Radio Recommendations for Astra G with Steering Wheel Control: Options under PLN 200
TenKtóryWie 14439 4
  • #1 16450824
    TenKtóryWie
    Good evening :D .
    I would like to get advice on which radio to choose for Astra G and keep the steering wheel control, I learned that I need to look for a radio with three cubes.
    Unfortunately, for now I have not found any such up to PLN 200, it is not about displaying data on the screen in Astra. All I need is steering wheel control which I know can be connected to the radio as long as it has the radio connector connected as above.
  • #2 16451046
    bujemuje
    Rate: 27
    Well, it will be hard. I have not yet seen a factory radio with such a control cube (btw. Laguna has the same). I would like to buy a radio with steering wheel control (usually a blue miniJack input) and an adapter from the original minijack input. At one time (3 years ago) I paid PLN 150 for such an adapter + then Sony 500 PLN radio now radios for PLN 200 already support steering wheel control. Of course you need an adapter :-)
  • #4 16451172
    piotrek22101
    Help: 695
    Rate: 1421
    This set should match.
  • #5 16452756
    bujemuje
    Rate: 27
    It should be that: the adapter is selected for a specific radio and car model. Note that the radio you give is not controlled by miniJack (I haven't noticed or I'm blind), however, the manufacturer supports them, so it goes with ISO cables confidently. Pressing a key on the remote control causes "resistance" in ohms that must coincide with the target radio. As these radios cannot match the keys, I can see everything must be programmed in the adapter. Be sure to write the seller for which radio model (new) you need an adapter for. Later, after changing the radio, if the plug is the same, the adapter may fit and work, but not necessarily all the keys and not necessarily with the assigned functions (e.g., click vol + and the song changes).
