Creating Home Ethernet Network with Orange Funbox 3.0: Verification, IP Cameras, UPS, POE
MM44 3975 5
  • #1 16450954
    MM44
    I am at the stage of creating an Ethernet network in my home and I am asking for verification if the project is correct.
    In the attic there will be a switch and NAS powered by UPS, and the internet connection will be in the basement, and the supplier will probably be an orange and their funbox router.
    1. First, will it even work?
    2. Will the router power the IP cameras?
    3. I would like to see the cameras in case of power loss at home using UPS, should they be powered from the switch in this case? Should the switch then be POE?
  • #2 16451025
    sylweksylwina
    Help: 1884
    Rate: 2357
    If the cameras can be powered by PoE, you must have a PoE switch or additional power supplies. Funbox will not power them.
    What will the images from the cameras be saved for?
    In such a situation, after a power failure, if the FB is not connected to the UPS - the cameras will not work.
  • #3 16451475
    MM44
    I wanted the image to be saved to disk on the NAS. So I think I need to either power the FB for some UPS, or pull the cameras from the switch that will have PoE?
  • #4 16451915
    LucekB
    Help: 143
    Rate: 137
    Orange Funbox 3.0 at home? What service will you have? Only access to the Internet or TV?
    They give funbox 3.0 for FTTH fiber
    to neostrada vdsl funbox 2.0
  • #5 16452334
    MM44
    In my city, they are already establishing an orange fiber, so I think fb 3.0
  • #6 16452735
    KOCUREK1970
    Help: 3863
    Rate: 5496
    @ MM44
    If you want to preview the image after a power failure - it's not only a PoE switch, but also a router, the NAS must be under the UPS - and in this case, not the one for PLN 200 (low current efficiency, and it will consume some electricity).
    It is worth thinking that the UPS would automatically turn on to the power supply if it comes back (after the battery is discharged) and starts to charge and power all elements of this network again.
