[Solved] Unlocking Electrolux EWT 1262 TDW Washing Machine: Unresponsive Cycle End and Start Lock Indicators
Nowamowa 10935 4
  • #1 18602684
    Nowamowa
    Rate: 10
    I have a problem starting the Electrolux EWT 1262 TDW washing machine. After the program is switched on, two indicators light up on the panel - cycle end indicator and start lock function indicator. They do not respond to touch with your finger, what is the reason and how to unlock it? Thank you for the hint.
  • #2 18603278
    Oxygen1410
    Hey, did some of the elements rebel? I mean a pump (worn out) or a clogged filter that made it fade?
    Maybe no water supply (clogged filter supplying petrified water)
    The solenoid valve, which also has a certain lifetime, is also suspected.
    It would be appropriate to check if it reacts to the postponed voltage.
    If you treat my info as a truism, don't be angry.
    I write about it because I only have such messages.
    Wojtek
  • #3 18604252
  • #4 18604563
    skryn
    Home appliances specialist
    Help: 268
    Rate: 1011
    Try pressing these two sensors at once:
    Washing machine control panel with highlighted sensors.
  • #5 18646874
    Nowamowa
    Rate: 10
    The fitter unlocked the programmer, the washing machine works :) .
