[Solved] MTD B115 Tractor: Transmission Assembly Queries - Gearbox, Reverse Gear & Gears 15/16 on Shaft 13
andren123 11844 3
  • Reverse gear binds; should gears 15 and 16 move on shaft 13?
    #1 16450115
    andren123
    Rate: 93
    Hello. I have a MTD B115 tractor. I bought it with the gearbox unfolded. I put everything together and the box walks but I don't have reverse gear. When the reverse engine is turned on, the engine gets resistance and the belts start to burn. My question that came to my mind when assembling the chest. Will Gear No. 15 and May 16 move around on fight No. 13? Because as I noticed one of them is movable and the other one is rigid. On my peasant reason should probably move, but I prefer to deal with "professional strength" Thank you for your help
    m MTD B115 Tractor: Transmission Assembly Queries - Gearbox, Reverse Gear & Gears 15/16 on Shaft 13
  • #2 16455955
    TheGolibroda
    Rate: 14
    I made such gears at home. These modes 15 and 16 must be movable. In the photo, the blue marked fangs enter the red spots in the gears, which are responsible for whether the tractor travels forward or backward. You have yellow fingers as if they overlap yellow, between the gears with fangs. One of the gears is locked and therefore does not go back and burns the belt. MTD B115 Tractor: Transmission Assembly Queries - Gearbox, Reverse Gear & Gears 15/16 on Shaft 13
    There are other markings in the picture but the transmission is the same.
  • #3 16456303
    andren123
    Rate: 93
    Thank you for your answer. I came to the same conclusion that it would work, these wheels must be mobile. Thank you for your help.
  • #4 17089434
    andren123
    Rate: 93
    After starting the baked wheel in the box everything works as it should. Thanks for the help
