Connecting Refrigerator to Power: Can I Use a Splitter Instead of Wall Outlet?
dwmt 20787 7
  • #1 16448760
    dwmt
    The manual says that the refrigerator should be connected to the wall. Can I connect it to an extension cord (or rather a splitter, what about now) and then to contact?
    It is an extension cord without any cable. Only connection to a contact and a sort of adapter, splitter. In the sense of making one contact two, but without any cable.
    vodiczka
    Help: 1185
    Rate: 4311
    You can, the fridge is not an oven. :)
    Attention: If the refrigerator has a plug with a protective contact, then both the wall contact and the distributor must have protective pins / contacts.
  • #3 16448791
  • #4 16448794
    dwmt
    These are the pictures? Connecting Refrigerator to Power: Can I Use a Splitter Instead of Wall Outlet?
  • #5 16448839
  • #6 16448849
    vodiczka
    Help: 1185
    Rate: 4311
    dwmt wrote:
    Tell me yet an experienced buddy what is a protective contact
    Explanation for the layman: This is a hole in the plug that the socket or splitter pin goes into - you can see it in your photo above the black plug :)
    If you know ELEKTRONICE, you should also know protection against electric shock.
  • #7 16448860
    dwmt
    Ok, photos are there.
    Is it ok or change something?
    I understand that this way I can't connect the oven? Because it's been connected for a year :D
  • #8 16448936
    vodiczka
    Help: 1185
    Rate: 4311
    I did not ask you for photos :) You have received an explanation, use the sage "eye and umu" and judge for yourself whether it is OK or something should be changed.
    "A fridge does not mean an oven" that is much less powerful and will not burn out the socket and the oven may or may not.
    Check that the plug and socket do not heat up during oven operation.
The discussion revolves around the feasibility of connecting a refrigerator to power using a splitter instead of a direct wall outlet. The manual advises against using extension cords or splitters, emphasizing that the refrigerator should be plugged directly into a wall socket. Responses highlight the importance of ensuring that both the splitter and wall outlet have protective contacts if the refrigerator's plug includes a protective pin. Users discuss the differences in power requirements between refrigerators and ovens, noting that while refrigerators typically have lower power demands, caution is advised to prevent overheating of plugs and sockets during operation.
