Diesel Fuel in NAC Gasoline Lawn Mower: Smoking, Squeaking, and Won't Start - Solutions?
Trawniczek55 22524 8
  • #1 17127047
    Trawniczek55
    Hello! I poured diesel fuel into the NAC mower where gasoline is poured. I mowed the plot a few times with it, it was smoking terribly, but I didn't care about it. Eventually the day came that it went out for me and refused to fire. It fired, but it squeaked loudly, so I turned it off and it doesn't fire at all anymore.
    Anyone know what to do? Service? Scrap? I don't want to pay money ...
    Moderated By T5:
    3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and a brief description of the fault.
  • #2 17127072
    ryba884
    Level 19  
    Help: 33
    Rate: 49
    So if you don't want to cash out, why did you pour oil instead of gasoline? I would undress and clean the fuel system with carburetor and candles, pour gasoline and check if it starts.
  • #3 17127092
  • #4 17127097
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. What model of NAC mower?
  • #5 17127246
    rs07
    Help: 33
    Rate: 166
    I also had an adventure with diesel fuel unknowingly poured into a NAC mower.
    After adding fuel, I fired it, but after a while it started to work and smoke strangely. I release the brake to stop her, but she keeps walking. I don't know what to do, I took the pipe off the candle, it goes on. Only when I ran into some thickets it strangled her. After pouring diesel fuel and filling in gasoline, it started without any problems and it continues today. But for me, she only worked on diesel for a few minutes.
  • #6 20171108
    rafal19052
    It is unrealistic for her to work a few seconds without a candle.
  • Drain fuel and clean carburetor after diesel contamination
    #7 20171126
    60jarek
    Help: 88
    Rate: 508
    Pour out the fuel, clean the carburetor, spark plugs, check if it works, otherwise seized.
    I think it will work after thorough cleaning.
    You have imagination ha ha!
    A, D March 25, 2018 -We repair it after many years.
    The author of the topic will be surprised - the question is whether he is still alive, judging by the last login "Last Visit: 29 Oct 2019".
  • #8 20171127
    r103
    Level 37  
    Help: 283
    Rate: 968
    At the beginning of:
    Finally, the addition of diesel fuel to gasoline significantly lowered the octane number and increased the propensity of the fuel to self-ignition, quod erat demonstrandum ...
  • #9 20171321
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Replace the candles at the beginning .......
The discussion revolves around a user who mistakenly filled a NAC gasoline lawn mower with diesel fuel, leading to severe smoking, squeaking noises, and eventual failure to start. Responses suggest cleaning the fuel system, including the carburetor and spark plugs, and replacing the spark plugs as potential solutions. One user shared a similar experience where they successfully restored their mower by draining the diesel and refilling with gasoline. Concerns about lubrication and engine seizure were also raised, indicating the potential for serious damage if not addressed promptly.
