. Because if everyone thought so, the bread would be 500 zlotys.
    He does complicated things himself on very expensive machines and if I sang 200pln for a 5-minute client, I would go to dry muzzle ...
    I will look for another professional, that's what.
    Moderated By CameR:
    Reg. 3.1.9. Do not be ironic and do not be mean to the other side of the discussion. Respect different opinions and other opinions on the forum.
  • Key coding pricing and equipment cost argument
    #9 16504130
    adrian1201
    Help: 128
    Rate: 416
    On the car you gave 30 thousand maybe more and you're on the key for 200 PLN mockery. How would I make these 10 keys a day I would pay 50 PLN + the cost of materials could be done and so lie later buy a piece of equipment that sometimes did not even pay. Besides if the guest does it with zedful and probably the same tokens for PLN 100 will get and go out that it will earn PLN 100, that's also a lot of you.
  • #10 16504146
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Apparently you have h .... customers.
    Coming back to the topic the answer is simple, you go to the guest what the system plays and you provide the service and you have another launching transponder.
    There is no other way.
  • #11 16504249
    adam7009
    Help: 656
    Rate: 1635
    the matter is simple You do not need this key simply because it is too much for you.
    But how would you lose the last key and 500 PLN would give and thank you that someone can start the car.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • Cheaper key coding quote of 70 PLN
    #12 16504256
    jackq
    Rate: 26
    Ordinary common sense does not allow you to pay someone two hundred dollars for coding yourself. For adding the key, he wants 100. This is a guest on the wave ... hehehe.
    I respect that he spent money on equipment and had to train, but there are certain limits of common sense. It announces where it can, that is, customers probably - I am not surprised at the prices presented.
    I called myself to the point and it is possible to do it cheaper because you asked for coding 70 PLN.
    In spite of everything, I wish you a nice day, I think it's exhausted. greetings
The discussion revolves around the challenges of coding a new key for a 2007 Audi A3 8P, specifically regarding the use of a TP25 transponder. The original poster encountered difficulties when attempting to encode the key, as the process failed despite having the correct PIN from the engine control unit. Various suggestions were made, including the need for a clean 48 crypto transponder and the importance of proper pre-coding based on IMMO data. The conversation also touched on the costs associated with professional key coding services, with opinions varying on the fairness of these charges. Ultimately, the consensus is that specialized equipment and knowledge are crucial for successful key programming.
