Electrolux EWF11274BW Washing Machine: Resolving Error E51, Door Lock & Timer Issues
phiter 6033 5
  • #1 16541681
    phiter
    Level 19  
    Help: 33
    Rate: 188
    Hello, I have a problem in the washing machine mentioned in the topic, i.e. error E51. In general, the washing machine only blocks the door and that's it, it doesn't even count down the time, it stands at the given minute. Error reset does nothing. Engine checked, no puncture, except for the system works, engine harness checked, disconnecting the ground wires gives nothing, I replaced the engine triac .. will anyone help?
  • #2 16542725
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
    What did you check the engine for leakage?
    The triac on the module still needs to be checked.
  • #3 16542793
    phiter
    Level 19  
    Help: 33
    Rate: 188
    I checked the engine with a megohmmeter, I replaced the triac - and my friend knows what it should be like, because I am not sure if someone has already fumbled in this module in front of me and maybe he put it in a bad one
  • #4 16543293
    MARCIN.SLASK
    Help: 1037
    Rate: 2658
    I suspect some BTB16-600.
  • #5 16602770
    piotrek1608
    This triac, which was written by the predecessor, agrees with the ending of the SW designation. BTB16-600SW.
    Best regards.
  • #6 16603133
    POL02
    Help: 180
    Rate: 550
    How did you check?
    The correct check of the motor circuit is performed at the plug on the module.
    By checking the contacts on the plug with an ohmmeter, the ohmmeter should still show the correct resistances for the excitation, rotor and generator.
    If you did not measure it, repeat the tests.
