[Solved] Nac T675 Mower: Fuel Pump (Primer) Isn't Drawing Fuel - Possible Carburetor Issue?
wierza3 17676 4
  • #1 16451647
    wierza3
    Rate: 8
    Hello. My mower cannot ignite. I pump fuel with a pump. According to the instructions 3 times and the mower does not ignite. After unscrewing the fuel pump (primer) and dismantling it, it turns out that it is dry inside. I removed the air filter and poured some fuel in with the syringe. The mower caught up after two pulls and operated normally. Is it possible for the pump to break? After dismantling, there is only a spring inside, or is something about the carburetor wrong?
  • #2 16451726
  • #3 16451839
    wierza3
    Rate: 8
    Approx. I thought it worked just like a two-stroke grass trimmer that pumping fuel into. So what can be the reason that the mower does not start. After pouring fuel into the carburetor with the syringe from the air filter side, there are no problems with firing.
  • #4 16451908
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    I had a similar problem with the carburetor / pump on a Brigs engine. The reason was a damaged, not "tight" seal between the carburetor and the air filter base in which there is an air duct from the pump.
    Gasket of this shape:
  • #5 17406458
    wierza3
    Rate: 8
    Finally succeeded.
    The problem was in the unoriginal gas line, which I had to replace. It turned out that it was too tight. After pulling a few millimeters, everything returned to normal and the mower works.
