ASUS Transformer T100TA - software problem with battery charging
Arteq81 6543 3
  • Battery likely not being detected by Windows or BIOS
    #1 16623597
    Arteq81
    Request for help. I have a problem with Asus Transformer T100TA tablet. Namely, under Windows does not charge the battery. Even as if it does not recognize the charger.
    The problem was the same on the old battery. That is why a new one was bought. After replacing the battery, I connected the charger without turning on the tablet. The battery has charged because the charger has become hot. After 12 hours the charger was no longer charging (it was cold).
    After starting the tablet, a battery icon with a red X appeared.
    I can't update even the BIOS (even from the BIOS) because the battery level is detected too low.
    What may be the problem ?
    I deleted the driver from Device Manager. Nothing helped.
    The tablet on the charger itself does not work after disconnecting the battery.
    Someone will help how to deal with it.
    PS I will add that even though the battery shows 0% charge / discharge, the tablet works normally on it. Download updates are installed. Works normally.
  • #2 16623703
    nutergsm
    Help: 1034
    Rate: 1665
    It looks like a problem with the driver. You need to find the right one and install it. I had the same on another tablet and only the appropriate driver did the trick.
  • #3 16624732
    Arteq81
    I have tried all available ASUS drivers. Unfortunately, this did not work.
    I did all the recovery. Also to no avail.
    But if the charger (as if) is not detected by the BIOS, then there may be something with the Bios hardware?
    I would love to mention it, but it can't be done in this situation.
    "EASY FLASH" does not allow:
    "Initialize
    Please plug in BATTERY and its remaining capacity should be more then 20% !!
    System dosn't permint flashing BIOS !! Please press any key after plug in BATTERY !! "
    What's next ?
  • #4 17510168
    Arteq81
    For posterity.
    Asus has hit the site - motherboard malfunction. After repair, everything began to whisk.
