Restarting Electrolux EWF1287HDW Washing Machine: Step-by-Step Guide and Troubleshooting
ketchoop 12402 12
How do I unlock or restart an Electrolux EWF1287HDW washing machine that is stuck with a blinking padlock after a program ends?
To clear the lock, hold the “Prewash” and “Easy ironing” buttons at the same time; this disables the parental lock and makes the machine respond again [#16980709][#16983666] If you want to enter service mode and read the stored fault, set the knob to the first position, hold “Start/Pause” and the button with the key symbol for 3 seconds until the indicators flash, then turn the knob to position 11 to display the last memorized error [#16450559] The blinking padlock indicates a lock function rather than a simple resetable fault [#16983666]
  • #1 16449711
    ketchoop
    Good morning, how can you restart the washing machine as in the subject?
  • #2 16449756
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    ketchoop wrote:
    How can you restart the washing machine as in the subject?
    What question such an answer :cry:
    http://poszukaj.elektroda.pl/szukaj,zresetowa%C4%87-pralk%C4%99-electrolux.html
    http://poszukaj.elektroda.pl/szukaj,reset-pralki-electrolux.html
    3.1.15. Publish entries presenting the problem, without providing enough information to enable other Forum Users to take a substantive position.
  • #3 16449774
    ketchoop
    Dear Moderator, I have searched the entire forum and found no answer to my question.
    In the links you put there is no answer to the question.
    In the subject I included the type of washing machine and the question of how it can be restarted, I can expand the question and write how to enter the service mode.
  • #4 16450031
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    Describe what your problem is, these washing machines do not need to be reset. The cause must be removed and a reset will not be needed.
  • Diagnosing blank display and total machine inactivity
    #5 16450053
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    ketchoop wrote:
    it hung up
    So what does it show up and when did it crash? What was she doing or was she supposed to do?
    ketchoop wrote:
    the question is how can it be restarted
    Of course, it was disconnected from the 230V network for a long time, and the electronics of the PCBs were viewed and measured? However, the LCD panel does not display anything, the washing machine itself does nothing at all, does it?
    Writing as below:
    How this topic is supposed to look like, it is about to end up in the basket ...
  • #6 16450531
    ketchoop
    Okay, I'll start again, I was only interested in the key words needed to restart the washing machine or enter the service mode.
    Failure History.
    - Pairing program - turned off 1 minute ahead of time, waited some time (maybe too short) to open the door
    - The door could not be opened, two keys pressed to unlock the door had no effect.
    - The washing machine's power has been turned off and on, after this operation the washing machine display shows as below,
    All the time flashing start, each press of a key or knob only blinks the padlock. The door has been manually unlocked using this dining box at the bottom of the washing machine.
    Answering the questions, the power supply was disconnected for the whole night min. 10h, the tile is not measured and it will not be, unfortunately, a dryer is standing on the washing machine (I can not take off this as itself).
  • #7 16450559
    TONI_2003
    Moderator
    Help: 2195
    Rate: 3828
    ketchoop wrote:
    or entering the service mode.
    :arrow: link :idea:
    peter falk wrote:
    Knob first position, fingers for start / pause and "key" above - hold for 3 seconds - indicator lights will flash - knob for 11th position - the last error memorized on the display. Work :spoko:
  • #8 16450572
    ketchoop
    The knob in this washing machine is electronic with position lighting, I can not select anything with the knob because as I wrote everything is locked including the position indicator.
    I really spent a lot of time on the forum and not only in search of the answer to the question bothering me.
  • #9 16450881
    zibi1971
    Help: 262
    Rate: 1120
    I suggest checking the heater for puncture for protection
  • #10 16977930
    j_god
    Hey ketchoop
    did you solve the problem?
    I have a similar situation.
    The washing machine performed the "rinse" program with the spin turned to 0 (before clicking I clicked on the panel). About 20 minutes after finishing the program (I do not know what was going on there because I left the bathroom after the start) I opened the washing machine. The laundry was wet and spun (!) But I didn't care. I closed it, added washing liquid and I still can't do anything. The washing machine is stuck in the "rinsing" program, the timer shows 0, the knob is also blocked, as I turn it it lights up in the rinsing position, the padlock blinks on the panel. The door is unlocked.
    On / off of the button and turning off / on does not help.
  • #11 16980709
    Chupacabra
    Help: 247
    Rate: 868
    And how do you hold '' prewash '' and '' easy ironing '' simultaneously?
  • #12 16983666
    j_god
    thanks for the answer, actually this combination of buttons solves the problem. Even this is written in the instructions, but in the "settings" chapter and you must first find out that this is not a bug, but a feature :-)
  • #13 16983680
    Chupacabra
    Help: 247
    Rate: 868
    The so-called parental lock?
The discussion revolves around troubleshooting and restarting the Electrolux EWF1287HDW washing machine. Users express difficulties in resetting the machine, particularly when it becomes unresponsive or locked. Key issues include the machine being stuck in a program, the display showing a blinking padlock, and the inability to unlock the door or select settings. Suggestions include checking the heater for protection issues and using a specific button combination (holding "prewash" and "easy ironing") to unlock the control panel. Users emphasize the importance of understanding the machine's features and service mode for effective troubleshooting.
