Samsung Galaxy Tab 10.1 P7500: Upgrade to Newer Android Version, Safe Methods & Sources
DarekRz4 30747 10
How can I safely upgrade a Samsung Galaxy Tab 10.1 P7500 to a newer Android version, and where can I get the files?
There is no official newer Android for the Galaxy Tab 10.1 P7500; the only option mentioned is a custom ROM from XDA [#16489619][#16489644] Before flashing, install Odin and use it to put CWM or TWRP on the tablet [#16489644] Then boot into TWRP, wipe/reset the device, copy the ROM to the SD card, and install the ROM from TWRP [#16500946] After that, flash GApps through TWRP as well, and finally install SuperSU via TWRP if you want root access [#16500946] The thread points to an XDA development thread with an Android 6.0 Marshmallow ROM for this device as the source [#16489644]
  • #1 16489523
    DarekRz4
    Help: 20
    Rate: 163
    I got a tablet like that in the subject. It is fully functional and in perfect condition. I would like to use it, however, the old android 4.0.4 from a few years ago prevents me from installing some browsers or applications. I am looking for and I am looking and I can not find anywhere how to safely upgrade my system to a newer version of android. I did not even find it on the Samsung website. (I do not know maybe I can not look), but I have not found a description of how to do it and where to download the new version. Maybe one of my colleagues will help and show you how to do it ??? The menu does not find an update I do not know why despite having found information from a few years ago that Samsung has released an update to a much newer version.
    ps. I found something like that, but I'm worried if it suits me ??
    http://www.droidword.com/2016/01/04/update-sa...xy-tab-10-1-p7500-to-android-6-0-marshmallow/
  • #2 16489619
    nutergsm
    Help: 1034
    Rate: 1665
    There is no official newer android on this tablet. All you have to do is download some costom roma.
  • #3 16489628
    DarekRz4
    Help: 20
    Rate: 163
    How to do it and where to download it ??
  • #5 16489655
    DarekRz4
    Help: 20
    Rate: 163
    Thank you very much.
  • #6 16500843
    DarekRz4
    Help: 20
    Rate: 163
    Well, again. I have to root it to upload by Odin CWM then download android on PC and upload it to the card? Please step by step ...
  • #7 16500946
    nutergsm
    Help: 1034
    Rate: 1665
    You have a description after all in the link I provided.
    You install TWRP from Odin. You start TWRP and you reset the settings.
    You upload the rom into the memory card and install it via TWRP.
    Then you install gapss (google apps) also via TWRP.
    At the end, you install SuperSU via TWRP.
  • #8 16501031
    DarekRz4
    Help: 20
    Rate: 163
    Ok, I know everything. Tomorrow I will try to do it.
  • #9 16524656
    DarekRz4
    Help: 20
    Rate: 163
    Managed to. Admittedly, I'm not just a colleague who has done this several times. He stated that it can only be updated to 4.2.1. The above supposedly can not be anything that would not mean ......
    In any case, the tablet works much more efficiently than before. There is one problem I did not write about earlier because I thought it was related to an outdated version of android or some errors. As the tablet will be charged up to 100% it works perfectly until the battery charge drops to 50-35%. Then it turns off suddenly without warning and you can not turn it on. It behaves like the battery has died. As I connect it to the charger, it can be switched on normally and everything works, however, if I unplug the charger after a moment of charging, it turns off after a few seconds as before. It has to go through the normal loading process to 100% to make it work again. Question to colleagues. Is this the problem of a damaged battery or can you do something about it with the service level? This is not a question of the new android because earlier this problem also occurred.
    pozdr.
  • #10 16524665
    nutergsm
    Help: 1034
    Rate: 1665
    It looks like a faulty battery. To be 100% sure you have to replace it with a new one.
  • #11 16525655
    DarekRz4
    Help: 20
    Rate: 163
    OKAY. Thank you very much.
    Greetings.
The discussion revolves around upgrading the Samsung Galaxy Tab 10.1 P7500 from Android 4.0.4 to a newer version. Users express difficulty in finding official updates from Samsung and seek guidance on safely installing custom ROMs. A recommended method involves using Odin to install TWRP recovery, followed by downloading and installing Android 6.0 Marshmallow from a provided XDA Developers link. Users share their experiences, including a successful upgrade to Android 4.2.1, but one user reports issues with the tablet shutting down unexpectedly when the battery drops below 50%. Responses suggest that this may indicate a faulty battery requiring replacement.
