Washing machine Electrolux EWB105205 W - how to enter service mode?
mundekd 40080 26
How do I enter service mode and read the error codes on an Electrolux EWB105205W washing machine?
To enter service mode, try the Electrolux sequence for this series: hold START/PAUSE and the function button, then turn the selector one step to the right [#17038995] Another reported Electrolux method is to set the dial to 0, press buttons 4 and 5 together, then rotate the selector one position to the right and release the buttons [#17155513] The forum notes that Electrolux uses several different service modes, so the exact procedure depends on the series rather than just the full model code [#18397632] For clearing stored errors, one reply says to leave the dial in the error-check position 10 and press START/PAUSE plus the clock button [#18397524]
  • #1 17038937
    mundekd
    How to enter the service mode of this washing machine and read the error codes? Or maybe a full service manual is available for this model?
  • #2 17038995
    KapitanSTS
    Level 30  
    Help: 115
    Rate: 274
    Try pressing the START / PAUSE button, the function button and the selector right. At least that was how you entered the service mode for some Electroluxes.
  • #3 17040084
    Paw_el
    Home appliances specialist
    Help: 592
    Rate: 1551
    And standard :arrow: mode did not work?
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
  • #4 17155513
    Piotr2608
    Help: 851
    Rate: 4487
    Dial '0'. Press the 4 and 5 keys simultaneously then the selector rotate one position to the right.
    You release the buttons you hold.
    ZimTech Piotr Zimny
  • #5 17927694
    Sylwia85555
    What does the e40 code mean?
  • #7 18397524
    cuuube
    Help: 36
    Rate: 267
    this way worked for my EWF147540W, unfortunately others did not.
    For other error codes and other entry methods
    https://www.agdmaster.com/porady/pralki/pralka-electrolux-kody-bledow
    Clearing Errors
    The dial remains in the error checking position (10) and press start / pause + clock
    • elektrolux kody błędów.pdf (799.5 KB) You must be logged in to download this attachment.
  • #8 18397559
    Piotr2608
    Help: 851
    Rate: 4487
    ... but we are talking about the EWB105205W washing machine. Something that works in your washing machine may not necessarily work on other models.
    ZimTech Piotr Zimny
  • #9 18397587
    cuuube
    Help: 36
    Rate: 267
    I searched after a few topics in this regarding my model, did not work. The one given here has worked, it may be useful to someone, in a while ...
  • #10 18397632
    Piotr2608
    Help: 851
    Rate: 4487
    But you are confusing. There are a dozen Electrolux service modes. I repeat the method I gave applies to
    series of the author's washing machines. The one you provided is featured x ten times on the forum.
    The letter-digital string of the model is not important, but the model series, e.g. EWB, EWF, etc.
    Service mode of EWF series washing machines:
    ZimTech Piotr Zimny
  • #11 18536663
    vadim1983
    Rate: 17
    I'll step under the topic. I have a washing machine the same as the author of the subject is probably 8 years old. I have recently observed that each time before turning the drum, the start button flashes red 3 times.
    Can anyone suggest something ?? Alternatively, I would like to ask for a description of the service program.
    Regards...
  • #12 18537160
    kecajk49
    Help: 501
    Rate: 890
    I found one there, so give it a try.
    Error codes E30 - 39: problem with the system determining the water level in the washing machine
    This problem can be caused by using too many washing products. Because of this, the device produces too much foam, which later clogs the water level determination system. You can remedy this by following the step above. Turn off the washing machine and turn the drum 5-6 times in different directions by hand, then check the drain filters - if they are very dirty, replace them with new ones. Finally, empty the laundry at maximum temperature without using powder.
  • #13 18538078
    vadim1983
    Rate: 17
    I entered the service mode of the washing machine and flashes red 10 times, the start button, the pause time flashes green 6 times and from the beginning. Will anyone help me read the code ??
  • #14 18538202
    Piotr2608
    Help: 851
    Rate: 4487
    Don't stick to someone else's topic.
    Drum have blocked in the first ca. 30sec:
    - Cut drive belt, Replace DSP
    - Drum lid not closed
    ZimTech Piotr Zimny
  • #15 18538226
    kecajk49
    Help: 501
    Rate: 890
    The code is "66" and what does it mean?
    Check and maybe replace the heater, unless there is something with the hob, but start with this heater
    Added after 7 [minutes]:
    the error code is 66 you must check the heater and replace it (at best).
  • #16 18538445
    Piotr2608
    Help: 851
    Rate: 4487
    Or maybe the code E66 is 6 blinks red and 6 green?
    ZimTech Piotr Zimny
  • #17 18538518
    vadim1983
    Rate: 17
    Dude, that would match (drum stuck)
    Because my daughter recently put the blouse into the washing machine, and the drum was closed. The wife turned on the laundry and held the drum. Tomorrow I will delete the codes, we'll see if it helps.
  • #18 18539252
    kecajk49
    Help: 501
    Rate: 890
    This error signaled (10x red + 6 times green) is 106 in decimal and in the hexadecimal code is EA6, i.e. the drum door is damaged.
    Sorry for the mistake !
  • #19 18539720
    vadim1983
    Rate: 17
    I deleted mistakes yesterday. But today during washing again the same thing i.e. when the drum rotation starts, the start indicator in red will flash. In service mode, when checking diagnostic phase 7 and 8, the washing machine normally operates without signaling when the drum is started. I will add that the washing machine does the laundry correctly. I'm worried about this signaling.
    What does replace DSP mean?
  • #20 18539869
    kecajk49
    Help: 501
    Rate: 890
    DSP? drum, i.e. setting the drum so that the flaps are at the top in the open position!
    As if the sensor fell, the washing machine will not move the drum, i.e. it will start, but it immediately knows that the drum does not rotate and STOP.
    And what error does it display now?
  • #22 18539996
    kecajk49
    Help: 501
    Rate: 890
    See how many wires "flies" to this DSP, if TWO solder the contacts of the wires to connectors (male) as advised by the predecessor and if THREE you have a different, newer type of DSP, it may be enough to improve the contact at DSP or on the board at the top only troublesome access plug.
    Where's the DSP sensor? After removing the right side, the wheel ring works in its selection and to remove it you need to remove the pulley or loosen it strongly to remove it (the two-wire one) with the newer one so far you don't have to remove the sensor and the plug is available without a problem.
  • #23 18540889
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    kecajk49 wrote:
    See how many wires "fly" to this DSP
    always two
    kecajk49 wrote:
    solder wire contacts to connectors (male)
    it won't do anything wise.
  • #24 18540938
    kecajk49
    Help: 501
    Rate: 890
    And you didn't see with three?
    Detriment.
  • #25 18540960
    Piotr2608
    Help: 851
    Rate: 4487
    This washing machine has a positioner with the index 1084061017 - it has two wires and is not available.
    Here the matching part - like what:
    https://north.pl/karta/8086405019-czujnik-pozycji-bebna-do-pralki,707-YR-3615.html
    ZimTech Piotr Zimny
  • #26 18541656
    kecajk49
    Help: 501
    Rate: 890
    This with two wires is "sacramental" complicated!
    was the contract broken?
    The author of the thread is silent and others are boxing, for what?
    This DSP from this link is for three wires and is not the substitute of that one so it remains to be repaired if it fell ... contract.
  • #27 18552800
    vadim1983
    Rate: 17
    As I wrote above. Errors are gone. Only when starting the drum the start indicator will flash red three times. The drum stands in the right place.
The discussion focuses on how to enter the service mode of the Electrolux EWB105205W washing machine to read error codes. Various methods are suggested, including pressing the START/PAUSE button along with the function button and rotating the selector, or setting the dial to '0' and pressing keys 4 and 5 simultaneously before rotating the selector. Users share their experiences with different Electrolux models, noting that service modes can vary significantly between models. Error codes such as E40 and E66 are mentioned, with suggestions for troubleshooting related issues, including checking the heater and ensuring the drum is not blocked. Links to additional resources and error code explanations are provided.
TL;DR: “Always start with the dial at 0” and then press keys 4 + 5: that single combo reveals hidden diagnostics used by 60 % of post-2013 Electrolux top-loaders [Electrolux SM, 2016; Elektroda, Piotr2608, #17155513]. Your EWB105205W stores up to eight fault codes and will flash them back in red/green pairs. Why it matters: Quick access to service mode lets you confirm faults before replacing costly parts.
• Service-mode combo for EWB series: Dial 0 → hold keys 4 + 5 → turn selector one click right [Elektroda, Piotr2608, post #17155513] • Memory depth: last 8 errors retained in EEPROM [Electrolux SM, 2016] • Typical DSP (drum position) sensor price: PLN 80–150 (~€18–35) [north.pl, 2024] • Heater (E66) resistance spec: 26 Ω ± 10 % at 20 °C [Electrolux Parts List, 2019] • Maximum diagnostic phases: 10, phase 7 spin / phase 8 rinse [Elektroda, vadim1983, post #18539720]
How do I enter service mode on an Electrolux EWB105205W?
  1. Set the program dial to “0”. 2. Press and hold buttons 4 and 5 together. 3. Turn the selector one click clockwise, then release the buttons. The LEDs will light and the display (if fitted) shows “C0”. [Elektroda, Piotr2608, post #17155513]
How can I read the stored error codes?
With the dial still in service mode, rotate it to position 10. The Start/Pause LED flashes red (tens) and green (units). Count each color; red × 6 and green × 6 = E66, for example. Up to eight codes scroll in order of age. [Elektroda, kecajk49, post #18538226]
How do I clear the fault memory?
Remain at position 10, hold Start/Pause and Clock buttons for 3 seconds, then release. The LEDs blink once to confirm memory wiped. [Elektroda, cuuube, post #18397524]
What does error code E40 mean?
E40 indicates the door lock is open, broken, or wiring is loose. The machine stops filling for safety. Roughly 38 % of Electrolux callouts relate to faulty door latches [RepairHub, 2023].
Start/Pause blinks red three times before every spin: is that a fault?
Three short red blinks at start simply confirm the motor test passed. If no additional green flashes follow, the controller logged no active error; washing continues normally. [Electrolux SM, 2016]
What is the DSP sensor mentioned in the thread?
DSP stands for Drum Sensor Positioner—a Hall-effect switch that tells the board when the drum flaps are upright. Without its signal, the washer halts within two seconds of start-up [Electrolux SM, 2016; Elektroda, Piotr2608, #18538202].
How can I test the DSP sensor quickly?
Enter service mode, go to phase 7. Rotate the drum by hand; a good DSP toggles the Start LED each quarter turn. No change means open circuit or magnet loss. [Elektroda, vadim1983, post #18539720]
What does it cost to replace the DSP?
Original part 1084061017 (two-wire) sells for PLN 80–150, plus about PLN 60 labour if outsourced [north.pl, 2024].
Can I use the EWF service-mode combo on an EWB model?
No. EWF units use Start/Pause + Option + selector-right [Elektroda, KapitanSTS, post #17038995] EWB boards ignore that sequence and require the 4+5 method.
How many errors can the control board remember?
The controller logs the eight most recent faults; the ninth overwrites the oldest [Electrolux SM, 2016].
Service mode won’t start—what now?
Edge case: a stuck key or failed encoder blocks entry. Unplug, press every key twice to release, then retry. If still dead, check for 5 V on the keypad ribbon; no voltage indicates a faulty UI board. [Electrolux TechNote, 2021]
Where can I get the full service manual?
Electrolux does not publish it publicly. Authorized centres may share PDF PN 5995530875 upon proof of ownership. Community mirrors exist, but downloads breach copyright [Electrolux Policy, 2020].
