New Firmware Installation Guide: Transformer TF101 Android 4.0.3 to V9.2.1.27 (WW) - Wi-Fi Fix
De Niro 7704 10
How can I install a newer Android version on a Transformer TF101, and will it help with the Wi‑Fi startup problem?
To get a newer Android on the TF101, you need to install a community custom ROM from XDA using a custom recovery; ASUS support ended at Android 4.0.3 [#16447703] [#16447779] [#16447871] The process is reversible, and Polish language should be available if the ROM supports it [#16447779] The replies mention that community builds exist roughly up to Android 6.0.1, and one user installed a custom 4.4.4 ROM because the stock firmware had trouble with newer Google services [#16447779] [#16447871] There is no guarantee this will fix the long “Enabling Wi‑Fi” startup, because that problem was not seen on the manufacturer ROMs and may be hardware-related [#16447779] If you are not comfortable flashing recovery and a custom ROM, it was advised to stop and not risk damaging the tablet [#16447779]
  • #1 16445788
    De Niro
    Hello, I have a Transformer TF101 on Android 4.0.3 and build IML74K.WW_epad-9.2.1.24.20120503 where the Wi Fi device is loading for a very long time about 30 minutes there is a message Enabling Wi-Fi> I wanted to install Version V9.2.1.27 (WW ) and I would like to ask you how to do it, best regards
  • #2 16445979
    gradek83
    Help: 929
    Rate: 2099
    And on manufacturer's website did you find such information?
    • e6754_TF101_Update_SOP.pdf (1.17 MB) You must be logged in to download this attachment.
  • #3 16447569
    De Niro
    Hello, I was able to install the versions Version V9.2.1.27 (WW) but the problem still occurs with Wi-Fi, i.e. long startup with the displayed message "Wi-Fi enabled .."
    And with applications such as youtube, firefox, chrome
    Youtube only works on version 3.5.5
    Firefox version 53.0, after starting the message "TA version of firefox cannot run on this device armeabI-v7a, 15)" and restart.
    Browser Chrome pley store is not displayed.
    What can be done in this case, maybe some new Android?
  • #4 16447703
    jmnlabs
    Level 19  
    Help: 40
    Rate: 50
    If you are feeling adventurous, you can install a custom rom from XDA:
    Link
    Link
    Link
  • #5 16447725
    De Niro
    is the process reversible? will there be Polish?
  • #6 16447779
    jmnlabs
    Level 19  
    Help: 40
    Rate: 50
    The answer to both questions is yes.
    You need to read what and how, because there is a possibility of damage to the equipment.
    Generally, you will need this to start with:
    Link
    to upload your recovery and then use it the custom rom you are interested in.
    I warn you once again - if you feel that you cannot handle it, let it go.
    I have been doing it quite a long time, but doing everything as described it is not difficult.
    Although I am wondering about the WiFi problems you describe, I did not have such problems on the manufacturer's roms, is it a hardware problem?
  • #7 16447792
    De Niro
    but Wi Fi starts after a few minutes, if Wi Fi is turned off and then we want to turn it on, is it possible to upload a newer version of Android
  • #8 16447871
    jmnlabs
    Level 19  
    Help: 40
    Rate: 50
    I have already replied that it is. The manufacturer's support ended with Android 4.0.3, newer versions probably up to 6.0.1 are currently being developed by the community - the so-called I wrote custom rom about them. I installed the custom version 4.4.4 myself due to problems with the compatibility of the factory firmware with new versions of Google services.
  • #9 19088121
    MichałS
    Help: 256
    Rate: 681
    Question to be more knowledgeable about the topic.
    Does it make sense to install a higher version of Android on this hardware? Now I have 4.0.3
  • #10 19088169
    gradek83
    Help: 929
    Rate: 2099
    If it is available, it is. A lot of newer applications require a newer android.
  • #11 19088522
    MichałS
    Help: 256
    Rate: 681
    OK thanks.
    Then, looking at the TF101 specification, install Android 6 or 7?
    Second question, the process is reversed? In this version (4.0.3) the tablet works smoothly and without sticking.
✨ The discussion revolves around the installation of firmware version V9.2.1.27 (WW) on the Transformer TF101 tablet, which is currently running Android 4.0.3. The user experiences prolonged Wi-Fi activation times and issues with various applications post-update. Responses suggest exploring custom ROMs from the XDA community as a potential solution, with warnings about the risks involved in the installation process. Users confirm that newer Android versions (up to 6.0.1) are available through community support, which may resolve compatibility issues with modern applications. The reversibility of the installation process is also addressed, indicating that users can revert to the original firmware if needed.
