MD81S Webcam Configuration: Setup with P2P Cam Viewer on Android, EPC3925 Modem & Remote Access
amigo70 7410 8
  • #1 16451816
    amigo70
    Hello everyone, I have an MD81S webcam I have such a problem I have no idea how to configure it because I started it and I have a preview on an android phone the program I use is P2P Cam viwer but I do not have a view on the computer although it has an assigned IP address and the second problem is how to do it I had a view from the outside, I have internet with UPC with EPC3925 modem, how would I have to configure it to make it go crazy in advance, thank you in advance
  • #3 16465563
    amigo70
    no, I did not try, but as I entered this link now, this page is blocked because it steals passwords and logins, such a message popped up and when I skipped it, a login window popped up, what should I enter, what logs and which password
  • #4 16465568
    sosarek
    Help: 9320
    Rate: 15541
    What is the manual attached to the device?
    The camera must be connected to the network and configured for external viewing to work.
    Z
    Pka, Poznań, 60-850
  • #5 16465704
    amigo70
    it is connected to the network everything is exactly written in the description
  • #6 17495813
    fikon
    Rate: 8
    I bought such a MD81s camera and I can't configure it for anything in the world I download a program from a Chinese store as it is in the manual I connect to the camera on the phone program in the LAN tab sees the camera there is an image then I enter the wifi settings enter the router password, before that I put it to the camera a micro sd card which I can not format from the application level, a card formatting error pops up, the sticker shows the id and password number, but I do not know what to do with it in the application, there is no option to enter these numbers, did anyone of you configure such a number the camera successfully?
  • #7 17746194
    piotrva
    Help: 625
    Rate: 735
    I have the same problem - I do everything according to the instructions (on 2 different Android devices) and unfortunately it does not detect the camera in the LAN tab :| I tried all combinations of switches and pressing the hidden button next to the place where the tape comes out - to no avail.
  • #8 17840381
    kwas1988
    unfortunately I have the same problem. Maybe you managed to solve it.
    The camera starts up, after downloading the application indicated in the instructions, I can see the camera, I have a preview, but it looks as if it was the maximum zoom.
    There is nothing you can do in the PTZ tab. No other android app can see the camera and from what I found on the net, practically every one should. Especially for this type of camera.
    Besides, when I enter the camera settings, nothing can be edited. After entering the settings and the WiFi tab, it crashes me to the main screen.
    I was surprised because my friend has an almost identical webcam and works like gold. Only he bought his in the country for over 100 and I from the Far East paid 196 via Joom with a shipment for 4 pcs.
    I suppose that some (including me) found very cheap and poor "versions" of this equipment. I wrote to the supplier my comments about the operation of the webcam (among other things, the offer included information about the 2800 mAh battery, and in the manual and physically it is 230mAh :wink: but that's what I expected). We'll see if they help, but it will probably be "you have your money and ... tyryry" :D
  • #9 17840392
    piotrva
    Help: 625
    Rate: 735
    They refunded me the money - mine did not work at all, it does not report in the application, and I checked several of them under Android and iOS. Unfortunately, the crap inside is impossible to hack / reprogram when it comes to the processor. The only thing that could be used is a WiFi module ...
The discussion revolves around configuring the MD81S webcam for remote access using the P2P Cam Viewer app on Android, alongside an EPC3925 modem. Users report difficulties in establishing a connection, with some able to view the camera on mobile devices but not on computers. Issues include blocked access to configuration links, inability to format micro SD cards, and problems with the camera's settings crashing the app. Several users suspect that low-cost versions of the camera may be poorly manufactured, leading to functionality issues. Suggestions include checking the device manual, ensuring proper network connection, and troubleshooting through various apps.
